Question about Hitachi Televison & Video
Can you use a universal remote to do the convergence on a hitachi 50vs69a tv?
We misplaced the original remote i have a universal that turns the tv on and off and can change chanels but am not able to get to the convergence menue
    Top Expert:
  • Hitachi Master
  • 14,553 Answers
No, but almost any hitachi remote will do that--problem is on different remotes different buttons do different things in the digital convergence mode.
Posted on Nov 02, 2012
johnnydiode
  • 647 Answers
SOURCE: my hitachi 50vs69a tv wont turn on and after afew blinking red li
Have you replaced the lamp? Unplug the set remove the lamp and see if it's blown
Posted on Sep 20, 2009
TMurdock
  • 93 Answers
SOURCE: Change from TV mode to AV mode for a Hitachi C28W4110SN
There should be buttons somewhere on the TV itself to switch input modes. Look around where the power button is located and see if there is a menu button you can access. Then use channel up/down and volume up/down to scroll thru modes to find input
Hope this helps
TankMurdock
Posted on Apr 27, 2009
ladywinn
  • 5138 Answers
SOURCE: how can i access the menu to adjust picture without the remote
On front of TV Press and hold vol- and vol+ together menu should apear then.
Posted on Jun 11, 2009
  • 3 Answers
SOURCE: Hitachi 50GX30B I need to align Digital Array no original remote
Unfortunately, it looks like you will need the original remote. I found one at www.remotes.com Give it a try. Good luck.
Posted on Feb 18, 2009
johnnydiode
  • 647 Answers
SOURCE: My hitachi 50VS69A tv shows the picture green.
A green image is usually due to a lack of red or especially blue. the problem is becoming all too common with hitachi lcd projection sets. what happens is that one of the lenses in the optical block (or light engine) starts to burn or discolor due to overheating because of a blocked air filter causing poor air (cooling) circulation. Nothing can be done when the damage is too far gone except to replace the light engine-at acost that makes it not worth repair. if the damage is minimal than to reduce further damage the air filter should be replaced. Light engine needsto be removed in order to replace the air filter.
How to work the hdmi
how do you set up the HDMI input on a hitachi tv model #51F59A ...
https://answers.yahoo.com/question/index?qid...
Jan 8, 2010 - i tried to hook up an HDMI devise but i cant set it on input HDMI it ... My TV has HDMI, Component and AV inputs, which one should i use for my ...
HDMI not working - Hitachi 50VS69A - AVS Forum ' Home Theater ...
www.avsforum.com/.../948284-hdmi-not-working-hitachi-50vs69a.html
Dec 1, 2007 - 7 posts - ‎2 authors
I have a Hitachi 50VS69A 50 RP LCD HDTV connected to a Dish Network receiver that the HDMI input is not working on. I have been using the ... Hitachi P50H401 - all HDMI ports are dead - HELP!
Oct 2, 2008
Hitachi 51/57/65F59A CRT RPTV Tweaks Thread
Jan 19, 2007
More results from www.avsforum.com
Dec 27, 2015 | Hitachi CLE-960 Remote Control HL02121
Picture in picture Mode will not turn off
Your universal remote control does not have the PIP control feature of the original.
Jan 01, 2018 | Hitachi Televison & Video
What is the procedure to do color convergence on a hitachi 50vs69a
Almost all you can either get into the mode by use of the remote or remove front speaker grill and inspection plate behind it, there is a tiny blue push switch which will put you in the convergence adjustment mode, then various buttons on the remote do different things and save the adjustments.
Of course if convergence will not adjust you have a bad chip and this model uses two so both get replaced in that case.
Aug 27, 2012 | Hitachi 50VS69 50" Projection HDTV
I lost the remote to my Hitachi TV and I now can't
Buy one universal remote control, and set it with your TV. It will be best. If you want to get its original remote control, you have to contact the nearest authorised service center for Hitachi.
Want more details about selecting a substitute universal remote control? Check the setup codes for Hitachi, and buy one universal remote control, which has setup codes.
Visit this site for more details. Type in the site name "Electro-help" either Google or Yahoo search box [not in the address bar of your browser], and click search. It is an electronic equipments service help site. All details you want are there. Note the position of hyphen in between words in site name, when you type it in. The site will appear as it is in web; subtitled as service help to electronic home entertainement equipments.
Pull up older posts. You can get all details.
Check associated ads too. Sometimes, it might help you.
May 29, 2012 | Hitachi Televison & Video
Can a hitachi convergence be fixed without a remote? seems like red is adjustable, but cannot access the blue line with our universal remote
Ur universal remote was able to move - + from the convergence grid wright,it is a good remote.The tv convergence board is dead.The tv convergence board the 2 STK convergence ICS and some or all of it resistors are dead too.These parts must be replaced on the tv convergence board to solved the tv pictures convergence problems.The shop,will cost u like $300-350 for parts and labors.
Dec 19, 2010 | Hitachi 43FDX01B TV
Convergence
It depends on what kind of convergence problem you got & what kind of universal remote you are using. If you mean aligning the crossline some
universal remote can be used to align the colors & on most TV you don't have to save it. Otherwise it will tell you what to do. If you are talking about aligning the convergence by accessing the service menu, you need the original remote control. Of coures this procedure is ONLY for the experience
technician. Good luck. AstroTech
Jun 02, 2009 | Hitachi 60DX10B 60" Rear Projection...
Hitachi projection tv
Solution:
Your TV has a convergence problem. Here are some of the most common symptoms.
Screen looks 3D
One or more colors can't be adjusted when using the convergence menu.
Screen is bowed in but stationary.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence or magic focus section
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
You can get a repair kit that includes all the parts from www.TvRepairKits.com.
They have put together a kit for the Hitachi TV sets.
The kit includes a photo instruction guide, original Sanyo STK chips, convergence resistors, etc.
Everything you need to fix it yourself. Its a fairly easy fix on the Hitachi sets.
Dec 29, 2008 | Hitachi 61SDX01B 61" Rear Projection...
When i turn on tv the screen is turning green
Solution:
Screen looks 3D
Dec 11, 2008 | Hitachi 53FDX20B 53" Rear Projection...
Have a hitachi rear projection 50" TV (model# 50EX12BA). The screen gets dark when it gets dark in the room where the TV is (but it brightens if a light near the TV is turned on). Also, the colors...
From what i can find, you need to adjust the convergence of the individual projectors. One person said you need to adjust them once a month for optimal conditions, but also said once a year will suffice. I have an extra blue image, and although i was able to clean i dont know how many years of grime off the lenses and the mirror, i lack a remote that will operate the menu. I only have one universal remote by RCA that will operate the channels and volume, but not the input (im using S video input) nor the menu functions. You may have to buy a Hitachi remote (1-800-Remotes wants $40 for it), but i will try to get a better universal one and will post back if i have success.
A.J.
Nov 03, 2008 | Hitachi Televison & Video
Need a remote code that actually works!
I have never been a big fan of the universal remotes , but most of the times they do at least turn the tv on . You could possibly have a bad IR as well to . Whats your model # of the tv and what type of universal remote are you trying ?
Dec 29, 2007 | Hitachi 46W500 46 in. TV/DVD Combo
Televison & Video Logo
152 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
