Question about D-Link Dlink DI-514 Air Wireless 2.4 GHz Router (A0177337)
I installed a D Link Router on my computer and I don't know where it is i.e. what file it's in?
  • jmax_com Jan 04, 2009
    I have solved the problem. Thank you all Jmax
  • John Hong
    John Hong May 11, 2010
    Please clarify. The question makes no sense.
    A D-Link Router is a piece of hardware (usually grey, blue and silver), it is not installed on the computer, it is plugged inbetween your computer and modem using a category 5 cable. The CD that comes with the router contains the manual and a program that helps you to configure the router but is not required for the router to actually work. What is your problem, what are you trying to do?
U can open router by typing the IP address of that router .most of the router default IP address is 192.168.1.1.try tis
Posted on Jan 04, 2009
I don't have a cd to install the product what other option is available
Connect a LAN cable from the D-Link to your laptop/computer'sLAN port, open the browser on your laptop/computer and enter the D-Link's configurationURL..
http://192.168.0.1
The default login = admin
The default PW = blank (just press Enter)You can now change the default admin password.
You can now configure the wireless settings. Now configure the wireless card in your computer/laptop withthe router's wireless settings.To secure your wireless network from unauthorized access,please click on this link and follow my instructions :-http://www.fixya.com/support/r3559128-wireless_router_security
Jul 08, 2012 | D-Link DIR-600 Router
How can reinstall a router - it was reseted to the original fetures - 20 seconds - after the modem was changed - now I can not re program it
If you don't have the install disk software from D-Link you can always set it up manual.
First press the reset button on the back for 15-30 seconds to make sure its in factory original setup.
Best way to do this is to connect a ethernet cable to your computer to your router. Make sure the ethernet cable is plugged into one of the ports (ex. 1-4) and not the internet port that usually goes to the modem.
Next once you have the router powered up and your computer connected. (don't have it connect to the modem yet just your computer) open your web browser (Internet explore,firefox).
In the address bar type 192.168.1.1 (same place you would type www.google.com)
This will open the router menu onto your screen.
If it asks for a username and password I believe the default for dlink is
username - admin
password - password
Once in the setup page go ahead and browse the options and set it up.
After all is said and done. While the router is off reconnect all the ethernet cables back up to the modem and other devices. Power up the router and you should have internet.
If you need further help setting it up let me know.
Oct 11, 2011 | D-Link DIR-615 Wireless-N Router (54682G)
I don't know how to reset password for d-link DIR-625
Section 1 - Product OverviewHardware OverviewConnectionsUSB Connect a USB 1.1 or 2.0 flash drive to configure the wireless settings using WCN.Reset Pressing the Reset button restores the router to its original factory default settings.LAN Ports (1-4) Connect Ethernet devices such as computers, switches, and hubs.Internet Port The auto MDI/MDIX Internet port is the connection for the Ethernet cable to the cable or DSL modem.Power Receptor Receptor for the supplied power adapter.D-Link DIR-65 User Manual
If you don't know it you can check our list of default router and modem password list here.
If you have changed it and don't remember it you may have to reset your device to factory default using the reset button on most routers.
Sep 23, 2011 | D-Link DIR-625 (790069292637) Wireless...
I contacted c/s for netgear products, I have aWGR 614 v10 wireless router, they recommended I download a driver for it. I went to www.support.netgear.com, attempted to download a deiver, and was not...
I am going to assume you were advised to download a firmware update and not a driver, as in 99% of user installations of a router drivers are not necessary. Below you will find the instruction for uploading the firmware to your router, as well as the links associated with the firmware. You need to access the router through a browser, such as Internet Explorer, Mozilla Firefox, etc. The reason you cannot find the file association is because this is a checksum file with a chk extension and there is no program that can run this in a computer environment, as it is a language file, compiled for installation through hardware. I hope this helps explain what is going wrong and how you can correct this issue. Let me know if you require additional information on setting up your router.
  1. Download the file to a convenient place such as your desktop.
    For North America users only
    right-click-and-save-downlo.gif 1.84 MB
    For users outside Americas - World wide Version
    For users in Russia only
    Note: Do not upgrade the firmware using a wireless connection. Please perform firmware upgrade with "wired" or Ethernet connection only.
  2. Open a Web browser.
  3. Access the router (http://192.168.1.1 or the Default Gateway address if the router's default IP was changed).
  4. Log in the router (User Name = admin and Password = password, unless you changed it).
  5. Write down all settings that you entered when previously configuring. This includes information such as ISP configuration and wireless security settings.
  6. Under Maintenance, click Router Upgrade.
  7. Click Browse and locate the firmware upgrade file.
  8. Click Upload.
  9. Wait for the router to reboot.
  10. Under Maintenance, click Settings Backup, then click Erase. (Or press the reset button on the back for 10 seconds.)
  11. Wait one minute for the router to reboot.
  12. Manually enter the configuration information you wrote down in Step 5.
Jul 07, 2011 | NetGear WGR614 54Mbps Wireless Router...
My computer cannot see router. I don't have driver, it lost How can I download from internet? How can I setup again? please...
This link will take you to the D-Link website. Select your country then it will take you to a page with two links. Below them will be a link to a FAQ which will help explain which of the two you need. Once you know that you can download the one needed. It will contain "revision specific drivers, firmware, installation guides, and other resources."
http://www.dlink.com/products/?pid=226
Jun 18, 2011 | D-Link DI 514 Wireless Router (DI-514)
The start up disk wont start on my mac and I don't know how to get the cd to run any other way = or how to install the route a different way ???
Connect a LAN cable from the D-Link to your laptop/computer'sLAN port, open the browser on your laptop/computer and enter the D-Link'sconfiguration URL..
http://192.168.0.1
The default PW = blank (just press Enter) You can now change the default password.
To secure your wireless network from unauthorized access,please click on this link and follow my instructions :- http://www.fixya.com/support/r3559128-wireless_router_security
May 30, 2011 | D-Link DIR-615 Wireless Router
After inserting CD set up disk , it promts me to take cd out restart computer and try to reload set up disk , over & over!
You should not have to restart your computer to install router. try downloading the installation file from the d-link website :)
Dec 27, 2010 | D-Link DIR-615 Wireless Router
Can you give me a step-by-step tutorial to install my wireless router to my desktop computer?
Here is the link to your complete setup for your modem.
ftp://downloads.netgear.com/files/WNR2000_UM_24FEB09.pdf
If you still need help just let me know.
Thanks
Dec 22, 2010 | NetGear WNR2000 Wireless Router
I am having slow internet while my son has great internet. I want to know how to get to the web browser based utility to see if this is the case.
First make sure your computer is not virus infected. Also follow below procedure to speedup the computer. Remove temp files from computer. Press windows key + R then you can see type in run "%tmp%" without "" then press enter then remove all temp files.Type in run "prefetch" without "' then press enter remove all prefetch files. Type in run "chkdsk /r" then press enter then press "y" then restart computer then it fix errors on harddrive. Scan computer updated antivirus it is best antivirus. Download it's free version from below link. Click here Download and install then update it from internet. Then scan computer in boot time avast scanner. Then your computer and internet run fast. Also your mouse not freeze. For access your router bye web browser utility folllow below. Connect your router to computer with ethernet cable then you can access it with following default link. http://192.168.1.1 or http://192.168.0.1 or http://192.168.15.1 or http://192.168.2.1 If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it. Then it ask for user name and password. Type user as "admin" and password as "admin" or "password" or blank. Then you can see configuration page of router. Then check the settings of router . Let me know if you need further assistance. Thanks for using FixYa.
Nov 09, 2010 | Linksys WRT54G2 Wireless Router
How do I find this router address
To leinartj.
1.- For install the Router, you don`t need the Router Address.-
2.- You only connect the Router to the ISP Modem and then you must to "Clon" in the Router the Mac Address of your computer.-
3.- So, You must to configure the Router.-
That`s all.
Aug 26, 2010 | D-Link DI 514 Wireless Router (DI-514)
D-Link Dlink DI-514 Air Wireless 2.4 GHz Router (A0177337) Logo
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
