Question about Acer Aspire 5100 Notebook
I need a standard enhanced pci to usb host controller-ATI SB450
I CANNOT USE THE USB SLOTS OF MY LAPTOP ,IT HAS A XP OS,WHERE CAN I DOWNLOAD IT,IF POSSIBLE SEND TO ME VIA E-MAIL
    Novelist:
  • 176 Answers
Go here:
http://www.soft32.com/download_170571.html
Posted on Jan 04, 2009
Drivers for hd1600s
if you are referring to usb drive
click start control panel administrative tools computer management device manager scroll down universal serial bus controllers you could see a yellow question/exclamation mark ? ! or a red X you will need to update the driver
right click to reinstall drivers
if you can see your usb drive but its not working
if your computer came with a motherboard disk the drivers could be on it
ports(com&lpt)right click update driver
or you could download them
http://download.cnet.com/usb2-0-driver-zip/3000-18493_4-163914.html Intel PCI to USB Enhanced Host Controller NEC PCI to USB Enhanced Host Controller B0 NEC PCI to USB Enhanced Host Controller B1 USB 2.0 Root Hub Generic USB Hub VIA PCI to USB Enhanced Host Controller
http://download.cnet.com/usb-2-0-root/3000-18493_4-55793.html
http://download.cnet.com/usb-mass-storage-controller/3000-18493_4-161651.html USB Mass Storage Controller
if these packages are not the right
http://download.cnet.com/2000-20_4.html
on the home page you should see a search tab just type in what you are looking for
(be precise)don't use numbers and / - you might have to try a few times to get it right
also the download software finder under that there will be a list place a tick in the box of any one you want/need
all software windows software mac software mobile and web apps
http://majorgeeks.com/downloads35.html
also this link will provide you with many freeware and share drivers
hope this helps you
Oct 01, 2011 | HP HD1600s 160 GB USB 2.0 Hard Drive
Asking for driver
click start control panel administrive tools ,computer management ,device manager look through all of your devices if you see a yellow question mark?or exclamation mark ! or red x
right click to reinstall drivers or
if you can see your usb but its not working
hope this helps you
Sep 27, 2011 | Toshiba HDDR320E04XW 320 GB USB Hard Drive
I am using a fujitsu mpg3307ah in an external usb mode and need to install the correct driver in my vista laptop.
click start control panel administrative tools computer management device manager scroll down universal serial bus controllers you could see a yellow question / exclamation mark? ! or a red X
you will need to update/reinstall drivers
ports(com&lpt)right click update driver if this fails to fix the problem
check the USB leads that attach to the motherboard usually red white green black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems for a computer and its parts
hope this helps you
Sep 26, 2011 | Fujitsu (MPG3307AH) 30.7 GB Hard Drive
Cant find driver for SimpleTech 250gb external hd. Is it available?
Should not be necessary. It is recognized by the system automatically. Try connecting to another port, check the data cable and the connection to the unit, it may be corroded or loose.
Sep 13, 2011 | SimpleTech 250GB USB2.0 7200 RPM External...
I an not have driver usb for hdd2193 for fix problem
click start control panel administrive tools computer management device manager scroll down universal serial bus controllers you could see a yellow question / exclamation mark? ! or a red X
if you dont have a motherboard disk you will need to download the drivers
hope this helps you
Sep 11, 2011 | Toshiba MK4026GAX (hdd2193) 40 GB Hard...
Hi, i do have a n1996, ms-6547, motherboard, imtrying to download a fix for and also for usb 2 and i can not find them,thanks in advance
control panel admistrive tools,computer management,device manager scroll down universal serial bus controllers you should see a yellow question mark? right click to reinstall drivers or ports(com&lpt)right click update driver
If your Device Manager shows an ENHANCED USB Host Controller, the system has High Speed USB (USB 2.0) capability.
Types of High Speed USB (USB 2.0) Host Controllers
· Intel Enhanced
· SiS Enhanced
· VIA Enhanced
· ALi Enhanced
· Standard Enhanced
· NEC Enhanced
The system shown has onboard Intel High Speed USB (USB 2.0) with an NEC High Speed USB (USB 2.0) PCI card installed.
The key word is ENHANCED. If you have an ENHANCED USB Host Controller then you have High Speed USB (USB 2.0)
All other types are USB v.1.1
hope this helps
Nov 11, 2010 | MSI MS-6547 Motherboard
What is the version of the usb port on a compaq presario 1200
Hi again, after extensively searching I believe your Laptop has a USB version 2.0.
Most PC's manufactured before 2001 were USB 1.0 and USB 1.1.
The Spec Guides for your PC indicate 2002 was the year of manufacture.
USB 2.0 is a faster USB connection than version 1.0 or 1.1. You might have trouble connecting devices that are USB 2.0 (which all new devices are now - since 2001).
To double check, use your Device Manager on the PC to look up the USB device and see what is written.
If you are using XP then do the following:
  1. Click Start
  2. Click Settings
  3. Click Control Panel
  4. In the Control Panel double-click the Systems icon.
  5. In the System Properties window click the Hardware tab.
  6. In the Hardware tab click the Device Manager button and you will see a list of devices.
  7. Click the + button next to the word the Universal Serial Bus controllers.
If it is USB 2.0 then it should say something like USB Enhanced or USB High Speed, this means it is USB 2.0 compatible.
I hope this helps. Please rate. Regards,
Feb 12, 2010 | Compaq Presario 1200 Notebook
Error code 19 - Device MANAGER - USB devices
What OS are you running? XP, Vista, 7, etc? In Control Panel where you see the yellow exclamation mark, right click and select Update Driver. When it asks where to find the driver, tell it to search the internet.
If it does not update, then go to the Samsung website to locate the drivers for your computer and OS.
Dec 10, 2009 | Samsung R65 Notebook
Acer Aspire 5100 Notebook Logo
399 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
