Question about Yamaha CDC-655 CD Player
Pwr. on but won't play cd,
Light indicates ea. cd slot (1-6) but will not play., also, didn't close by itself
    Master:
  • 444 Answers
The lazer is not reading the info off the disc any more, It is costly to have them (Replaced) $180 to $250.
Posted on Nov 02, 2012
Hitachi ax-m71 cd door won't stay closed. Unable
if it opens back up when you close it the drawer mechanism is probably out of alignment. Most players have a slot on the bottom of the drawer that a pin must slide in. Look under the drawer and see if there is a pin sticking up that maybe should be in that slot.
Jul 09, 2013 | Audio Players & Recorders
Fuse inside of player might of blowin,Cover has to ge taken off,To replace it,
Nov 01, 2012 | Yamaha CDC-655 CD Player
Philips DCB146 NO SOUND!!
The answer is straightforward. The main power amp has gone. If you are lucky it's a single IC unit which you will find on a big heat sink. It might look like the one shown below.
You will of course need to de-solder it and resolder a new one. The type needed to replace it will be shown by the letters and number on the IC itself.
May 02, 2017 | Audio Players & Recorders
Bose 321 II dvd drawer won't open, fixes here & elsewhere not working. I put in a recorded dvd. It tried to read it, & never gave me the not supported msg as I started trying to eject it...
Hi Donna,
Please do be frustated.
Your lovely Bose has problem with its mechanism that cause load / unload totally out of order. If you hear some noise while you turn on the bose or when you hit some buttons, it is telling us the motor still work. Now we need to check the broken gears ( or other mechanism linkage).
If you able assemble this Bose, go ahead to find and fix it mehanism ( you may need some parts replacement.
Note : Be carefully with its laser lens while power on ( avoid direct contact to your eyes).
Best luck,
Jay
Sep 26, 2011 | Bose 3 2 1 GS Series II DVD Home...
Pilot light on the gas boiler won't stay lit it's
The pilot flame must touch (burn) the tip oqef the t-couple to hold the magnet in the gas value open.make sure the pilot orifice (hole) is clear.the pilot pressure (in the tube) is factory set full open & can only be adjusted down (less). Also check the gas **** didn't get closed or turned half way.? Assuming its not the t-couple. If all is good & it still won't stay on. Replace the gas value.!
Sep 20, 2011 | Heating & Cooling
When I turn the system on the CD Drawer keeps going in and out repeatedly by itself. When I load a CD it won't recognize it and won't play it and keeps going in and out opening and closing by...
Hello
Check all connections, such as from player to amplifier or receiver and receiver to speaker. Check and clean contacts on RCA jacks and cables and try a different input on the amplifier or receiver.
Clean the lens. Use only a special CD lens cleaner and follow the instructions carefully.
Check the traverse assembly (the metal rod that the laser travels along and the gear that drives it) if CDs aren't recognized or won't play, frequent skipping occurs at random, CDs randomly get stuck in one spot, the player can't find tracks correctly, or cleaning the lens doesn't work. Dust and lint may be interrupting its function.
Have the laser-head assembly checked by a repair person if the traverse assembly seems intact and free of debris.Look for broken plastic parts, such as gears and clips,look for loose or broken internal connections.possibly have gears and belts replaced.
Jun 09, 2011 | Audio Players & Recorders
Jctwhen pressing the play button the light is on red it goes from red to green like it suppose to do ,but whithin 2-3 sec. it shuts itself down back to red and will not play
Unfortunately you have the red light of death (RLOD). Which means your graphics card has overheated. Repairable, but prob won't last. Mine didn't. I'm on my 3rd PS3, thankfully the slimline models don't suffer this problem.
Hope this helps.
LJ
Apr 17, 2011 | Sony Playstation 3 (PS3) Console
Yamaha CDC-655 CD Player Logo
141 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
