Nordyne Furnace Gl 1RC 100D 16B. Limit Open, or external load on W
5 Suggested Answers
Therinnaiguy
  • 1420 Answers
SOURCE: code: open upper limit on a 1 yr old Goodman furnace
The sensor over the flame has tripped. It will need to be replaced or check for a disconnected wire.
Posted on Oct 11, 2009
Testimonial: "thank you, do you know of a good plce to get a sensor. I saw the sensor looked okay no wire disconnectd so it must be bad"
billyvangogh
  • 108 Answers
SOURCE: miller furnace model M3RL080 BW, code flashes open
Check your furnace filter any Limit fault code usually relates to airflow...Not enough...causes the furnace to run too hot and shut off....the furnace can be too big for your house if its new...the ductwork can be too small , also make sure your return air vents are clean and unobstructed . Your furnace can be running too long a cycle ....also if you have central air conditioning the coil for the AC in the Furnace can be dirty...restricting airflow...if all this seems ok you can usually increase the fan speed or try tunning the fan in the "On" position on your thermostat this will promote better circulation
Posted on Oct 25, 2009
Therinnaiguy
  • 1420 Answers
SOURCE: Does the Nordyne gas heater have a pilot light
The easiest way to really know is to open up the unit and find the gas valve. If it has a round knob that has "On", "Off" and "Pilot" stamped on it , then yes it has a pilot. If it just has an "on" and "off" switch, then it it has electronic ignition and the glow bar may be burnt out. Hope this helps.
Posted on Jan 18, 2010
  • 2597 Answers
SOURCE: LOOKING FOR INSTRUCTION FOR GAS FURANCE NORDYNE
nordyne have there own wed site google your furnace or nordyne info is all there
Posted on Jul 14, 2010
I have a nordyne furnace model # e3eb-017h. Furnace doesn't kick on at all. No relay click or anything but it's getting power. Did the thermostat trick with touching wires together to kick on the furnace...
Check the pilot light sensor. Have seen this issue before. Sometimes after lighting need to hold it in longer. If it doesn't detect the lit pilot wise it will sit in safety shut down mode
Oct 28, 2014 | Heating & Cooling
Why is my heater coming at the same time my a/c is on
Check your limit switches by ohming across the swtich and u should get a reading if not it is open. The limits are located in the furnace area There will be one on the heat exchanger and two around the pilot valves. sounds like one is open if this is not it then its the control board.
Aug 21, 2014 | GE 2251 Nordyne 1/8 HP 208/230 Volts 5in....
LOOKING FOR INSTRUCTION FOR GAS FURANCE NORDYNE FG6RK 096N-16B -WOULD LIKE INSTALLATION AND PRODUCT INFO
Jul 11, 2010 | Heating & Cooling
Does the Nordyne gas heater have a pilot light 903046 G6RC080C-16B If so, its out, How do you re light it with out calling someone to come out and do it. I don't see Nordyne Listed on the Heater Drop down?
Jan 18, 2010 | Heating & Cooling
Miller furnace model M3RL080 BW, code flashes open limit switch or external load on W, I bought a new limit switch, the furnace runs for 5-10 minutes then the flame goes out, the blower keeps running and...
Oct 25, 2009 | Heating & Cooling
Intertherm Furnace Will not stay on
possible dirty air filter low air flow causing high temp in fire box to trip limit switch or fan motor is bad hope this help let me know if you if this solved problem I may need more info
Jan 04, 2009 | Intertherm P3RA-048K Air Conditioner
Heating & Cooling Logo
102 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
