Model KV35540 Series #9017817 goes to standby after 30 sec
Goes to stand by after 30 sec. Still have sound no picture
    Top Expert:
  • Televison & ... Master
  • 14,553 Answers
OLD set, most likely the picture tube has aged and only hope would be if the master screen inside the set is turned up just a little it may function again. If doing that (taking back off) be careful and also look in neck of the picture tube to see if the 3 filaments are faintly lit.
Only chances are no filaments or screen set too low from old age.
Posted on Nov 02, 2012
  • 16 Answers
SOURCE: Standby Light blinks
it is an error code of the sony maybe there is a problem in it.
Posted on Apr 25, 2008
jerryg50
  • 1689 Answers
SOURCE: lg tv cf20d30 goes to standby mode intermittently
Most likely there are some parts that have become thermo sensitive with age. Many times electrolytic capacitors become thermo sensitive as they ware down.
The parts that are going out of spec are probably causing some kind of fault that the set's uPC sees as a fault and puts the set in to protection.
The service tech will use a heat gun and liquid air also known as "freeze spray" to cool and heat the suspect components to trigger the fault, and then reverse it. Once the parts are found, they can be changed.
Jerry G.
Posted on Apr 27, 2008
SOURCE: Standby Blinks 5 times. Picture goes off but sound stays on. Only hookup is Digital Cable - help!
Plug the electricity to a surge protector. I fixed my that way. Try it and let us know.
Posted on Jul 15, 2008
VOTIT
  • 2071 Answers
SOURCE: stand by\timer blinks,picture go out everytime it blink .
Blinking codes meaning:
  • Five blinks - AKB circuit (automatic kine bias), the timer/standby indicator blinks for about 30 seconds then goes to the self-diagnosis function. Something is wrong with the video. Check video out, Q705, 732, 761 and other components on the C board, also check Q218, 219, 220 on the A board. In addition, unit could be in IK blanking, try turning up screen slightly.
Good luck:
Dont forget to rate:
Posted on Jun 30, 2009
SOURCE: tv picture is going out and standby/timer light blinks
Hi Kevin!
The issue may be related to the projection lamp in the TV and replacement may be required. However, before replacing the projection lamp in the TV, you may perform the troubleshooting steps mentioned below.
Please disconnect all the cables from the TV including the power cable then reconnect them after two minutes. Please make sure that the the power cable from the TV is directly connected to a functional wall outlet. Next, you may try connecting any other video source such as cable box, DVD player, Blu-Ray player, Playstation, etc. If the issue persists then try resetting the TV to the original factory settings.
Please follow the steps mentioned below to reset the TV to the original factory settings:
(i) Turn the TV ON.
(ii) Press and hold the Reset button on the Remote Control supplied with the TV, then press the Power button on the front panel of the TV.
(iii) Next, release the Power button. The TV will turn itself off, then back ON.
(iv) Release the Reset button.
If the issue persists then you may replace the projection lamp in the TV.
Posted on Jul 12, 2009
Picture goes on for 30 sec. then off for 45 sec.,power/standby lite then blinks.can this be fixed or thrown out.SONY KDF-E50A10
Search Results
    KDF-E50A10 Sony TV - turns off and on - on its own - Sony's ...
    https://community.sony.com/t5/...Picture.../KDF...Sony...off.../442042
    Sep 12, 2014 - Our TV turns off and on without warning on its own. The standby lights starts to blink and the picture and sound go out, then 30 seconds to a ...
    Sony KDF-E60A20 problems - High Def Forum - Your High Definition ...
    www.highdefforum.com > ... > Rear-Projection TVs
    Jan 19, 2009 - 14 posts - ‎11 authors
    I recently got a 60 inch Sony KDF-E60A20 from a friend for around. ... runs for about 1 minutes then goes black(no picture no sounds), then the picture and sound come right back on for another minutes then off for 30 seconds.
Jan 18, 2016 | Televison & Video
Picture and sound turn on and off
I believe that model has a logic board in it and that is what it sounds like to me. That is just off top of my head, but I believe if you will notice the standby light it will be blinking so many blinks and stop and then blink again. If so this is a code that you can look up on the Samsung web site and plug in your model and it should tell you what just say ~ 4 blinks means. I worked on so many and it has been a while but I believe the last one I had was a Samsung and I put a logic board in it. If I can be of any further assistance please let me know.
Mar 12, 2014 | Samsung HL-R5078W 50" HDTV
HI, MY NAME IS S. A. ANSARI, I HAVE A SHARP AQUOS LC-32A66M LCD TV. ONE DAY SUDDENLY GOES INTO STAND BY MODE. NOW WHENEVER WE TRIED TO TURNED IT ON, IT ON FOR 30 SECOND I.E. WE CAN SEE PICTURE, HEAR SOUND...
Hi Ansari
It sounds like a main board problem. The control voltage that goes to back-light inverter board; from the main board, goes down. Contact any service technician. This is not a user repairable fault. Gopakumar Gopalan Google
Feb 27, 2014 | Sharp LC-32A66M 32 inch Multi-System Full...
The picture comes for 2 secs on the screen and immediately goes to stand by and red LED Sony bravia standby mode blinks 8 times
the picture comes for 2 secs on the screen and immediately goes to stand by and red LED Sony bravia standby mode blinks 8 times
Nov 19, 2010 | Televison & Video
Picture & sound go on & off every sec, red light blinks 5 times
helloFive blinks - AKB circuit (automatic kine bias), the timer/standby indicator blinks for about 30 seconds then goes to the self-diagnosis function. Something is wrong with the video. Check video out, Q705, 732, 761 and other components on the C board, also check Q218, 219, 220 on the A board. In addition, unit could be in IK blanking, try turning up screen slightly.
shaun
Oct 25, 2009 | Sony Grand WEGA KDF-55XS955 55" Rear...
Picture goes off after a brief display on the screen.
dear,
check the flyback. did u hear any noise coming from that ..
regards
Sep 25, 2008 | Sony V SERIES BRAVIA KLV32V300 32 in. LCD...
Tv prob
This is the common symptom of defected IC memory 24COxx,replaced this IC so it will works normal again.
Feel free to ask whatever the result...
Hope this may help you;
DON"T FORGET TO RATE:
Sep 04, 2008 | Sony KDF-E50A10 50 in. LCD HDTV
Televison & Video Logo
Top Televison & Video Experts
