Question about Westinghouse LTV-40w1 HDC 40.02 in. LCD HDTV
How do i setup the pip on a whetinghouse ltv-40w1
I DO NOT KNOW HOW TO SETUP THE PIP
  • 127 Answers
Please refer to the owners manual Is in there
Posted on Nov 02, 2012
  • 8457 Answers
SOURCE: picture in picture
Yes,but must have cable,satalite,or telecom signal.
Posted on Oct 14, 2009
  • 92 Answers
SOURCE: get my PIP to work!!!!!!!
The "Picture in Picture" function will only work with a "digital" source like hdmi or dvi input. It will not work with an s-video or vga input source.
Posted on Feb 12, 2010
  • 20 Answers
SOURCE: Westinghouse LTV-40w1 HDC HAVE SOUND - NO PICTURE
You need a T-con Board and I have that one for $80.00.
I reclaim working components for TV damaged in shipping or returned for other reasons. Simple repair for any body with a Philips screwdriver. NO special tools needed.
GBC_CMC@yahoo.com
Posted on Jun 03, 2010
  • 20 Answers
SOURCE: need dvd for LTV-40w1 HDC PARTS
I have one ($90) but take the old one out first to confirm the part number because they used two different ones. Need to use the same that was origanal. The wrong one will work but the FF and RW functions don't respond correctly.
GBC_CMC@yahoo.com
rylee_smith
  • 8619 Answers
SOURCE: Can't get anything on LTV
Hi
Thanks for using FixYa. From what you have described it seems that you might have a backlight inverter board issue with this TV set. The inverter is the power supply source for the backlights. There could also be a screen driver problem; if it is then you have to change the entire inverter board. All this is only recommended if you have some kind of expertise for checking the internal circuitry of the TV as these units have high voltages running even when the set is switched off. Please do accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Jun 19, 2010
I'm trying to hook up picture in a picture with my TV using the HD dual tuner DVR DC H 6416 converter box. Is there a place that I can connect a cable to the box that has video out to use individually for...
The TV requires two inputs to use the PIP function. Your setup box Has multiple outputs, but the same picture comes out of all of them. The only way you can use PIP in your TV is to split the signal and connect it to both the set-top box and the TV. However; you will not receive the additional channels that the setup box picks up unless you use 2.
Some set top boxes already have PIP built in. If it does you can view a PIP display even if your TV does not have that feature. Because the cable box has 2 tuners built in they are designed to do two different things at one time. If yours has PIP capability they will proudly and prominently tell you about it in the instruction manual..
Nov 15, 2014 | Televison & Video
WS-65611 PIP worked until cable tech connected new Digital Box
do u want pip form the cable box itself or watch dvd on one side then tv on other
Jan 25, 2008 | Mitsubishi WS-65611 65" Rear Projection...
Setup vizio vur103d pip
pip works mostly if you have cable tv the tv needs to use its tuner to display two channels.
Feb 11, 2012 | Vizio Televison & Video
How to setup pip
You should first enable the PIP option from the settings before you can use the PIP button on the remote. To do this press the "MENU" button on the remote, navigate to the "SETUP" option, Select the "PREFERENCES" option, select Picture/Sound preferences, select PIPFORMAT and turn it on. That should do the trick. Once enabled you can use the same menu to adjust the position of PIP etc.,
Should you have any further queries be sure to let me know.
Sai.
Dec 11, 2010 | Philips 37PF7320A 37 in. HD-Ready LCD...
I do not have the remote control how can i setup the pip without it
PIP is always controlled by the remote. If you want a new remote go to remotes.com
Nov 26, 2010 | Sony Televison & Video
I have a Sony trinitron XBR and I can't get the PIP turned off.
A solution I found for our KV-32XBR200 was to press Setup on top of the set, then select the "Demo" item with TV/Video. The text overlay apparently banished PIP. Verified this twice, as I'm at this page because our remote can only turn PIP on :-).
Aug 23, 2010 | Sony KP-53XBR200 53" Rear Projection...
How do u setup the pip
only tvs that have two tuners are able to have PIP.  You can set up PIP if you have a dvd player or a vcr.  The instructions will be in the manuals for them
Mar 29, 2009 | Philips Magnavox 9P6034C 60" Rear...
Can't remove blue PIP (?) section in lower RH corner
I have the Olevia TV with RC-LTU remote, To get rid of PIP just press the (VIEW) button twice.
Nov 13, 2008 | Olevia LT37HVS 37 in. LCD HDTV
PIP is causing problems
You are lucky in that this is problem you can solve yourself with a little diligence. The set has defaulted to the 'Theater Mode'. It happens frequently with this model. It is merely a setting in the customer menu. Go into either SETUP or ADVANCED SETTINGS and look for something refering to 'Thearter Mode' and turn it off. An owners manual would help locate it.
Sep 01, 2008 | Mitsubishi VS-50604 50" Rear Projection...
Turning off PIP on KP-61v45
I had this problem with a universal remote.I tried everything you can think of.Finally I got it.I hit the setup button on top of tv and the volue down button to start the demo.I dont know exactly how long it ran but after awhile I hit a button and screen was normal...Yeah
Mar 10, 2007 | Sony KP-61V45 61" Rear Projection...
Televison & Video Logo
74 people viewed this question
Top Westinghouse Televison & Video Experts
Jaime Hernandez
Are you a Westinghouse Televison and Video Expert? Answer questions, earn points and help others
