Question about Mr. Heater Heating & Cooling
How do i disable the oxygen sensor on a mr buddy heater
5 Suggested Answers
SOURCE: Mr Buddy Heater Flameup on ignition
It sound like the pivot inside the regulator is damaged. I think that you will need to replace the regulator.
Posted on Jan 05, 2009
kapishtech
  • 2272 Answers
SOURCE: Mr Buddy portable heater Model
Turn the valve counter clock wise to open in and clock wise direction to close it.if its got stuck on any position,then move it on both direction and then move counter clock wise to open the valve. Check out.Keep updated.Thanks.
Posted on Aug 31, 2010
  • 182 Answers
SOURCE: mr. buddy heater- pilot light goes out when i
would try to replace the thermocoupler for the pilot light and this should cure the problem.
Posted on Dec 22, 2010
bmaaustin
SOURCE: no propane comes thourgh pilot on mr buddy heater
If the pilot will not light get a q-tip and alcohol and remove the wire grill and be sure the cotton doesn't come off the end of the stick wet the cotton with the alcohol and twist it and push it down into the pilot tube 2 full inches. Let the alcohol soak for 30 seconds and while twisting pull the q-tip out. Try this until the pilot lights.
Posted on Feb 29, 2012
Cannot get it too light
PDF]operating instructions and owner's manual - Rural King
www.ruralking.com/.../MH9BX_Portable_Propane_Heater_Manual.pdf
light, adjust or operate the heater. PORTABLE PROPANE HEATER FOR RECREATIONAL AND COMMERCIAL USE. MH9BX. Model #. 02/09 32030. MR.HEATER, INC., 4560 W. 160TH ST., ... Get fresh air at once! Have heater serviced. speciFicatiOns. MODEL NO. .... Some people cannot smell well. .... Buddy series hose.
Mr. Heater Portable Buddy Propane Heater - Bass Pro Shops
www.basspro.com/...Heater-Portable-Buddy-Propane-Hea...
Bass Pro Shops
Feb 03, 2016 | Mr Heater Base Camp Portable Buddy Propane...
Pilot will not stay lit on my mr. heater buddy. where do i get a thermocouple for this buddy model no. MH9BX
First follow this trouble shooting guide to make sure you need one-http://www.mrheater.com/product/faqs/little-buddy-troubleshooting/ Then Amazon http://www.amazon.com/Mr-Heater-Pilot-Assembly-Portable/dp/B008DBRB8W Make sure it's the right one for your model heater.0810snp
Feb 24, 2015 | Mr Heater Base Camp Portable Buddy Propane...
When mr heater portable buddy is on for about 30minuts control valve sticks on high and even on low when heater cools moves it moves freely
The solution is to contact Mr. Heater tech support. Once I made contact with them they took my complain very seriously and wanted immediately to inspect my unit. They issued a FedEx Pickup request to take my unit back to Ohio. They're sending me a replacement unit which they promised to test before send it it me.
Jul 16, 2012 | Mr. Heater Mr Heater Portable Buddy...
My Big Buddy heater inconsistently works on high. The low and medium settings work fine (single ceramic element) but when I turn it to high (activating the second element) the element does not fully light...
I did some research on these units-- I pass them on to you-- Do these help?
your Mr. Heater the model that uses two small one pound cylinders or you have the choice to hook it up to a single larger tank? if so, you must use the special filter connected to the Mr. Heater and then your hose to tank.
This happened to me and after I hooked up the filter my problem was fixed.
Ron
large and sealed of an area are you using it in? I ask because those units have a low oxygen sensor which will shut it down if there is not enough oxygen in the space.(kinda prevents that pesky suffocation thing). Otherwise if using it in larger cold spaces, the issue is can be from the smaller tanks. As mentioned above, a larger tank can solve this, because these units have a fairly good input rate, which will cause the smaller tanks to freeze, and lower the propane temperature and evaporation rate, basically runs out of gas until the tank warms back up.
just one new cylinder, it will run on just one, to verify a problem with the cylinders. Also it could be the pilot light, sit and watch the pilot light to see if it goes out for some reason. If it does the heater will shutdown automatically, but you already know that.
Let us know if we can help further?
Mack B
Jan 17, 2011 | Mr. Heater (F274825)
Big Buddy heater shuts down after a short time while on Hi. There is plenty of ventilation. It will do this even if sitting on the picnic table in the yard. Any suggestions? Have used single, double and...
Well, this happened to my son during the winter of 09 with my Buddy Heater, my heater sat around for months on my shelf hopefully ready to use, and the heater was not used in excess as it was. My son about froze off his body parts trying to camp last year, turns out a recomendation on a web site to use a Qtip Swab dipped in rubbing alcohol swabing inside the pilot orfice tube did the trick. Seems the sensor in the pilot tube area collects dust or some webs and this affects the sensor. I thought it was lack of oxygen when he called me with trouble but he already provided plenty of air for cumbustion saftey, but still the heater would run for short time then make a click/dink sound from unit and shut down. Anyway, tried it when he got back with it and sure enough, click/dink sound in a short time and off the heater went. After discovering this suggestion online it was the right answer because it has worked perfectly ever since, in fact heater was just used recently the weekend of March 20th-21rst 2010 up north here in Michigan. When they sit like mine did the pilot orfice tube collects dust that affects the low Ox sensor. By the way, before he took it recently I simply took canned air as a precaution and blew it out, at the very least this is going to be my standard maintance procedure with it EVERY TIME before it's off to a camping trip.
Jan 31, 2010 | Mr. Heater Big Buddy Heater
Stays lit for 25 minutes and shuts off
How large and sealed of an area are you using it in? I ask because those units have a low oxygen sensor which will shut it down if there is not enough oxygen in the space.(kinda prevents that pesky suffocation thing). Otherwise if using it in larger cold spaces, the issue is can be from the smaller tanks. As mentioned above, a larger tank can solve this, because these units have a fairly good input rate, which will cause the smaller tanks to freeze, and lower the propane temperature and evaporation rate, basically runs out of gas until the tank warms back up.
Jan 19, 2009 | Mr. Heater (F274825)
Jan 05, 2009 | Mr. Heater Portable Buddy
No propane comes thourgh pilot on mr buddy heater
Jan 01, 2009 | Mr. Heater Mr Heater Portable Buddy...
Heating & Cooling Logo
192 people viewed this question
Top Mr. Heater Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Mack Baxter
Are you a Mr. Heater Heating and Cooling Expert? Answer questions, earn points and help others
