Question about Locks & Locksmithing
How to reset combination on tioga watchdog lock when forgotten lock combo
Hubby thought he had set the combination but when he turned the reset dial it wont move
  • 38 Answers
SOURCE: How to reset EasyGo Travel Sentry 3-Dial Combo
well.maybe you should get a new lock because there is nothing to do with it
Posted on Sep 15, 2009
rsmith972278
  • 160 Answers
SOURCE: I have 2 master lock combination dial padlocks
Please click below and follow the instructions.
http://www.masterlock.com/faq/lostcombo.shtml
Best of Luck,
RSMITH972278
P.S. PLEASE RATE MY ASSISTANCE
Posted on Nov 29, 2009
  • 4 Answers
SOURCE: resetting my master lock
nokia6708
Posted on Jun 15, 2010
snowghost1
  • 784 Answers
SOURCE: i set my lock code
if the lock is locked up and the combo that you set it to is not working then I would say that there might be a problem with the lock itself. I would suggest returning to the store that you bought it from and exchange it for a new one. if you want to try and get the lock open - you can try and progress the numbers, since you already have a combo set, this is a little easier then if you didn't have a combo at all. try setting the lock to the combo that you selected, starting with the first number - rotate the first wheel to the next number and try the lock and then to the next number and try the lock, when you get back to your original number, go to the next wheel and rotate that one around to every number ( testing the shackle everytime you get to a new number )---- repeat this process for the next two number wheels,, hopefully this will work,, but again it could be a broken wheel and I would just exchange it for a new one and start fresh.
here is an example of progression --- 1973 ( combo set )
1974,1975,1976,1977,1978,1979,1970,1971,1972 --
1983,1993,1903,1913,1923,1933,1943,1953,1963,---
1073,1173,1273,1373,1473,1573,1673,1773,1873---
2973,3973,4973,5973,6973,7973,8973,9973,0973 ---
I just used 1973 for an example -- if you want a more exact progression chart tailored to your combo, just let me know and I can write it up for you.
c...
Posted on Jan 03, 2011
snowghost1
  • 784 Answers
SOURCE: we have a Passage-2 luggage
if you have forgotten the combo the only way to get the lock to open is to ' progress ' the combo wheels. since it is only a 3 digit combo - this will take anywhere from 15 to 40 minutes.
start with 000 then 001 then 002 etc... all the way to 999 ( but you will get the combo before 999 is reached ). after the combo is found, with the latch open push the lever to the to open position and set the new combo that you want.
c...
Posted on Jan 15, 2011
How do I can unlock dial lock
The master dial lock is the world's best selling combination padlock.The lock uses three digit combination of 40 numbers.allowing for 15,00 possible variations
.Follow these step to unlock dial lock. 25284217-gdc3ufgmlwaqnv2deqjxyac2-5-0.jpg With the Combination Step 1 Turn the lock until the numbers read right-side-up. Roll the left-most dial until the first number of your combination lines up with the scored hash mark just to the left of the dial.
With the Combination Step 2 Roll the middle dial until the appropriate number lines up with the number to its left. Do the same for the right-most number. Your three-digit combination should now show, left to right, lined up with the scored hash marks.
With the Combination Step 3 Pull the body of the lock away from the U-shaped metal ring without turning any of the dials. The lock will click open to expose a hook. The hook spins 360 degrees so that it can be placed onto, and taken off, luggage.
Forgotten Combination Step 1 Pull the body of the lock and the U-shaped ring away from each other to put pressure on the mechanism inside the lock. Pull the body of the lock away from its attachment, or, if the lock is not attached, apply pressure on the U-shaped ring away from the body of the lock with your fingers. Keep holding a firm, steady pressure.
Forgotten Combination Step 2 Roll the dial closest to the U-shaped ring slowly, while keeping steady pressure on the mechanism. The dial will get difficult to roll over three consecutive numbers, and one of those numbers will click. You should feel and hear this small click, and that is the first number to your combination.
Forgotten Combination Step 3 Repeat Step 2 with the middle dial, and then the farthest dial. Leave the dial set when you find the click, moving onto the next dial. The combination will reveal itself, letting you pull the U-ring away from the body of the lock.
Resetting Your Combination Step 1 Hold the body of the lock so that the numbers face away from you. Set the combination and release the U-shaped ring.
Resetting Your Combination Step 2 Turn the hook of the U-shaped ring counterclockwise 90 degrees until the notch on the stem of the hook and the hole on the body of the lock line up. Push the stem of the hook down into the body of the lock as far as it will go.
Resetting Your Combination Step 3 Turn the hook another 90 degrees counterclockwise while it is depressed into the body of the lock.
Resetting Your Combination Step 4 Roll the dials until you have your new combination.
Resetting Your Combination Step 5 Turn the hook 90 degrees clockwise and raise the stem out of the body of the lock. Turn it another 90 degrees clockwise and push it back into the locked position. The lock now uses your new combination.
Sponsored Links
Luggage Trolleys Supplier
Supplies Made to Order from World's Largest Supplier Base. Top Deals!
www.alibaba.com $0.01 Web Hosting
Scalable, Secure Web Hosting. Try Our Award-Winning Service Now!
www.hostgator.com/1Penny Rooftop Air Conditioner
low noise, high static pressure. Made in China, Inquire Now!
www.airconditionings.cn Download Facebook Apps
Get The Most Popular Apps For The Largest Social Network. Join Now!
www.facebook.com by Taboola
Sponsored Links
Move Over, Turkey: 9 Side Dishes that Will Steal the ShowKraft Recipes See Another Side of Dubai in HattaDepartment of Dubai Tourism & Commerce Marketing by AFAR
Email Best Practices: Sending Emails That Won't Be IgnoredRackspace
TIP
  • Email yourself the password to your lock, and title the email "Luggage Lock." If you forget the password in the future, simply search your email for the term "Luggage Lock."
WARNING
  • Do not open a lock that does not belong to you. It is against the law.
REFERENCES
RESOURCES
ABOUT THE AUTHOR Christopher Michael began writing in 2004 for his college newspaper. He received a Bachelor of Arts in English and psychology, as well as a certificate in criminal justice from the University of Massachusetts, Amherst.
PHOTO CREDITS
  • Creatas/Creatas/Getty images
Suggest an Article Correction
How to Open a Combination Lock on a Samsonite Suitcase
  • How to Reset the Combination on an American Tourister
  • Airline Rules on Locked Luggage
  • How to Reset a TSA Lock
  • Reagan Airport & Luggage Storage
  • How to Prevent Lost Luggage
  • Cost of Shipping Luggage Ahead to Destination
  • How to Repair Wheels on Luggage
  • The Odds of Losing Luggage
  • How to Make Inexpensive Luggage Tags
  • Solutions to Lost Luggage in Air Travel
  • How to Measure Luggage
  • How to Expedite Lost Luggage Claims
  • What Are the Dimensions of Hand Luggage for Air France?
  • What Rights Do I Have If My Luggage Is Lost?
  • How to Store Luggage While Traveling in Italy
  • pixel.gifHappy Camper: Test Your Outdoors Knowledge
  • pixel.gifCruisin' Along the PCH: Test Your Knowledge
  • pixel.gifWhich U.S. Landmark Would You Be?
  • pixel.gifCan You Pass for a Proper Brit?
  • Nov 15, 2014 | Lands Phones
    How do I set up a Master Lock Key Safe with a new code
    Open the box, with the existing combo, push the reset lever to the left and down, dial in your new combo, push the reset lever up and right to set.
    Oct 04, 2014 | Master LOCK 5401D Combination Key Safe...
    I have a 418-392 Brinks combination lock and don't have the combination
    I have the same lock and a forgotten combo. Did you ever find out how to get it open and reset?
    Jan 03, 2014 | Brinks 1-7/8 In. SS Dial Combination Lock
    Forgotten combination dial lock
    hi,
    on the back of some of those dial combo locks there are small numbers stamped in the back ~~ with those numbers your local locksmith shop can look up the combo for a small charge.
    chris...
    Sep 10, 2012 | Brinks 1-7/8 In. SS Dial Combination Lock
    Have just purchased an 8mm Tioga resettable combination bike lock but stupidly threw the packaging with instructions on how to reset the combination... currently set at 0000.
    I realise this is an old question, but...
    Open the lock with the default combination (0-0-0-0)
    At the insertion point you will see a raised ring to the right of the numbers. Turn this part clockwise (it has an arrow on it). Set the combination you want. Turn the ring back, anticlockwise. All done!
    Sep 15, 2011 | Tioga Cycling
    How do I reset a 4 dial Samsonite combination lock
    Hello sstacy1,
    You can follow the steps below to fix your problem on how to reset your 4 dial Samsonite combination lock:
    1. Set the dials to 0-0-0. Find the lever or button next to the dials.
    2. 2If your lock has a lever, lower it and turn the dials to the desired numbers. Return the lever to its starting position.
    3. 3For locks with a button, push the button towards the dials and turn them to the desired numbers. Release the button.
    4. 4The lock is now set to the new combination.
    Read more: How to Reset Samsonite Luggage Combination Locks ' eHow.comhttp://www.ehow.com/how_4761466_reset-samsonite-luggage-combination-locks.html#ixzz157Q4Ap
    Hopefully it helps.
    Thank you for using fixya
    Sep 08, 2011 | Health & Beauty
    I lost the instructions and don't know how to unlock using "original code" and how to create a new code
    try all zeros Kryptonite locks come preset to zeros once unlocked there is a small lever inside were it locks together pull it down and set your new combo then push it back up
    Oct 17, 2009 | Kryptonite Kryptoflex 1218 Combo Cable...
    I dont know how to open the lock its brand new????? They failed to give me instructions when they attached to the bike
    My new lock didn't come with any instuctions. I followed the link above and located the "bike locks" heading. I found that the question:
    - I have a Kryptonite resettable combination lock and can't find the instructions for resetting it. How can I change the combination?
    contained a pdf titled :
    - Resettable Combination Cable
    (red reset buttons inside)
    which is not the cryptoflex 1218 but is compatible anyway.
    dont hurt your fingers trying to depress the nodules as the diagram says though. to my chagrin i discovered that they will turn easily if you just push them around into place.
    here are the instructions:
    To set your own combination
    Your new lock is preset to open at 0-0-0-5 at the factory.
    1. Open the lock by aligning the opening combination
    number to the Guide Points and pull out the Lock
    Post. (Figure 1)
    2. Push down the two Reset Buttons simultaneously
    with thumb and forefinger, and turn counterclockwise
    until it comes to a stop. (Figure 2)
    3.You are now ready to turn the dials to set your
    secret combination, such as a phone number, birthday,
    etc.
    4. After setting your secret combination, turn the
    two Reset Buttons again by Thumb and Forefinger
    clockwise until it comes to a stop and back to its
    original position.
    5. Verify your new combination before using your
    lock. Insert the Lock Post all the way into the Locking
    Port but do not turn the dials. Pull out the Lock Post.
    Your lock is ready to use.
    6.The reset operation is now complete. Repeat
    steps 1-5 anytime you wish to change your secret
    combination.
    Oct 11, 2009 | Kryptonite Kryptoflex 1218 Combo Cable...
    We threw out the info that came with our new trek combination lock. now we have no idea how to open it or to reset it.
    Try this....
    Post. (Figure 1)
    etc.
    original position.
    combination.
    Sep 16, 2009 | Kryptonite Kryptoflex 1218 Combo Cable...
    Locks & Locksmithing Logo
    222 people viewed this question
    Top Locks & Locksmithing Experts
    ray gallant
    Tom Chichester
    Are you a Lock and Locksmithing Expert? Answer questions, earn points and help others
