Question about Singer Sewing Machines
All my decorative stitches are comming out straight
Only my straight stitch is working any other decorative stitch I choose comes out straight
  • Singer Master
  • 7,365 Answers
It sounds like something has happened to the cam gears that
do the decorative stitches, which means the sewing machine needs
to be checked..
but before you have the machine checked,, make sure all the
dial that are used for decorative stitches are at the right setting
one missed setting can cause a lot of problems
Posted on Nov 02, 2012
SOURCE: Sewing machine straight stitch is not straight
Hey. It's full out possible that you have it on the right setting...but concider this - the switcher inside the sewing machine could be broken (ie. It's moving to different stitches - but not the one you have the outside set for)
It happened to me (pc o crap singer model)
Posted on Jan 24, 2008
SOURCE: shark 384 - how can i get a straight stitch?
How canI get a straight stitch Shark 384
Posted on Sep 20, 2008
kent581
  • 87 Answers
SOURCE: Husqvarna Prisma 980 decorative stitch cassettes don't work
On that machine, the cassettes aren't actually computer chips. Each cassette has a little spot of white on a certain little area you must find (top right I'm pretty sure). Look in the machine at that point. There is a sensor that looks for that white spot, and as it identifies it, it changes stitches according to that cassette. Either the sensor is blocked, gone bad, or you can put a fresh coat of white paint on with white out. I hope this helps.
Kent
Posted on Mar 23, 2009
SOURCE: Singer Touch Tronic 2001 Sewing Machine Stuck on Sewing Straight Stitch Only
I had a similar problem a couple of years ago. I finally figured out that I had the straight stitch needle plate (the one with the single hole), rather than the zig zag needle plate (the one with the curved hole). When I changed plates, it worked fine.
Posted on May 27, 2009
  • 46 Answers
SOURCE: only does zig zag stitches, no straight stitches,
make sure the pattern selector is set for straight stitch first. If it is set correct then the machine may be "stuck" is zig zag mode. May need to be de greased and then re lubricated.
Posted on Jul 27, 2009
In order to run a straight stitch, what numbers will I need in the boxes? Thanks. Di
Stitch width needs to be set to zero and NO decorative stitches selected. Stitch length will simply control the space between one stitch to the next.
Nov 16, 2016 | Sewing Machines
My singer heavy duty 5532 makes a knocking noise when I use the decorative stitches
check thread and make sure thread has been in its threading slot in your bobbin case
Mar 23, 2016 | Singer 5532 32-Stitch Heavy Duty Sewing...
I am having troubles with the decorative stitches bought used
Difficult to diagnose. Try a brand new needle that is compatible with the thread and fabric.
All About Needles
If the machine is mechanical, it may need cleaning and oiling if the decorative stitch mechanism is sticking.
Feb 23, 2016 | Sewing Machines
My decorative stitches are not sewing. The machine sews straight okay but the thread does not catch with the decorative stitches.
there could be a problem with the gear for the decorative stitches, the machine may need to be checked to see if there is a gear or gears damaged or broken
Apr 06, 2015 | Elna Quilter's Dream 6003Q
How to fix decorative stitches for sewing machine.
Make & Model??? Sounds like the stitch selector mechanism is stuck. If it's a mechanical machine, you can try oiling the mechanics of the stitch selector with Tri-Flow Synthetic Oil and then heat with hand-held hair dryer.
Mar 23, 2015 | Sewing Machines
How do I set the dials on husqvarna viking 6000 sewing machine
The "dial" in the back is for decorative stitches which require a "programmer" to be inserted with the stitch formation you want to form. For a straight stitch no cam is required in the back of the machine. The three dials on the front:
Upper Left: Stitch selector
Upper Right: Stitch lenght
Lower: Stitch width
Using the upper left dial select the straight stitch picture
Using the upper right, choose your stitch lenght
Using the lower, choose your needle position, left/center/right
Dec 13, 2014 | Husqvarna Sewing Machines
I have a Janome Newhome 672. Cleaned and oiled it, works great. But, the decorative stitches will not form correctly. The reverse is not engaging. How can I fix this. Also, the button hole knob h
In most cases Laurie, with decorative stitches selected some machines can't sew in reverse. Your stitch length is too long or too short to make the decorative stitches sew correctly. So many things could be wrong. I'd need more info to get you going again.
Cheers,
Kelly
San Diego, CA
Embroidery Services
Oct 22, 2014 | Janome Sewing Machines
Why won't it do decorative stitches?
Have you selected the proper stitch. Look at the decorative stitch line 1,2,3,or 4, then the number above the stitch. Your screen should say 1:24 for line one, stitch 24. Make sure you are using the recommended foot. Embroidery unit is disengaged. Then makes sure you have selected the proper weave or thickness of material button. If it still won't sew, try a different type of fabric button and try that. This will change the tension. The tension could be too tight or too loose for that stitch.
Sep 08, 2014 | Sewing Machines
Singer curvy
there could be something wrong with the cam that does the decorative stitches, you may want to have the machine checked..
May 27, 2013 | Sewing Machines
Hello. I hope u can help me. I cannot get my stitching tight? If I pull the thread it comes right out. Thanks Jodie
You need to backstitch over the beginning and end of your stitching, Jodie. When you start out, manually turn the wheel to put the needle into the fabric. Push the foot pedal to stitch forward a little. Now, reverse over those stitches to nearly where you started stitching. Use the foot pedal to go forward again, stitch to where you want to end. Reverse again, just a 1/4 inch or so. Then take the fabric out and cut your stitching.
This backstitching keeps your thread from pulling straight out. You should always use it with straight stitches and general zigzag stitches. Don't use it with decorative or embroidery stitches, though, as it mars the appearance of them. But if you're doing any type of topstitching that uses straight stitches, backstitch in the area that will be in the seam allowance, ever so slightly, or your top stitching will pull out, too.
Hope that helps!
May 19, 2011 | Kenmore 16622 Mechanical Sewing Machine
Sewing Machines Logo
159 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
