Question about Kitchen Gourmet Kitchen Appliances - Others
Gourmets best sw-087a waffle maker manual - Kitchen Gourmet Kitchen Appliances - Others
  • 83 Answers
SOURCE: waffle mix spilled over entire waffle maker, inside and out
If it is a non-stick surface brushing cold water on with a pastry brush while it is still ver hot and immediately after removing the food will clean the surface easily. As for the outside, if it is a painted surface a non- abrasive cloth with warm water could possible clean it. I would not recommend pulling it apart.
Posted on Sep 25, 2008
SOURCE: removing top of waffle maker to clean it
The other night my wife had the same issue. My thought had always been to wipe it down using a wet cloth with simply hot water and rely on the extreme heat of using it to sterilize it.  My wife decided instead to disassemble it.  The problem is that it is not made to disassemble and she bent some parts and broke others and stripped out screw heads.  It is clean now, but can not be reassembled without extracting stripped screws and replacing some parts. My advice to you is - don't try to disassemble it. The factory went to great lengths to ensure that you don't.  Instead use a soft cloth dampened (not dripping wet) with the hottest water you can.
Posted on Dec 29, 2008
greenspan
  • 1734 Answers
SOURCE: Need instruction manual for oster waffle maker model 3871
Ask here, it seems they can get you every Oster manual
Posted on Jul 03, 2009
SOURCE: I need a manual for a salton waffle maker wm4
There is a site that posts PDF files of manuals for all manner of things..manualsonline.com.
Here's the link for the Salton Waffle maker, they have several versions:
http://kitchen.manualsonline.com/search.html?q=+salton+salton+waffle+maker
Posted on Aug 05, 2009
dnewcombe1
  • 1564 Answers
SOURCE: I have lost manual for Emeril Waffle, Pizzel maker
Just punch in "only" the model # and the letters "pdf." and the word manual. Your search should be quick and painless. Good luck.
Posted on Aug 13, 2009
What is the best electric waffle iron to make waffles at home?
In my opinion, the best waffle irons are the vintage ones made here in the USA. They are more durable and more reliable than anything made in China today. Look up the older Sunbeam, Toastmaster, Kenmore and G.E. models and you can usually find either round, square or rectangular versions, as well as models with and without non-stick coatings. The years from late 50's to the late 70's are best.
Jul 31, 2015 | Cuisinart Kitchen Appliances - Others
I lost the instructions for my sunbeam waffle maker, and I dont know how long Ihave to bake it.
Here is a direct link to the User's Manual for your appliance:
http://dl.owneriq.net/d/db0acd4e-57c1-43f0-a51b-4ef04ad30e2d.pdf
To view the Owner's Manual with Operating Instructions just use your mouse to click on the link, which is the underlined and highlighted text just above. This will open a new web browser page automatically for you and allow you to view the information at the website indicated and the contents of the Owner's Manual.
You may need ADOBE READER installed on your computer to read PDF documents.
You can download this free at WWW.ADOBE.COM if necessary.
Click on the DOWNLOAD ADOBE READER button on right side of the ADOBE home page when you get there, then follow the onscreen instructions to install the software on your computer.
See page 2 of the manual for detailed operating instructions. Basically they read as follows:
Preparing Waffles
1. Close Waffle Maker and plug into outlet. Use only voltage specified on bottom of Waffle Maker. The Power light (Red) and Ready light (Green) will come on.
Caution: Touch Waffle Maker only by handles during use or directly after use. Take care not to touch hot surfaces.
2. The Waffle Maker is ready for initial use when the Ready (green) light goes out (approximately 2-4 minutes).
3. Open Waffle Maker, pour approximately 3/4 cup waffle batter onto grids. For best results, pour batter around outer edge of waffle maker. Close cover. It is very typical to have a small amount of batter run over grid and down Waffle Maker. However, if an excessive amount of batter runs over, use less batter.
4. Close the Waffle Maker by lowering the upper plate onto the lower plate and secure with the safety latch. Do not open cover while steam is escaping. Most waffles bake in approximately 2-4 minutes, depending on personal taste. Waffles are generally done when the Ready light (green) goes out and when steam no longer escapes from sides and front of Waffle Maker.
5. When waffles are done, remove with a fork or wooden tongs. Note: Be careful you do not scratch the non-stick cooking surface.
6. Close cover and wait for Ready light to go out before preparing another batch of waffles. The next waffle may be baked in less time because the plate will store heat.
I hope that was helpful to you, good luck and take care.
Joe.
Aug 31, 2011 | Sunbeam 3852 Waffle Maker
I made some yummy waffles in my kitchen waffle maker and forgot about the one waffle. Several months later, I went to make waffles again and found a terrible black powder in the appliance. The waffle had...
Unfortunately you have ruined a perfectly good waffle maker...
The coating in there is a teflon coating that needs to be applied properly for it to work...if you try to use it in the condition it is in then the waffle will stick to the plate...
Best thing to do is to trash the old one and then buy a new one...
heatman101
Jun 24, 2011 | KitchenAid Kitchen Appliances - Others
When using a toastmaster waffled maker do you have to use an oil or butter pan spray?
Normally you mix oil in with the batter, but this doesn't keep the waffles from sticking. Even non-stick waffle makers stick some. Use a light spray of Pam (or similar) on the bottom tray, add your batter than spray the top pan and close. This gives you your best shot at a perfect waffle!
Enjoy!
--W/D--
Jan 17, 2011 | Toastmaster 217 Cool Touch Belgian Waffle...
How should I clean this product?
you should not submerge this completely in water but whip it out with a soapy dish rag .
Jan 01, 2011 | Kitchen Gourmet 2 Slice Waffle Maker
I open a Kitchen Gourmet Waffle Maker Model #SW-035A The unit plastic cover is broken. The box was not crushed. Where do I exchange the unit for a new one. Thanks for your help in advance James...
i would take it back to the place you bought it at and have them replace it if not there should be a phone number on your instruction manual that you can call for customer service.
Dec 25, 2010 | Kitchen Gourmet 2 Slice Waffle Maker
Jul 28, 2009 | Salton WM8BEL Belgian Waffle Maker
Waffle iron gets to hot -waffles stick
before you make your 1st waffle, spray it really good on top and bottom plate with PAM spray, once at the beginning is all it should take- good luck!
Mar 21, 2009 | Gold Medal 5020 Waffle Maker
Waffle stickes
The question is! Was this waffle maker brought into the home new or used?
Jul 12, 2008 | Waring WMK300 Professional Belgian Waffle...
Kitchen Appliances - Others Logo
107 people viewed this question
Top Kitchen Gourmet Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Kitchen Gourmet Kitchen Appliances - Other Expert? Answer questions, earn points and help others
