Question about Yamaha YBH301MS Marching Baritone Horn in Silver
Valves on a baritone are stuck
The valves on my baritone are stuck and i cant get them off and i really need them off how do i get them off
Need an R62 resistor for a soundcraft Spirit Live 4/8 Board #SC3536B
Cant get the schematics myself...weird...check out this site and call http://www.prosoundservice.com/ this was on other blurbs in the past and was really helpful...good luck
Feb 23, 2015 | Soundcraft Music
Need a power transformer for a Mackie 1202-VLZ mixer
The transformer itself will have the codes you need to replace it either printed on it or on a label stuck to it. Mouser should have what you need.
Sep 16, 2014 | Music
I just bought mesa express 5 50 amp. After a couple of weeks the reverb control malfunctioned - no reverb, and the overall tonal quality drops. Is this a common problem? is it the tube?
Quite likely a valve. The only valve unique to reverb is V5. Clearly labled on the amp. Or check your manual. It's a 12AX7. You can't really swap it with another because they are all common to both channels. Just buy another - not expensive. If you have not changed valves before:
1. power off
2. let valves cool
3. identify V5
5. note the orientation by pin layout on your new valve.
6. remove valve (might have to wiggle gently)
7. do not force in new valve - pay close attention to orientation.
If it is not a valve, then it gets complicated, take it to a tech
Aug 22, 2013 | Mesa Boogie Mesa EXpress 5:50 2x12 Guitar...
No Power after Valves glowed bright
This could be a transformer failure. Take it to the repairs shop.
Jun 08, 2013 | Peavey Valveking Vk100 Guitar Head
Zomm g1xn software problems
Yes, it's a hardware problems. Try using the battery.
If the result is the same,there is a possibility of damage to the processor IC (ZFX3). But before be sure, try measuring the voltage as in the image below :
Stuck in GN display usually appears because 1.8Volt voltage is not normal (or no voltage at all), and in general, it is caused by damage ic ZFX3.
Leave it to the experts to be repaired. If it really ZFX 3 is the case, then this can not be fixed, because ic ZFX3 not sold to the public. If you call the authorized service ZOOM, you may be able to buy G1XN mainboard. 11399294-xykdzr1cdriwl1tmr4ngy0qt-2-3.jpg
Jan 22, 2012 | Zoom Samson Technology Zoom G1XN Multi...
Hi i got the korg pa50sd when i swith it on it shows me korg pa50sd boot loading files then this goes off, still the light on display is on but blank display with nothing on it ,. i was trying to find any...
NOT a fuse... thaat person knows nothing. There is something wrong for sure. Check if one of the buttons or keys MIGHT be stuck down (depressed). Sometimes the units check that all the control buttons are up and they don't really tell you why they fail to start. Beyond this a repair shop is in order.
Jul 11, 2011 | Korg PA50SD Pro 61 Key Keyboard Bundle
I have a Fender Cyber Twin (1st edition, dont have serial number to hand) which I purchased 2nd hand from Ebay. Lately it has had a fault which started off as quite intermittent but has got worse. When...
Check for degradation of C144 a 2200mfd/16volt cap.
This is power source for the 5 volt digital hardware. Check for excess ripple with a scope. The voltage should NOT go below 8 volts. If the voltage dips, the DSP will go nut-case.
Sep 30, 2010 | Music
Open Questions:
Yamaha YBH301MS Marching Baritone Horn in Silver Logo
37 people viewed this question
Top Yamaha Music Experts
Matthew Spark
Matthew Spark
Mike
Are you a Yamaha Music Expert? Answer questions, earn points and help others
