Question about Desa International Heating & Cooling
I need replacement logs for VSGF28PTB/CSGF28PTB
REPLACEMENT LOG SET
  • 58 Answers
SOURCE: i NEED TO SET UP A COMPUTER LOG IN
Click start>>>control panel>>>user accounts>>>create password
Posted on Mar 15, 2009
  • 100 Answers
SOURCE: Replacement door for little tikes log cabin
Click on this link it is the replacement site link for little tikes. http://www.littletikes.com/consumerservice/replacementparts.aspx You should be able to click on the product you are looking for a replacement part for and you should be able to find it there.
You can email them and ask for the part that you are looking for as well here is the email address link http://www.littletikes.com/consumerservice/Contact-Us.aspx
Thank you
Posted on May 03, 2010
pcj141414
  • 62 Answers
SOURCE: Help! I need to set the
If you cant find the password or remember it you'll have to do a hard reset on your router.
You can do a hard reset by plugging it in, locating the small hole on the bottom or side with possiblitly the words reset next to it. Insert a pin for about 10-20 seconds and the device should revert to the default settings.
You can then set up a new SSID and password.
A tip to help me remember is to write the password down and tape it to the bottom of my wifi router.
Enjoy your Kindle.
Posted on Dec 29, 2010
guru_fixya
  • 944 Answers
SOURCE: I need replacement VUL24NR Model
You may want to try Master Parts. Just make sure you have the part numbers. You can contact them at 800-446-1446 or on-line at www.masterparts.net.
Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thank you for using fixya have a nice day:-)
Posted on Jan 10, 2011
  • 252 Answers
SOURCE: I need a replacement foam
you need briggs part number 27987
and assume this is a horizontal shaft engine
your local small engine shop should have one
cheers pauly46
Posted on Jan 17, 2011
How do I replace bulbs on model DS5603 Mod G electric fireplace
Do you need to replace the upper or lower light bulbs?
For both, first open the door of the fireplace. For the upper light, locate the upper bulb bracket (above the door). Bend the bracket down. Unscrew the old bulb and replace it with 7 W clear chandelier or candelabra bulb with an E12 base. Bend the bracket back up to its original position. Close the door, if only the upper bulb is out.
You will need a Phillips blade screwdriver to replace lower bulbs. Open the door (if it wasn't already open). Locate the screw that holds the log set in the center of the ember bed. Remove that screw and the log set. Locate the bulbs that are behind the log set and determine if one or both bulbs need to be replaced. Unscrew the bulb(s) to be replaced. Screw in the replacement 60 W clear chandelier or candelabra bulb with the E12 base. Replace the log set and press firmly against the glass. Replace the screw that holds the log set. Close the fireplace door.
The procedure to replace the bulbs is on page 4 of the service manual. It is also on pages 10-11 of the Owner's Manual. The documentation is available from Dimplex: http://www.dimplex.com/en/customer_support/technical_and_troubleshooting . The direct link to the service manual is http://www.dimplex.com/cms/publications/7400650000R04.pdf . The Owner's manual is here: http://www.dimplex.com/cms/publications/7206570100R09.pdf .
I hope this helps.
Jan 12, 2017 | Heating & Cooling
Tip
The Log function!!
I calculators you can't change or set the base of 'log' is default 10 so you need to know these:
log x (base y) = log x / log y
when log x it's automatic log x (base 10) here some examples:
log 8 (base 2) = log 8 / log 2
log 27 (base 3) = log 27 / log 3
and the base it's default 10 again, and that is how you need to use it in calculators(no bases), and here the explanation to this:
log x (base y) = log x (base 10) / log y (base 10) = (log x / log 10) / (log y / log 10) = (log x / log 10) * (log 10 / log y) = log x / log y
here so other stuff about 'log' :
log (x*y) = log x + log y
log (x/y) = log x - log y
Hope it's helped
on Jul 07, 2009 | Casio fx-300ES Calculator
36ECMII pilot light won't light
If you go to this link http://fmisupport.hcents.com/supportdocs/54024F.pdf it will take you straight to the owner's manual.
Now the gas log set is completely seperate from the fireplace. You would need to find out the model of the gas log set as any manufactuer of vented gas logs can go in this fireplace. Just for clarification the brand is actually Coleman but it was made by FMI. Now, the SPVBPD is a direct vent gas log set that was only designed to go into either the Amity, Oxford, or Victor hearth gas stoves. If you have the SPVBPD burner in a 36ECMII then you honestly need to remove that log set, as it was a burner only rated for direct vent fireplaces, and get a set of 18" LP vented logs. If you look at the link below you will see the owner's manual for the SDVBND. These logs need to be removed and you can go with any 18" vented log set. I suggest Peterson (http://www.rhpeterson.com/realfyre/vented-series/)
as they have the widest selection of logs and biggest array of dealers. Good luck.
Desa Tech SDVBND Owner Operation And Installation Manual
Jan 04, 2014 | Fmi Fireplaces SDVBPD Direct Vent Propane...
Can not log in. Key selection error. TAMPER LOG F5 mo1 not loaded?
Maybe your internal battery is already LOW that needs replacement. And cleasr the tamper by reloading Verifone Software. If you still needs help you can cal at (775)358-2922 as for Randy. Thank you. http://freshpoint.org
Oct 15, 2012 | VeriFone Vx 670 Payment Terminal
How do i change the bulb on my dimplex electric fire 930 3003.9
TO REPLACE LIGHT BULBS
1. Open the steel curtains (remove glass doors if applicable).
2. Remove the log grate retaining screws and remove the log grate.
3. Pull the rear edge of the log set forward by grasping the ember bed by the sides
(handle the log set only by the ember bed and not the logs) and pulling firmly
until the rear tab pops out from under the back ledge, then lift out.
4. Examine to determine which bulbs require replacement.
5. Unscrew bulb counter clockwise.
6. Insert new bulb screwing clockwise.
7. Replace the log set by inserting the front edge, pushing the back down until the
rear tab snaps under the back ledge and the logs are resting against the mirror.
Quantity 4 clear chandelier or candelabra bulbs with an E-12 (small) socket
base, 60 watt rating. Example GE 60BC or Philips 60CTC
CAUTION DO NOT EXCEED 60 WATTS PER BULB
Feb 23, 2011 | Heating & Cooling
Thank you
May 03, 2010 | Toys
Pilots lites , holds ok for minutes,but once move
Hello KJGreen, It sounds, based on your description, as though the thermocouple is faulty and should be replaced. If the pilot light stays lit and you've left it on for several minutes before turning the knob on to light the log set, then that indicates that the thermocouple is bad.
The thermocouple is a safety device (heat sensor) designed to stop the flow of gas to the burner in the event the gas flame goes out and the pilot goes out. The sensor will only allow the gas valve to open once it has reached the preset temperature.
To confirm that the thermocouple is defective, I would light the pilot light and allow it to remain lit for up to 10 minutes before I attempted to turn on the log burner. If, after 10 minutes, the log burner still won't stay lit, then you know that the thermocouple needs to be replaced. Otherwise, the burner should light, since after 10 minutes, the sensor should be hot enough to signal the gas valve to open.
If you are going to have this replaced, please make sure you use only an approved supplier, since an incorrect replacement part could cause an unwelcome malfunction of the gas log burner. Safety should be primary when dealing with open flame burners.
Hope you find this Very Helpful and best regards!
Nov 23, 2009 | Vanguard International Infra Red - Large...
Errors
Press the following keys:
Function
7
monitor key slowly 4 times
6
scroll down to SHIPMENT SET
set
Wait for the fax machine to reboot.
Oct 21, 2008 | Panasonic Panafax UF-490 Plain Paper Laser...
Heating & Cooling Logo
46 people viewed this question
Top Desa International Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
mcijoe
Level 1 Expert
Are you a Desa International Heating and Cooling Expert? Answer questions, earn points and help others
