My sony rear projection tv's red light started blinking 8 times, so I removed the high vltage splitter, so I needed to test the block. And you guys are sugesting for me to turn on the tv, now do I
    Top Expert:
  • Televison & ... Master
  • 14,553 Answers
Turn on very briefly and make sure the large red wire that entered the block is well away from any metal---if hear a frying sound and blink sequence is gone the block is bad( I used to put the wire into a old soda bottle as it has over 20 thousand volts coming out of it, much like the spark plug wires in a car---high voltage with low current.
Posted on Nov 02, 2012
wyoed1
  • 211 Answers
SOURCE: Sony KP57WS510 Blinking 8 times
You have a strt up problem. I found, in a similiar Sony Big Screen a couple of fixes. First thing to try is unplug the set from the wall for about 15 minutes and then plug it back in and retry the set. If this corrects the problem, I suggest you purchase a good ( Not a 5 dollar piece of junk) surge protector. ( One rated at 500-1500 joules. A good surge protector may prevent future processor lock ups. If this doesn't correct the problem, the problem lies in the circuit boards of the set. I found one problem in a Sony like you describe had a bad convergence chip and a burned resistor in the same board. Good Luck
Ed
NC Electronic
Mills, Wyoming
Posted on Jan 06, 2008
SOURCE: Sony KP-46WT510 wont turn on
Can you tell from looking at the HVB that its bad?
Burn marks on them ect...
Mine looks like nothing is wrong with it.
Posted on Apr 27, 2008
  • 41 Answers
SOURCE: convergence chip
Convergence ICs cost around 15-25 each there are only two of them. I would go ahead and replace both of them because if one goes the other one will follow shortly. I would make sure that it is just the convergence IC not something else, and if its over five years old dont pay more than $500.
Posted on Oct 07, 2008
Wise Frog
  • 13 Answers
SOURCE: Sony wide screen projection tv model kp-57wv600.
I found this solution from SONY's website.
The STANDBY light will flash if an issue is detected within the television. This can sometimes be resolved by simply following the steps below to reset the television.
  1. Turn off the television. IMPORTANT: For a projection television that uses an internal lamp, wait 5 minutes after turning off the television to allow the lamp to cool before continuing with the following steps.
  2. Unplug the television power cord from the electrical outlet.
  3. Let the television remain without power for 60 seconds.
  4. Plug the power cord back into the electrical outlet. NOTE: If the television is plugged into a power strip or surge protector, remove it from the power strip or surge protector and plug it directly into the wall outlet. If the issue is resolved, the problem is with the power strip or surge protector and not the television.
  5. Turn on the television.
If the issue is still unresolved after following all of the troubleshooting steps, service may be required. Please note the number of times the STANDBY light flashes and relay that information to the service center.
I hope this helps.
Posted on Aug 05, 2009
SOURCE: Theatre View Toshiba Rear Projection TV 50 Inch with no sound or picture and a red light keeps blinking
I have the sames t.v you have to go in the back flip the power cord switch...then reboot the t.v.
Posted on Aug 13, 2009
TV turns red,shuts off, stand-by light blinking 8Times
Eight blinks - Problem with the audio (AUDIO), unit goes to standby and blinks the self-diagnosis code. Check IC406 audio amp, PS401, and 402. On some projection models of Sony TV sets, this code means that T8005 (flyback transformer), or the associative components in the high voltage circuits are defective on the D board.
Feb 27, 2014 | Sony KP-51HW40 51" Rear Projection...
Hi, I have a sony rear projection TV. I am trying
The wire is the HV lead to the block or HV splitter.
At the splitter pull rubber boot back and press down and turn wire and it will come loose.
SD TECH
Jul 10, 2011 | Sony KP-57WS510 57" Rear Projection HDTV
KP-57WS500 8 blinks will not power on
High Voltage Splitter Block #8-598-955-32 8 Blinks Call MAT electronics 1-800-628-1118 or Electronix Parts 1-800-223-3205 or you can go to thier websites online.
Jan 04, 2009 | Televison & Video
Sony kp51 ws500 red screen, 8 blinks
The 8 blinks is pointing to a bad flyback transformer and may be common with this set. (We have one too.)
High voltage error -- blinks 8 times • T8005 is faulty. (D board)
Jan 01, 2009 | Sony KP-57HW40 57" Rear Projection...
KP-43HT20
If the flyback is bad, the 135 volts will reach about 70 or 80 volts and the set will shut down, and the LED will blink twice. Usually, for 8 blinks, the high voltage capacitor inisde the splitter is shorted, and an easy test for this is to disconnect the thin gray ground wire, move it away from everything else and turn the set on. The set will now run but the ground wire will hiss like crazy. If you replaced the splitter but the set will not run, try disconnecting the 3 high voltage wires to the CRT's and see if the set runs. If it does, reconnect the high voltage wires one by one until you find which CRT is loading down the high voltage. Let me know how you make out.
Apr 09, 2008 | Sony KP-46WT510 46" Rear Projection HDTV
8 blinks means that the High Voltage Block is shorted - part# 8-598-955-32 (about $80)
Sep 10, 2007 | Sony KP-46WT510 46" Rear Projection HDTV
Green Screen then off...8 blinks
According to service manual, 8 blinks is a high-voltage error. A link to the manual and a how-to guide for retrace lines is here: http://www.somelifeblog.com/2007/06/sony-projection-tv-red-line-repair.html
May 21, 2007 | Sony KP-51WS500 51" Rear Projection...
Will not turn on
how many times does the light blink? There is a diagnostic set-up built into these Sony TV sets.
Apr 01, 2007 | Sony KP-51HW40 51" Rear Projection...
Televison & Video Logo
89 people viewed this question
Top Televison & Video Experts
