Question about Ace Hardware Electrical Supplies
Where is the hex wrench spot on the badger 5 model 5-81 i cant seem to locate where it is
  • Ace Hardware Master
  • 5,245 Answers
11-2-12
If unit has slot, then it's located on very bottom in center.
Or use a broom.
http://waterheatertimer.org/images/Broom-inside-disposal-350.jpg
Copy following link for steps troubleshooting garbage disposal:
http://waterheatertimer.org/How-to-repair-and-install-Garbage-disposal.html
Posted on Nov 02, 2012
SOURCE: Badger 1/3hp g disposal humms but does not grind
I just logged on to find an answer to the same problem as anna568. Help!....pushed reset and Badger hums
Posted on Dec 03, 2009
  • 3 Answers
SOURCE: I have a badger 5, model 5-81 and it does not
be sure you have 110v if its a 110volt unit sometimes when dropped they tend to lock up run some water and see what happens no results return product
Posted on Apr 12, 2010
  • 102 Answers
SOURCE: InSinkErator Badger 5, 1/2 HP Garbage Disposal: It hums but doesn't work. The wrench moves freely ...
If the blades move freely with the wrench and stick and motor hums then it sounds like it is time to replace the unit. Have you tried the reset switch? If it is humming than it is probably not tripped but worth a try. Hope this helps.
Posted on May 25, 2010
  • 760 Answers
SOURCE: Insinkerator Badger 5 - Does not turn, just hums.
If it turns freely with the hex key, but won't start,without help, you probably have start winding switch problems. As these are not very expensive, I would buy a new disposal. You can purchase a 3/4Hp for near 100.00 , so it isn't worth spending a lot of time on an old one, especially if it is older and corroded.
Posted on Oct 01, 2010
woobie dog
  • 1273 Answers
SOURCE: badger 5 spins freely with wrench, but not with
Hello,If pressing the reset button on the bottom doesn't get you going, you may have to replace the unit. If the hammers on the inside can be operated with the hex wrench, and you have a good power supply (you do, don't you?), then the unit is most likely burned out.
--_W/D--
Posted on Jan 28, 2011
Testimonial: "Thank You very much. I kind of figured it was the motor. Kind of surprising, unit is only 4-5 years old. Thanks Again"
Badger 5-81 motor buzzing, blades spinning, won't grind
Replace the whole thing. They are not that expensive and are easy to replace. The issue could be bad motor part or the shaft came loose from the grinding disk.
Jul 09, 2017 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
In sink erator model I-81 not working.
Stick the end of a broom stick down in and try to un-jam the blades by spinning them. sounds like there is something stuck in there.
Jan 05, 2012 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
BADGER DISPOSAL UNIT 5-81 SEEMS TO WORK, IT'S NOT STUCK BUT THE WATER WON'T GO DOWN IN THE SINK. ANY SUGGESTIONS.
Clean out the p-trap and tubular drain under the sink:
I wrote ez disposal replacement steps that cover how to take apart tubular drain pipe and put it back.
http://www.fixya.com/support/r7929008-replace_garbage_disposal
Jun 11, 2011 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Garbage disposal humming won't turn
Look on the bottom of the unit there will be a hex set screw 1/4 inch they should have given you this wrench with the disposal . With the water running turn this set screw it will unjam it and fix the problem
Feb 09, 2011 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Badger 5 spins freely with wrench, but not with power.
--_W/D--
Jan 28, 2011 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
The blades on my Badger 1 insinkerator don't move. The motor hums when turned on. The reset button stays out when pushed.
You will need to free the blades by inserting the food disposal hex key or a 1/4 Allen Wrench into the very bottom of the disposal in the center. After inserting the wrench you need to turn it all the way in both directions to free what has the blades held up. It may be hard to turn but afterwards pull the debris out from inside the disposal. Hit the reset button and it will work. Do not keep turning it on until you free the blade and then reset.
Jun 28, 2009 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
My Badger 5 garbage disposal will not work. It makes a humming noise but will not spin. I hit the reset button, used the hex wrench provided and turned it clockwise, used a broom handle through the top and...
I had this same problem after my wife tried to clean out a fish bowl (she said she skimed out all of the little pebbles). She still missed a lot of them and many ended up in the disposal. Anyways it made the same humming sound when turning it on. This humming noise means something is jamming it from spinning. The hum is just the sound of the motor trying to spin (DO NOT LEAVE IT HUMMING FOR A LONG TIME)
HERES HOW TO FIX IT:
-If you have a lot of whatever's causing the jam still in there, I suggest you take out the disposal and flush as much as possible out with water (I had to do this to get majority of the rock pebbles out) while holding it upside down.
-Now you need a decent tool set, get a 3/8" ratchet, 7/16" deep socket, and a 3" extension.
-It's easiest if you put the disposal back in the sink to do this step as it may take some muscle and the sink will hold it in place.
-If you look down into the disposal from the top of the sink you should see a nut in the middle of the disposal (and the 2 silver spinning teeth on the sides).
-The nut in the middle is what you need to get the ratchet on.
-Now just muscle the ratchet clockwise for awhile then counter-clockwise for awhile and repeat if necessary until the rotor spins completely freely. When there is completely no reistance when turning it you are done.
-Pull the ratchet out and try turning on the disposal. If you did the above step correctly then if should turn on like normal.
Congratulations you just saved yourself from calling a plumber!!
Apr 17, 2008 | Badger Basket 1905 Round Doll Bassinet
Electrical Supplies Logo
139 people viewed this question
Top Ace Hardware Electrical Supplies Experts
handygirl911
handygirl911
Craig Butler
Craig Butler
Mike
Are you an Ace Hardware Electrical Supply Expert? Answer questions, earn points and help others
