Question about GE Refrigerators
GE Profile Side by Side Model TFX22PRXDBB not working
Moved it from one home to another and it just stopped working. It worked fine before the move. Do not hear any of the motors running. The light comes on but that's it. Where do I start to figure out what part will make the entire refrigerator stop working?
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 35 Answers
IT MAY BE IN THE DEFROST CYCLE RIGHT NOW GIVE A HOUR TO SEE IF IT COMES ON
Posted on Nov 02, 2012
peyton32034
  • 410 Answers
SOURCE: GE ESS25XGMC WW Side by Side
its possible that your water tank has frozen up, try turning the refrig off and leave the doors open for about 10-15 mins and try it again. if that works just reset temp controls a little lower..
Posted on Dec 16, 2007
docjohn174
  • 943 Answers
SOURCE: GE Monogram side by side freezer and refrigerator
HI thanks for your question. the problem could have been, a defrost timer, stuck on defrost. or a failing thermostat. keep a close eye on it, if it stops again. get in touch and we fix the problem. thanks
Posted on Oct 15, 2008
  • 74 Answers
SOURCE: I have a GE Profile,model PFS22SISBSS,3 years
Possible main pcb failure failure which would cause everything to cut out and restart . Is the compressor or back of the appliance hot ?? Do all the control lights go out when the compressor cuts out ??
Posted on Feb 26, 2009
Maanita
  • 1142 Answers
SOURCE: GE side by side Refrigerator makes LOUD SQUEAK when running
Noise can come from these areas:
The inside of the freezer Self-defrosting refrigerators use a circulating fan to move the air through the freezer and refrigerator compartments. This fan runs whenever the unit is cooling. The fan is located in the freezer, as follows:
  • If the freezer is on top, the fan is on the back wall, near the top or bottom, in the center of the freezer.
  • If the freezer is on the bottom, the fan is on the back wall, near the top of the freezer.
  • If the freezer is on the left, the fan is on the back wall, halfway up or near the top.
Over time, the fan may become noisy--usually making a chirping or squealing sound, though it may make a loud groaning noise instead.
To find out if the fan is causing the noise, just open the freezer door and push in any fan/light switches. If the noise is louder when the door is open, the evaporator fan motor is the cause. You can't lubricate or repair this motor. You must replace it.
The outside back of the refrigerator There are three components on the outside back of the refrigerator that may become noisy: the compressor, the condenser fan motor (if self-defrosting), or the defrost timer (if self-defrosting).
  • The compressor is a football-sized case with no apparent moving parts. You can see it on the outside of the refrigerator at the back near the bottom. It is usually black and has black or copper-colored tubes and various colored wires attached to it. If the compressor is the device making noise, there is probably no repair that will reduce the noise. You will have to replace it--which can be quite costly.
  • If the condenser fan is making noise, there may be a build-up of lint or other debris on the fan blade. The fan is located near the back of the machine, sometimes behind a thin panel. To clean it, first unplug the refrigerator, remove the thin panel, and use a soft bristle brush to clean it. If there is no lint build-up or debris on the blade, you will have to replace the motor.
  • The defrost timer is often located at the bottom of the refrigerator, near the front and behind the kick plate. Occasionally the electric motor inside the timer may become noisy. The timer must be replaced to solve this problem.
The bottom of the refrigerator Noises detected at the bottom of the refrigerator almost always originate from the back of the refrigerator. However, sometimes the drain pan under the refrigerator will rattle. You may need to tape the pan in place to stop a rattle. Also see the “Outside back of the refrigerator.”
Posted on Mar 24, 2009
aasc
  • 1606 Answers
SOURCE: GE Profile model PFS22MISBWW stopped working, panel problem?
Replace the main control board on the back of the refrig . PT# WR55X10656 . It's behind a panel about 10" x 6" .
Posted on Aug 08, 2009
WATER NOT FILLNG IN GE PROFILE DIHWASHER
It ended up being a simple fix. Soap had dried on the floater (water sensor device) and it could not move, therefore no water was going in. I poured hot water and vinegar into the washer and ran a complete cycle and it is working fine now
Jun 10, 2009 | GE 24 in. Profile PDW7880G Built-in...
I JUST MOVED INTO A NEW HOME WITH A GE PROFILE AD791281B DISHWASHER. IT WAS WORKING FINE AND THE WATER STOPPED FILLING. ANY IDEAS THAT MAY HELP. THANKS MICHELE
There is a water solenoid valve that controls water flow. The valve will be near where the water line connects to the unit. You will need a voltmeter to test the valve; put the voltmeter on the two leads on the valve, and then start a cycle. If the valve is getting 120 volts, but not turning on, then the valve is bad and needs replacement
Jun 10, 2009 | GE Dishwashers
I purchased a used GE Profile side by side refridgerator; it was used for model homes... Well I got it home and the lights are on but it doesnt seem to be working??? The buttons seem to be non...
if the unit was working before......unplug the unit, place it where it will be used, let it stand with no power for 24 hours.......then plug the unit in and check its operation after 24 hours....I know, sounds nuts, but this has saved many from buying a new unit......not all refrigerators like to be moved.
clarkco
May 09, 2009 | Refrigerators
I have a 2004 GE Profile Arctica, no display, no ice, no water
where the wire from the plug goes into the fridge give it a waggle. and push the fridge from side to side it sounds like a loose connection to me.
Mar 26, 2009 | GE PSC23NGP Side by Side Refrigerator
GE Profile will not run cycles. Runs water continuously.
OK, i would do a hard reset by unplugging for 2 minutes. if the problem still exists, this is defiantly a malfunctioning relay. it will have to be replaced.
Mar 06, 2009 | GE Profile WPRE6100G Top Load Washer
Fridge and freezer won't get to temp
you have problem oil get in the evap call service
Dec 29, 2008 | GE Profile 26.6 cu. ft. Side-by-Side...
Moved refrigerator. Won't get cold now unless at 9.
Sounds like a defrost problem. Check to see if there is any frost buildup in the back wall of the freezer. If so, it is not defrosting as it should.
  • possible causes:
  1. bad defrost timer
  2. bad defrost heater (in freezer)
  3. bad thermo switch in freezer
If you don’t know what these are then unplug the machine and let the ice melt in the freezer overnight with the door open. Then try it the next day, if is cooling fine then you need to have a service person replace one of the above items.
Jul 01, 2008 | GE Profile 26.6 cu. ft. Side-by-Side...
GE profile performance tfx30ppz ice dispenser not working
Had the same problem. The water line from the valve to the ice maker was cracked due to heat from the compressor.
Jan 09, 2008 | GE Profile 26.6 cu. ft. Side-by-Side...
Refrigerators Logo
49 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
dweatherby
