Kenmore model110.20442990 washer won't spin - Washing Machines
KevinWhite
  • 1902 Answers
SOURCE: washer won't do spin cycle....and
Hello & Welcome to FixYa
When the washer fills but does not agitate or spin then you can check if the lid switch is fine. You can jump start the lid switch by connecting both the wires with each other or use the third wire to act as jumper between the two. After this if the problem is solved then replacing lid switch is recommended repair. Please get back to me if you have any other questions.
Kevin
Posted on Jul 15, 2011
SOURCE: WASHER FILLS WITH WATER, THEN WON'T AGITATE.
WASHER FILLS WITH WATER, THEN WON'T AGITATE. TURN KNOB TO SPIN AND IT DRAINS THEN SPINS. STILL WON'T AGITATE please show me a diagram
Posted on Jul 23, 2011
  • 500 Answers
SOURCE: My washer did fill, but
Hi tragz,
If it can't drain, it won't spin. There may be something preventing the pump from draining in the Pump filter. You will need to clean it.
Please follow my below Tip on how to do it:
ACCESS, DRAIN & CLEAN THE DRAIN PUMP FILTER
Kind Regards d")
* If this solution helped you, please rate it
Posted on Aug 05, 2011
Jahn27
  • 1554 Answers
SOURCE: I have a Kenmore Elite
The machine, based on the error code, is made by Frigidaire for Kenmore. Error code E20 pertains to a slow or no drain problem which can be due to a clogged/kinked drain hose, blocked drain filter/coin trap, or a broken drain pump. The link below provides the detailed troubleshooting procedure of this error code.
Error Code E20 on Frigidaire and Frigidaire-made (including Kenmore) Front Load Washing Machines
Posted on Aug 21, 2011
oldTech2332
  • 2341 Answers
SOURCE: My Kenmore washer (22712) won't spin. It
The number one thing wrong when that type top load washer makes noise and does not spin, is a broken coulper between the motor and the gearcase. This tip i wrote will show how to replace the coupler...follow it to take apart the washer to see if the coupler is broken,if it is my tip will also be helpful to replace the coupler. http://www1.fixya.com/support/r10293994-whirlpool_made_washer_not_agatating
GENE
Posted on Oct 08, 2011
Kenmore washer Model 110, Serial No. 27602690 won't spin
If wash cycle operates and water drains as should before spin indicates motor spinning. Chances are bad timer If your a real fixer you can remove timer control from panel check and clean all contacts internally making sure none are stuck closed . (Have had 3 110s in my time).not easy but can be done or buy new about 150$ reassemble and check operation.
Mar 28, 2013 | GE WBSR3140DW Top Load Washer
Kenmore washer model 110.26722693 won't spin,
If the unit agitates but when it gets to the spin cycle it just sits there you will need to replace the lid switch. Here is the part to order.
There is a video on that same parts page to show you how to replace it.
Keep me posted.
Nov 28, 2012 | Kenmore Washing Machines
Kenmore washer 110 20712990 won't spin
You will need to replace the lid switch. Here is the part to order.
Below is a video to show you how to replace the switch.
Nov 17, 2012 | Kenmore 24032\24036 Top Load Washer
My kenmore ad 80 series washing machine won't spin
The lid switch is probably out. Bypass it and see if she magically comes to life. Their are 3 wires to the lid switch 2 of which are live wires. Jumper them 2 live wires and see if she runs in spin.
My home video: Washer won't spin It's a doozy
Jul 20, 2012 | Kenmore Washing Machines
Kenmore 80 series washer won't spin or agitate
check to make sure the belt hasn't come off. if it's direct drive make sure the shaft is working and moving freely. if all of these check out the motor that turns everything my be stuck, frozen up or just bad all together.
Jul 14, 2012 | Kenmore 24032\24036 Top Load Washer
Kenmore series 80 washer won't drain after wash cycle
Try the 'drain' portion of a few of the other cycles (heavy, perm. press, delicates) and see if it will drain/spin there. You can also try advancing the timer slowly through the 'spin' portion to see if it kicks in anywhere.
If it will rinse and spin in the other cycles, you most likely have a bad timer.
Hope this helps.
Sep 25, 2011 | Kenmore 22422 Top Load Washer
My washer did fill, but won't spin or drain now and the door won't open
Hi tragz,
Kind Regards d")
Aug 05, 2011 | Kenmore HE2 Plus Front Load Washer
Washing Machines Logo
50 people viewed this question
Top Washing Machines Experts
