Question about GE GDS18LBR Bottom Freezer Refrigerator
Fridge not cold - freezer cuts out at minus 10 degrees.
Hotpoint FFM90 - The fridge compartment does not get cold. On initial switch on the compressor starts and the display flashes indicating that it is cooling down to the set freezer temperature. The freezer compartment only cools down to minus 10 degrees then display shows the defrost simbol and cools no further.
The evap fan works and there is no ice build up on the cooling coil.
    Prodigy:
    An expert who has answered 500 questions.
    Sergeant:
  • 531 Answers
Check damper control
Posted on Apr 03, 2009
I have a hotpoint FF72P fridge freezer. it comes down to temperature (-22/+4) without any problem, but after this the compressor won't cut in.
takes time for the temperature inside the fridge -freezer to normalize after doors are being left open
turning off a fridge freezer on and off wont help it
it takes time to for the thermostat to kick start the compressor
and more time to reach the freezing temp lost
if you are certain the thermostat is damaged
call in a service man
have the thermostat replaced and have them check
the gas in the system is running the correct pressure
Jul 31, 2016 | Hotpoint Refrigerators
Freezer turns of in cold weather
Many residential refrigerator / freezers are designed to work at temperature considerably above above freezing. Most modern refrigerator / freezer have a single electric thermostat - located in the fresh food compartment. This lone thermostat will control the compressor to keep the fridge (fresh food) section at the desired temperature (usually between 34 - 38 degrees F). The freezer will get colder regardless of how cold it is already whenever the fridge thermostat turns the compressor on.
Now that you see how the thermostat works, let's look at what happens when the fridge is placed in an unheated space - like a garage. In winter time, the temperature can drop considerably below 38 degrees. If the outdoor temperature remains cold enough, for long enough - it will affect the thermostat in the fridge. The temperature inside the fridge could drop below 38 degrees, preventing the thermostat from telling the compressor to turn on. Meanwhile, the temperature in the freezer compartment slowly rises from the normal -10 to 0 F degrees. It will continue to rise until it is the same temperature as the fresh food compartment or until the thermostat in the fresh food compartment tells the compressor to turn on again. This means the freezer contents will thaw.
If the temperature in the garage is even in the 40 to 50 degree range, the loss of cold in the fridge may not happen often enough to keep the compressor coming on often enough to keep some freezer items frozen solid - such as ice cream. Remember, water freezes at 32 degrees F, other products may require lower temperatures to remain frozen, and could thaw at 28 or other temperature.
Feb 13, 2012 | Refrigerators
Have temp gage almost to 9 (per instructions to make warmer ) but still at 33 degrees F. need to make warmer
the freezer cools the fridge side so if you open the air flow up going in to the fridge it will only get colder. so cut the air flow down low and it should warm up. this causes the freezer to get cold quicker too because there is more cold air available in the freezer so it cuts off the compressor sooner.
think about how it works. if you doing everything right then you need to listen to be sure the stat is cycling the compressor or does it never get cut off by the stat.
Dec 31, 2010 | Hotpoint Refrigerators
This unit is used in a garage as a 2nd unit. It
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Dec 26, 2010 | Whirlpool 25.2 cu. ft. Side-by-Side...
Ice is forming in the bottom of the freezer compartment of my hotpoint FFM90 frost free fridge/ freezer. Please help. Many Thanks
Had exactly the same problem.
It was due to a blockage of the drain.
At the back of the freezer there is the pump and there is a small darin that lets condensation from inside the freezer spill onto the top of the (hot) pump to be evaporated. When this small drain blocks it causes issues like water leaking out of freezer and big chunks of ice at the back of the bottom compartment.
The fix is easy, if a little laborious.
Take all the stuff out of the freezer, then dismantle the internal plastic trip, don't worry, you can't really break anything and it goes back together easily, Eventually you will be left with just the bare metal insides and in the middle at the bottom back you will see the drain collection point, slightly hidden from view is the drain hole. Pour warm water onto this till it comes out onto the pump at the back.
Then use a pipe cleaner to clean.
Re-assemble - done :)
Oct 15, 2010 | Hotpoint FFM90 Bottom Freezer Refrigerator
Ffa97 problems why is fridge compartment is freezing any food that is at the back
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Aug 27, 2010 | Hotpoint FFM90 Bottom Freezer Refrigerator
Hotpiont ffm90 fridge not chilling
hi if the freezer appears to work and the fridge if warm,the problem is that the freezer is over frozen and blocking the vents which send cold air into the fridge when required,and the noise is the fan hitting the the ice build up,defrost (switch off)your applinace for at least 36 hours then switch back on,you will then find after the freezer reaches -12 the fridge will then start to go cold.
Mar 09, 2009 | Hotpoint FFM90 Bottom Freezer Refrigerator
Fridge Freezer very noisy!
cycling every 30 mins is normal. bear in mind that frost free are more noisy as there are fans running as well.
you appear to have temp in freezer too high - should be -18degC
Oct 11, 2008 | Freezers
FFM90
hi The limit switch is found only on frost-free refrigerators and freezers. Its function is to keep the defrost heating element from exceeding certain set temperatures. If a refrigerator has lots of frost in the freezer compartment, the problem may be the limit switch. However, other components -- the evaporator fan, the defrost timer, and the defrost heater -- can cause the same problem. Check these for malfunctions, as detailed below. If these parts are in working condition, the problem is most likely in the limit switch. Don't try to fix the limit switch yourself; call a professional service person for replacement.
Sep 14, 2008 | Hotpoint FFM90 Bottom Freezer Refrigerator
Fridge part of fridge freezer not cooling
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
heatman101
Aug 16, 2008 | Hotpoint FFM90 Bottom Freezer Refrigerator
GE GDS18LBR Bottom Freezer Refrigerator Logo
359 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
RepairNinja
RepairNinja
