Question about Garden
Ryobi 970R I am having trouble keeping the 4 stroke trimmer running. It will run with a slight touch on the primer bulb but will not stay running. Seems like the fuel needs a little extra pressure to get to the carb. I have replaced the gaskets, diaphram parts, primer bulb, filter & lines. Any other suggestions? Also how many turns out for the High & Low screws?
  • S. Wilson Nov 08, 2012
    Update: Still dies when i hit the throtle but it is close to running at idle. seems the low setting is around one & a half turns.
3 Suggested Answers
moretons
  • 155 Answers
SOURCE: ryobi trimmer sat for about a year or so, replaced
Hi sounds like the filter mesh inside the carby is blocked and the diaphrams may be hard and not pumping fuel
Posted on Sep 10, 2009
suzukiracing
  • 200 Answers
SOURCE: Craftsman weed trimmer primer bulb is working in reverse
Make sure the line is near the botto ofthe tank.Thanks you for asking and I hope it helps.Please leave me a 4 thumbs up.
Posted on Jul 20, 2010
My Ryobi 4 cyl 30cc leaf blower just quit starting. Has always started perfectly, but now it just wont start.
replace spark plug.if spark plug okay problem could be carburetor or air leak at fuel lines or check primer bulb for crack which cause air leak.any breaks in fuel line or primer bulb cause air leaks fuel system cause carb not get fuel run engine.
Sep 20, 2013 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
My Ryobi start great but when I change it from start to run stays few seconds and died
  • Alow the engine to run for longer on the start setting before you switch to run
  • Ensure air filter is clean. Foam elements can be washed with hot water and detergent. Paper elements can be cleaned with compressed air blown from the inside of the filter but ideally should be replaced.
  • Check fuel lines aren't kinked or blocked restricting fuel flow.
  • Ensure fuel filter isn't dirty. This is probably located at the end of the fuel line in the tank.
  • The fuel lines may have become airlocked.This can happen if the tank is run dry. If the trimmer has a primer bulb, alternatively press it several times and then try to pull start the engine with choke on. Repeat this several times. The primer bulb should feel spongy and fill with fuel.Once the engine kicks, switch to run.
Apr 05, 2011 | Ryobi Gas Hedge Trimmer
I have replaced my ryobi whipper snipper fuel lines and now it won't stay running. What have I done wrong?
I have had exactly the same experience, and then also replaced the primer bulb, messed around with the carby mixtures, but so far it will not run for more than about 3 - 5 seconds! I have yet to resolve this problem.
Feb 26, 2011 | Ryobi Garden
My TP30 Ryobi weed eater turns and stays on while
You have a hairline leak in one of your hoses or a small gasket under primer bulb.
Jul 05, 2010 | Ryobi Factory-Reconditioned 30cc 18" Gas...
Ryobi weedeater 4 stroke starts but only runs for a second or so I can get it to run but not well and I have to have some choke on to do it
We have a Ryobi gas weed eater. We can get it started but it doesn't stay on. I took it in to get it fixed and he said it was the primer switch, which he replaced, but we are still having the same problem.
Can you help us or refer us to a Ryobi repair store? We live in Phoenix, Arizona but can go to any repair store in Glendale, Tempe, Phoenix, Mesa, Scottsdale, wherever in Arizona. Thank you. Sally
Jun 02, 2010 | Ryobi Garden
I have a Ryobi 768R Gas Trimmer, I just replaced the primer bulb and gas lines and had it running fairly well. It stalled on me while I was adjusting it and I can't get it restarted. I'd like to know what...
sorry not familiar with the 768R is it a 4 stroke or a 2 stroke?
Starting points for the HIgh and Low on 2 stroke carbs is about 1 full turn out for each
May 11, 2017 | Ryobi Garden
My prime button broke can i bypass it
No, you cannot bypass it. Even if you could get it to run without the bulb there would be a significant chance of fire and injury. Replacement Ryobi primer bulbs are very common, you can get one just about anywhere...in fact, you can go to Google, put in Ryobi and whatever the model number is of your trimmer and the words primer bulb and you will get plenty of hits for parts companies that carry the replacement bulb.
Sep 15, 2009 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
I changed the fuel line going from the fuel tank to the primer bulb and now my weedeater will not stay running and my primer bulb is not holiding fuel.
Make sure the fuel line is a good fit to the carb. ... If is sucking any air at all it won't run right.. Also check that the fuel line in the tank is still hooked up...
May 20, 2009 | Ryobi Garden
Ryobi 31cc lawn trimmer carb adjustment
As with all 2 strokes if you have compression and a reasonable spark, you only need fresh fuel with correct oil ratio) and they must go !(as long as you haven't fiddled first and all gaskets are sealing) I start mine by(1) pumping the primer till it is firm,(2) full choke,(3) pull till it kicks ONCE,(4) half choke, pull till it runs,allow to warm up and(5) switch to run (you may need to apply a bit of throttle while pulling as in (4)(or give it a few more pumps if it dies) If all is ok, check that when properly warmed up there is a smooth transition from idle to full revs, if it hesitates it may need the LOW SPEED mixture leaning (clockwise) SLIGHTLY.If it dies the LOW SPEED mixture may need richening(anti-clockwise)(adjust 1/8 turn at a time) Make sure that motor is just peaking at full revs and is on the RICH side of peaking (HIGH SPEED mixture)(this will avoid seizing it Adjust both till it revs cleanly and is JUST rich at full, and idleing nicely and it should start without too much trouble.(If you have fiddled and are lost,-about 2 1/2 turns out from closed on both needles should get you started)
Nov 23, 2008 | Garden
Ryobi 725r 31cc
Ryobi is Japanese for "Piece of ****" My suggestion is to throw it out!
My 767r has had fuel line and carb trouble from day one. I'll never buy another Ryobi or Craftsman tool again.
Jun 13, 2008 | Ryobi 15" Electric Factory Reconditioned...
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
