Limit open,or external load on w, Nordyne Furnace
3 Suggested Answers
billyvangogh
  • 108 Answers
SOURCE: miller furnace model M3RL080 BW, code flashes open
Check your furnace filter any Limit fault code usually relates to airflow...Not enough...causes the furnace to run too hot and shut off....the furnace can be too big for your house if its new...the ductwork can be too small , also make sure your return air vents are clean and unobstructed . Your furnace can be running too long a cycle ....also if you have central air conditioning the coil for the AC in the Furnace can be dirty...restricting airflow...if all this seems ok you can usually increase the fan speed or try tunning the fan in the "On" position on your thermostat this will promote better circulation
Posted on Oct 25, 2009
Therinnaiguy
  • 1420 Answers
SOURCE: code: open upper limit on a 1 yr old Goodman furnace
The sensor over the flame has tripped. It will need to be replaced or check for a disconnected wire.
Posted on Oct 11, 2009
Testimonial: "thank you, do you know of a good plce to get a sensor. I saw the sensor looked okay no wire disconnectd so it must be bad"
I have a nordyne furnace model # e3eb-017h. Furnace doesn't kick on at all. No relay click or anything but it's getting power. Did the thermostat trick with touching wires together to kick on the furnace...
Check the pilot light sensor. Have seen this issue before. Sometimes after lighting need to hold it in longer. If it doesn't detect the lit pilot wise it will sit in safety shut down mode
Oct 28, 2014 | Heating & Cooling
Why is my heater coming at the same time my a/c is on
Check your limit switches by ohming across the swtich and u should get a reading if not it is open. The limits are located in the furnace area There will be one on the heat exchanger and two around the pilot valves. sounds like one is open if this is not it then its the control board.
Aug 21, 2014 | GE 2251 Nordyne 1/8 HP 208/230 Volts 5in....
Open limit switch code
Take the Filter out of your furnace and try it again, some times the filter restricts the air flow to much going back to the furnace and it gets to hot and the switch opens. Also check that there is nothing blocking the return vents, like clothes, shoes or the ducts are very dirty but i don't think that's a problem. If the filter is a problem, put one of those spun fiber filters in, the kind you can see through they are blue or green. they are cheap maybe a $1.00 - $2.00
Hope this helps
V6boyo
Jan 09, 2013 | Gibson Nordyne GR6GD-X42K072C 3.5 Ton 13...
Miller furnace model M3RL080 BW, code flashes open limit switch or external load on W, I bought a new limit switch, the furnace runs for 5-10 minutes then the flame goes out, the blower keeps running and...
Oct 25, 2009 | Heating & Cooling
Wiring NO, NC relay on Nordyne furnace
NORDYNE , GOODMAN, AND NUTONE ARE ALL BUILT BY SAME MFG SO IF YOU TRY ALL THESE MAYBE YOU CAN FIND THE HELP YOU NEED
Jan 12, 2009 | Electric Circuit Breaker Kit for Furnace
Intertherm Furnace Will not stay on
possible dirty air filter low air flow causing high temp in fire box to trip limit switch or fan motor is bad hope this help let me know if you if this solved problem I may need more info
Jan 04, 2009 | Intertherm P3RA-048K Air Conditioner
Heating & Cooling Logo
1,808 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
