Question about Samsung Televison & Video
Samsung TV Model HLS5086WX/XAA turns off by itself
    Top Expert:
  • Samsung Master
  • 14,553 Answers
Not clear if set makes it on or not---its a DLP which uses a lamp for brightness so start there and next would be to inspect the color wheel that faces it directly--no broken or missing pieces there?
Samsung TV Model HLS5086WX/XAA turns off by itself - 11_2_2012_11_24_47_pm.jpg
Posted on Nov 02, 2012
SOURCE: I replaced the lamp on my Samsung HLS5086WX/XAA
To bring up the service menu, turn your TV off. On your Samsung TV remote, press Mute 1 8 2 Power. This WILL invoke 'service mode' and invoking this WILL reset all your custom picture and source name settings. I don't know the specific menu to find the lamp reset option, but I believe it is in the first menu context.
Posted on Nov 07, 2010
SOURCE: television shuts itself off
i had the same problem with my set shutting off and was told it may be the ballast so i changed that but it still would start up and shut down after a few mins, then i was asked if the bulb had been changed and i had not, so i did change the bulb and have not had it shut down yet. :) (so try a new bulb)
Posted on Jul 17, 2009
tvtek
  • 1284 Answers
SOURCE: White dots on screen of 50 Samsung DLP
Random dots or pixels failing on a DLP TV will be a bad DMD chip. This is a technician replace item only. The chip runs around 160 dollars list price. The part number will depend on which version the set uses and will be determined by the technician.
Posted on Jul 23, 2009
ladywinn
  • 5138 Answers
SOURCE: Tv keeps turning off
Lamp! Or defective Lamp Fan that cools Lamp, Call Encompass Parts or visit them on their website.
1-800-638-3328
Posted on Oct 05, 2009
  • 69 Answers
SOURCE: white dots all of screen
sound like you have a bad dlp chip. this happens to a lot of samsung dlp tvs. some of the mirrors are stuck. they can appear as black dots or white dots and it usually gets worse over time.
Posted on Feb 07, 2010
My Samsung DLP Tv turns off after about 3 minutes. What needs to be replaced?
i think it could be trip switch in the back of tv it should be a little blue button you can try put a bit of tape over the button it might work and if its that you can order a new one i put tape on mine and its still working
Feb 21, 2016 | Samsung HLS5086WX/XAA
Samsung TV HLS5086WX/XAA SERIAL # B18E3CELCO1546Dit comes on IN about a minute you hear it click and it goes off. MY TV IS NOT OVERHEATING IT DOES NOT STAY ON BUT A MINUTE.
Sounds like main board fault. Contact any service technician. If you wish to get some details; visit the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Jun 23, 2015 | Samsung Televison & Video
Samsung HLS5086WX/XAA made popping noise and shut off, then made whirring noise.
When my TV did this in the past it ended up being the color wheel. I had someone replace it and it worked fine. I asked it if had to be calibrated after it is installed and he said no. Also make sure the door switch is pushed down when you install the back bulb door. Sometimes this switch can go bad as well.
Jan 10, 2013 | Samsung HLS5086WX/XAA
How do I replace a lamp ballast in my Samsung model # HLS5086WX/XAA?
The ballast should come out fairly easy---at the end of the 2 red wires where it connects to the lamp should be a single screw and the lamp has to be already removed---with the screw at the wire end removed the socket lifts up and to one side and the actual ballast is secured with no more than 4 screws and has only one or two small plugs to remove
You might also check You Tube to see if they have video instructions there for your model.
Mar 20, 2012 | Samsung Televison & Video
I replaced the lamp on my Samsung HLS5086WX/XAA DLP set. How do I reset the timer on the lamp?
I have a Samsung DLP HLN617WX/XAA. After turning off by itself, the three indicator lights were blinking... signifying a defective lamp. I've re-seated the old lamp several times with no change. I bought a new lamp and reset the lamp hours through the "service menu" with no change. My television is still turning itself off and still blinking the same indicator lights. What should I look at, next?
Oct 26, 2010 | Samsung Televison & Video
TV wont turn on
a bad power supply is most likely cause of this. Other possible cause is bad main circuit board.
May 03, 2010 | Samsung HL-S5086W 50" HDTV
Samsung HLS5086WX-XAA after 1 years it's showing dark
Light Engine or the DMD board 1-800-638-3328
Jan 14, 2010 | Televison & Video
Samsung hls5086wx/xaa turns off at random
Go to website Encompass Electronics.com type in your model number it will list part and part number ,you can also look for Lamp on E-Bay Encompass 1-800-638-3328 Also ck Color Wheel remove lamp take a flash light to watch when you turn TV on see if the color wheel is turning if it is defective set will shut OFF. But most likely its your Lamp.
Oct 05, 2009 | Televison & Video
Televison & Video Logo
353 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
