F36650 36 Hi Benimur... I'm new to this website, and managed to loose your answer to my problem with LP03, and the Flyback xformer. You said to do a forward and reverse check of the HOT or Horizontal output transistor? and the FBT, what is the FBT? I have not made a living in elctronics in 13 years, and this is my first venture inside a TV. Thanks mjknfun
    Brigadier General:
  • 6,966 Answers
Hi again,
Appreciate the direct "Ask Me"
To your unit RCA F36650/CHASSIS # ATC113CA1, I posted replies to your original problem here.
FBT would be the FlyBack Transformer or Line OutPut Transformer (LOPT).A ring test is check for the FBT out of circuit using an instrumentthat sends pulses to the FBT's primary circuit. Thereafter a comparatorcircuitry checks the number of damped oscillations or 'rings' producedand determines if the primary is good or not.
Incidentally, it could also be the power supply unit (PSU). You could verify by doing the check on the HOT or lifting the supply to the main B+ going to the FBT and trying it. It the PSU powers up and the light lits as well as the sound comes up, the PSU is good and HOT/FBT is suspect.
You might be better off getting hold of a service manual or at least a schematic diagram.
Incidentally, 13 years is a rather long time in electronics with the technology changing at such a fast pace. 13 years ago we still have a few Betamax and laserdisc players especially those by Pioneer.
Cheers.
Posted on Jan 04, 2009
Sony KV25X5D CRT TV. When turned on the screen remains black, no sound. Red led flashes 2 times.
Service manual: http://raoul.foucault.free.fr/docs/SONY%20KV-25X5.pdf
This ia an old CRT TV, THERE IS NO POWER SUPPLY BOARD BY ITSELF that you can buy! I sure like to see this 'POWER SUPPLY BOARD' from TVPARTSANDMANUALS.COM!
The main board has power supply, controller, Flyback xformer, etc.
You need to do in-depth troubleshooting, check the H.O.T, Flyback xformer, caps, etc.
Dec 13, 2010 | Televison & Video
Dragon NaturallySpeaking 9 preferred will not work, Microsoft Excel
i do not understand your problem, can you please reexplain
Nov 29, 2007 | Computers & Internet
A red blue and green line jus appeared across the screen of my 55 inch rca floor model big screen. instantly my picture and color become distorted
conversions are out....rca ... check for bad connections on circuit board around fryback xformer. check fuse by flyback xformer...fuse is shaped like a little plastic rectangle>>fuses should measure a SHORT when GOOD! Flyback Transformer is large in size and sends highvoltage to 3 picture tubes via a SPLITTER . easy to locate
May 19, 2010 | RCA R52WH73 Projection Television
Picture out of foucs
HIGH VOLTAGE WARNING - open the tv and on the flyback Xformer, there should be a knob that is labeled FOCUS try adjusting it. the flyback has the red wire on top that goes directly to the the top of the picture tube.
Jan 11, 2010 | Televison & Video
I intermittantly loos pickture never loose sound. Picture goues black for a split second and then comes back on.
I would check the flyback transformer on this unit something tells me that might be the issue your having. Warning tho if you do not know how to repair this TV check it into a shop as the flyback transformer has high voltage and could be fatel up including death if handle the wroung way.
I thank you very much for your free questions and do hope I was Very Helpful in your free answer today please do leave postive feedback and ratings for your free answer today.
Dec 07, 2009 | Mitsubishi WS-55809 55" Rear Projection...
Burning oil-no visible leak. Seems as though engine is loosing pressure. sputtering from exhaust pipe. No smoke coming from pipe except on occassions when you hear a rattle and the car loose pressure then...
For some reason the Live Session froze. Our apologies for any inconvenience. Please find below the last part of my posts in case you were not able to view them.
photo7 says:
what about the piston rings
Benimur says:
that could be checked with a compression tester at your dealer
Benimur says:
so for the moment course of action would include: compression test
dye to determine where the oil went, if no trace found then it could be assumed was burned; change the catalyctic converter, it went as a direct result of oil in the exhaust system
Benimur says:
some remedial/temporary workaround includes installation of an aftermarket oil cooler with its own fan; maintain a lower engine temperature by removing the thermostat (not applicable to cold regions) and wiring the radiator fan to continously work.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Jul 28, 2008 | Toyota Corolla Cars & Trucks
Rca 36" f36650
Usually the horizontal output does become shorted when the flyback goes. I would replace the H output as it only cost around 3 dollars. You can check it with an ohms meter out of circuit to determine if it is indeed shorted or open.
Mar 19, 2008 | RCA F36650 36" TV
High Pitched noise returns after new parts installed.
Use first quality OEM or equiv. transistor, RCA 237470 is
least expensive...............T.
Nov 09, 2007 | RCA F36705 36" TV
Clicking sound coming from my projection TV RCA Model P46921 year 2000
Bad Flyback xformer = P46921YX1 Part # 239111
P46921YX4 Part # 250694.....................................T.
Apr 14, 2007 | RCA P46921 46" Rear Projection Television
Won't turn on.
Bad flyback xformer AKA IHVT.
Dec 17, 2006 | RCA F36665 36" TV
Televison & Video Logo
120 people viewed this question
Top Televison & Video Experts
