Not using the cold water cycles even though it is chosen for the wash. both the hot and cold water fawcets are on. the washer is ONLY using the hot water. please let me know why that is happening
SOURCE: Kenmore 70 series washer won't fill during rinse cycle
It appears your timer/main controller has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
SOURCE: kenmore elite washer
sounds like you have a bad water valve,,either that or a bad water temp select switch,(doubt that). way more common is a bad water valve.
SOURCE: kenmore top load washer - the cold water temperture does not work
It appears your dual inlet water valve or timer(CCU) has failed in this instance.
SOURCE: I have a kenmore Elite Oasis Top Loading Washing
Hi
This issue can either be due to the suspension rings or due to motor issue. Please check this link for exploded diagram of your washer---
Kenmore Elite Top Load Washer 110.28032701 Diagram
Also, check the stator motor and the retainer, make sure no parts are missing. Hope this helps... Please post back if you need more information.
Daniel
