Question about LG Washing Machines
Washer won't rinse the water
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 35 Answers
What is the model and what is it doing
Posted on Nov 02, 2012
  • 6277 Answers
SOURCE: My washer isn't getting cold
This is symptomatic of a malfunctioning cold water control valve. Sorry but it needs replacing and a service call to confirm that it is not something else- like the control board not feeding it the correct voltage ;-0(
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Posted on May 10, 2011
  • 6277 Answers
SOURCE: my kenmore washer 80 series
I would gently suggest as a first step that you clean the drain motor/pump lint tray/filter. So many 'faults' are caused by blocked filters and many machines will not even go to rinse or spin or release the door lock if there is any water still left inside.
Here are my complete and generic guidance notes for checking both the drain motor filter and the drain motor ;-0)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!). These panels are either held on by (plasic) screws or will just pull off. Most filters are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play.
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT (alternatively use a wet vac as sensibly suggested by VinnyB1234!)
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. Using something suitable like a glove see if it is easy to briefly slow the motor down. If it is easy then the motor is malfunctioning.
John C
Posted on Jun 24, 2011
Macmarkus
  • 2605 Answers
SOURCE: my washer was flashing F21
Hello, welcome to FixYa.
Based on your description specifically the door not unlocking combined with the F21 or as you stated "F21 & would not unlock" I'd suggest you check the pump filter and sub-components, i.e. back flow ball, drain hose etc.
Here's a link to my solution or explaination to guide you through checking these things. Typically this is associated with an error of F2, F21, or "suds" but not always.
http://www.fixya.com/support/r9090359-whirlpool_frontload_f2_f21_sd_suds
As for unlocking the door, it's a good idea to get the water out first, but in any event to do so is as follows...
Once you remove the service panel at the bottom, shown here (also shown in my "repair tip")....
...there is a manual latch release just below the lock latch assembly that you may be able to see visually or feel for by reaching up to the latch and pull the small "loop" below the lock...this is a image of what you'll be looking for.
Let me know how you make out or if anything is not clear and I'll try to help you moving forward in any manner I can. Good luck.
Please take a moment to rate the info and provide a testimony on my assistance and your experience here at FixYa.
Regards,
Macmarkus :)
Posted on Jul 14, 2011
heatman101
  • 43501 Answers
SOURCE: Washing machine won't rinse and
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Posted on Sep 04, 2011
SOURCE: We pulled our stacked washer
Hi, I got a samsung WA85B5 washing machine running for nine years already, but last week the electronic mulfunction in such a way that when the power plug is turn on, the electronic turned on automatically without pressing the 'power' button and non of the button on the panel works. I installed a new circuit board today but ends up a different problem. After I plug in the power I press the 'power' button and the LEDs light up, all the other buttons function properly ( delay timer, water level, function,course) except the 'start' button. After setting everything it refuse to start. Please help. Thanks in advance. Yip
Posted on Sep 19, 2011
Machine won't run on wash and rinse but motor will start and drain the water out
What you hear is the drain pump, remove back panel to see the problem
Mar 31, 2013 | Haier XQJ50-31 Top Load Washer
My whirlpool steam duet washer won't pour water in the wash cycle
There is no output from the control panel to switch on the inlet valve, so check the inlet valve at this time of the cycle. Also check the water level pressure sensor switch.
Choose another program to confirm if not the controller seems to be suspect.
Jan 24, 2013 | Whirlpool Duet 4.0 Cu. Ft. Steam Washer
My lg model wm2277hs won't rinse water stays after washing
you need to ck the filter in the front down at the bottom left corner of the washer if it is clean you will need a new drain pump motor
Nov 02, 2012 | Washing Machines
Roper washer rtw 4440 xqo very low water level for wash & rinse
You will need to replace the water level switch. Here is a link to the kit.
Here is a video to show you how to replace it.
Oct 21, 2012 | Roper Washing Machines
Washer Control Locked blinking and won't washer won't work
Water still in the bottom of the drum. Empty, clean filter and check pump is turning. Once pressure switch is satisfied no water is left it'll allow the door to open, assuming the door interlock is still ok.
May 19, 2012 | Washing Machines
Maytag_lse7804ace: washer won't fill with water. If I fill it by hand, the cycle works fine (until it gets to the rinse cycle, when it won't fill again).
Hello John,
The most probable reason the washer is not filling is because of a blown fuse that is part of the lid switch asm. By UNPLUGGING THE WASHER and removing the 2 INNER screws on the the control panel and the control panel can be rotated down to see the fuse in the lid switch asm. Here is where the fuse is on the switch asm. its circled in red 11_4_2011_1_39_54_am.jpg
Nov 03, 2011 | Washing Machines
Washer will not rinse on any cycle
Well if it won't rinse it won't pump out wither right? The pump is mounted on the motor. The motor won't pump or spin if the lid is open. I would check the lid switch
When this pump is going counterclockwise the water stays put. The machine agitates.
When time for rinse the motor goes opposite direction. If the lid is open the washer will not spin or pump out. I suspect you must have a lidswitch issue. Here is a video which shows how to check it without guessingthemobilian_3073.jpg
Oct 26, 2011 | Kenmore 23822 Top Load Washer
Washer won't drain, rinse or spin
Water will not drain from machine
1.kinked or clogged hose----clean drain hose
2.pump does not run----readjust & tighten pump-drive mechanism
3.suds lock----remove suds,, add cold water
4.faulty transfer valve---replace
5.defective timer----replace
6.loose belt---adjust belt
Sep 22, 2011 | Washing Machines
Maytag LSE7806ACE washer won't rinse. Machine fills with water and agitates, spins also. Just won"t rinse......help!!!!!!!
Your washer uses cold water only for the rinse cycle.
Start you washer and put the water temperature switch on 'cold' to see if you have any cold water.
If you find that there is no cold water then turn the water off and remove the cold water hose from the back of the washer.
Once you have the cold water hose removed you will be able to look in the water valve and check the screen. A lot of times the screens get plugged up and need to be cleaned. The screen will just pull out of the valve so you can rinse it out good.
Make sure to put the screen back in place.
If you have no cold water and the screen is clean then you will need to replace the water inlet valve.
Aug 03, 2011 | Washing Machines
Washing Machines Logo
56 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
