Always uses the hot water and not cold or warm water. cold water is on washer just uses the hot watere
    Top Expert:
  • Washing Mach... Master
  • 9,472 Answers
Sounds like the hoses are hooked up opposite. Swap the hose connections on the washer.
Posted on Nov 02, 2012
  • 1314 Answers
SOURCE: Whirlpool ghw9100lw2 front load washer doesn't use both hot and cold
first make sure the hoses aren't reversed hot on cold or cold on hot next turn off cold water remove the hose from the washer and check to see if the screen on the washer is clogged if not get a bucket turn on cold water and see how strong the water is then let me know what you find dont rate me till we are done
Posted on Jan 10, 2008
IrishDruid
  • 2712 Answers
SOURCE: Washer will won't run cold water cycle
Some washing machines allow cold water to enter only during certain cycles. Others intermittently allow hot and cold to enter, to temper the temperature of the water. Consult your owner's manual if you are unsure about whether the machine is acting abnormally.
If you're sure the machine is not working the way it used to--or should--check the following.
  • Is the cold water turned on? If not, turn it on.
  • Is the washer getting hot water but no cold water? If so, check to see if the control panel settings are correct.
  • Is there cold water coming through the proper hose? If not, check to see if the screen inside the water-inlet valve is clean. (The water-inlet valve is the device on the washing machine that the fill hoses are attached to.) If it's clean, you probably have a defective water-inlet valve. If so, you need to replace the valve.
  • Hope that helps! Should you have any further questions, please feel free to post them here.
    P.S. – I would greatly appreciate a FixYa! rating if the solution I provided fixed or helped you fix your problem.
    Thank you for using FIXYA!
    Cheers!
    IrishDruid
    Posted on Oct 12, 2008
    duby1990
    • 370 Answers
    SOURCE: Kenmore 90 series washer no hot water
    CHeck to see if the screens in the water valve are plugged. If not the hot water side of the valve went out. Replace the water valve and it will fix both the hot and cold problem.
    Posted on Nov 19, 2008
    onthejob5130
    • 640 Answers
    SOURCE: water temperature control not working
    the fill hoses are backwards,,,reverse fill hoses...on the job...also your under warranty ..call for service but you can do it your self..
    Posted on Jan 17, 2009
    canbruce75
    • 1776 Answers
    SOURCE: maytag performa washer hot/cold cycles reverse, hooked up correct
    This sounds like a cold water supply problem that's usually caused by a problem at the water inlet valve. First, remove the water supply hoses and check the small screens inside the water inlet valve. Make sure they are not clogged with rust or debris. Next, check the solenoids using a multimeter or ohmmeter. Check for continuity. A lack of continuity indicates a faulty solenoid and the water inlet valve assy will need to be replaced. I will attach a photo for reference. Hope this helps and best wishes.
    Posted on Aug 10, 2009
    Why does cold water mix with the hot when the switch is set on hot
    Depending on the age of the unit you may be looking at a faulty switch. Sometimes the contacts for the cold water solonoid on the switch may be fused shut and therefore you will always get cold water no mater what you select. If hot water is what you need the easy way to do this is select hot water and close the tap for the cold water until needed again. Hope this helps
    Sep 06, 2012 | Admiral AW22 Top Load Washer
    Cold/cold cyle wash water not cold
    try to do cold cycle first without doing warm cycle first
    Apr 12, 2008 | Whirlpool Duet GHW9150P Front Load Washer
    I have a Kenmore washer model 110.98762792 and im having a problem with the cold water. When the water temperature switch is set to the cold/cold position the washer does not fill with cold water. W
    Since U get warm water that tells you that the cold and hot water solenoids are both operating. Ergo the anomaly has to be with the device that controls temperature.
    Apr 10, 2017 | Kenmore Washing Machines
    I am getting warm water when we have selected colc/cold. I have checked the cold water intake and it works. In fact, if I shut the hot water intake, I only get cold water for the wash. What is causing...
    If you turn off the hot water line, and you have cold water then suspect the water inlet valve. Unplug the unit and turn off the water to disconnect the water hoses. Pull out the washer and remove the back of the unit by the water hose inlet. The new valve is around $65.00 and is on connectors, which make it an easy fix.
    Feb 22, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
    I have a Whirlpool washer GHW9150PW0 and it always washes on hot water, no matter if I set the temperature on cold. I turned off the hot water faucet and still the wash comes out warm. What is the problem?
    these washers sense the water temperature that comes in to them and automatically adjust the temperature by turning on the hot and cold valve on make sure both your water valves on the wall are on all the way and water is coming out of each
    Aug 19, 2010 | Whirlpool GHW9150 Duet Washer
    My new estate washer with 4 water selections actually only has 2, hot and cold. The warm water setting fills with lukewarm water for a while then shoots in cold water for a while and back and forth. In the...
    Yes, this is normal. All newer washer have auto temp control fills. This is to meet energy saving requirements. The less hot water used the more energy saved. Most hot settings on washers give out basically lukewarm water. The detergent made today is made to work well with cooler temperature water, so things will still come out clean.
    Feb 01, 2010 | Whirlpool Estate TAWS750PQ 27-Inch Washer
    No warm water coming out of the clotheswasher
    Turn the cold water valve about half way closed or maybe more to allow enough hot water to mix with it and make it warm
    Dec 31, 2009 | GE WJSR2070B Top Load Washer
    Water is always hot
    Turn off the water from your hot water valve at the wall. See if you get any hit water then. If you do it must be comming in from the cold water side. If you dont get any water to flow the water valve or selector switch is at fault.
    Please rate me as high as you can and thsnks for using fixya.
    May 10, 2009 | Washing Machines
    Water temperature control not working
    Jan 17, 2009 | Whirlpool LTE6234D Top Load Stacked...
    Water temperature
    It sounds like your water inlet valve (also known as a Mixing Valve on some washers) HOT solenoid is sticking open. When you select either a hot or cold wash cycle, separate solenoids open or close to allow only cold water to enter the washer on the cold wash cycles and hot water to enter on the hot cycles. If the hot solenoid stays open, you will have hot water mixing with your cold water during the cold cycles. The result is warm water. I would recommend you replace the water inlet valve. This is a job the average DIYer can do. Please post back with your model number and I can assist you with locating a part number and/or give you specifics on how to access the valve to replace it.
    Aug 26, 2008 | Maytag Washing Machines
    Washing Machines Logo
    20 people viewed this question
    Top Washing Machines Experts
