Question about RTO Toys
MY 49 CC SCOOTER WONT GO OVER 10 MPH IT BOGS DOWN BACK TO IDLE
SCOOTER STARTS FINE IDLES FINE BUT BUGS DOWN WHEN I GIVE IT SOME THROTTLE
  • 3 Answers
SOURCE: poor idle and bogs down when more throttle is given
coil pack
Posted on Mar 23, 2009
joecool1888
SOURCE: car bogs with full throttle
Its the Fuel Filter...mine did the same thing :)
Posted on Apr 26, 2009
  • 43 Answers
SOURCE: no power
Keep changing parts until you find the solution! No, just kidding. Many will do this if they don't understand how an engine works. It sounds like it may be a hung choke. Engines need extra fuel when cold, and die when warm if they are still getting that extra fuel. Also, low oil level will give the same indication. There are many variables.
Posted on Dec 31, 2009
SOURCE: my klf 300 intermitently bogs down like full choke
GRANTY
Posted on Jan 02, 2010
dmsr63
  • 2050 Answers
SOURCE: weedeater featherlite 25cc. runs fine for 10 mins,
I just fixed one of these. Starts, but won't throttle up, sounds labored.
I checked compression, exhaust for carbon build up, spark, and even the carburator for bad gummed up gas. All were fine.
What I did to fix it was...
You need to remove the high and low speed adjustment screws on the Zama carb. They are blanks, and have no slot for a screw driver. I used a roll pin that the inside diameter fit snug on the outer diameter of the ajustment screw head, and turned it with a pair of needle nose pliers. I remove them (One at a time) and cut a slot in the head with a hacksaw, to allow for future adjustment. Back them both out one full turn from seated, and then tweek to get it to run. The low speed is for idle (Out to richen), and the high speed is for wide open throttle. It's closest to the air filter.
Posted on May 05, 2010
My 50cc kymco scooter starts but when you pull the throttle back it cuts out
Hi, Christopher and the usual suspects are:
1. Idle circuit and transfer ports clogged.
2. Air fuel mixture adjustment too lean.
3. Pilot jet clogged.
4. Faulty accelerator pump.
5. Float level too low.
6. Float bowl contaminated old fuel, water, dirt, rust, etc.
7. Float bowl vent or overflow tube clogged.
8. Fuel flow to carburetor restricted.
9. Intake manifold leak.
10. The gas cap is not venting properly or fuel tank venting system blocked.
11. Vacuum line from intake manifold to petcock broken, cracked, or not attached, carburetor vent line plugged.
12. Needle and seat stuck closed in the float bowl.
For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have nice a day.
Bike idles perfect but dies when given the slightest amount of throttle 93...
starts idles stalls giving gas Scooter Doc Forum
scooter dies if give it throttle
http://www.scootermasters.com/manuals/kymco%20People%2050-complete.pdf
Aug 27, 2016 | Kymco Motorcycles
My kymco 50cc starts but when you go to throttle it it cuts out can you help
Scooter shorts out while runing
possible throttle pot failure.
Aug 23, 2014 | Health & Beauty
Car starts fine idles fine wont rev up wants to stall if you give it gas
Could be the throttle position sensor, or low fuel pressure.
Feb 25, 2013 | 2000 Toyota Corolla
Honda Metropolitan throttle is stuck
Throttle should be replaced.
Aug 11, 2012 | Motorcycles
My velocity 49cc scooter starts and idles fine but when I give it throttle it boggs down
Sounds like a fuel problem. Check the fuel filter, tune or rebuild your carburator.
Thats just possabilities of course...
Apr 14, 2012 | Cars & Trucks
Scooter Open Throttle (?)
Assuming the bike is not fuel injected, you either have a stuck slide, a throttle cable out of place such that it is lifting the slide or a really bad manifold air leak. Tighten the clamps holding the carb to the cylinder and the bolts holding the manifold to the cylinder. That should eliminate any air leaks. Inspect the throttle cable, especially at the ends where it connects. Remove the air filter and look into the center of the carb. Does the slide in the throat of the carb open and close properly? Below is a generic carburetor. Your carb will be similar.
Jun 30, 2009 | 2005 Qianjiang QJ100-2
Toys Logo
296 people viewed this question
Top RTO Toys Experts
The Scrivener
Pete Bruk
rostit
Are you a RTO Toy Expert? Answer questions, earn points and help others
