How to restore acer D270 to factory setting
Installing Sysprep - Factory Mode seems take too long time
  • 244 Answers
SOURCE: need to restore acer to factory settings
just boot from your backup disk. it will guide you to reload the Operating system (factory default).
FYI, if you haven't delete the recovery partition, you can use alt+f10 to reload. just press alt+f10 during boot.
Posted on Aug 01, 2008
zohail
  • 1223 Answers
SOURCE: restore factory settings
there are 2 ways for doing this
1) Fast and easy without backup disk just do this
Acer: When you turn on the laptop and see the Acer logo screen, hold the ALT key and press the F10 key (you need to do this before the Acer logo disappears).
2) If the method above doesnt work u can do it thru backup disk u have got when u purchased ur laptop u shud have made it thru Erecovery software.
Pls rate me FIXYA for help !
Posted on Apr 13, 2009
chudd1
  • 18 Answers
SOURCE: ACER NETBOOK MESSING UP NEED TO RESTORE IT BACK TO ORGINAL FACTORY MODE
reboot and hit the alt and f10 buttons at same time and follow the prompts
Posted on May 03, 2009
  • 52 Answers
SOURCE: acer aspire 6920 back to factory settings
Acer sent me these instructions.
The other way before Vista starts up is to tap ALT + F10 (at the same time repeatedly) when the computer is first switched on.. The window of opportunity is very small, so this may take a few attempts
Once you have tapped both the ALT and F10 repeatedly, you may see a screen showing:
“Edit Boot options for Microsoft Windows Vista”
If you see this, unfortunately, you have missed the window of opportunity, and you need to restart, and try again.
If you see this:
“Edit Boot options for Windows Setup” OR “Edit Boot options for Acer eRecovery”
Then it indicates that you have tapped the ALT + F10 correctly, and all you now need to do is press “Enter” and the Recovery program should load on your screen after a short pause..
In some cases, you may need to remove the battery (for notebooks only) and run the machine directly from the mains.
The Disk2Disk recovery feature allows you to recover the system without recovery CDs.
This will return your system to factory settings and will delete everything stored on the machine.
If possible we strongly advise backing up anything important on your machine before starting the recovery process.
Posted on Jul 12, 2009
  • 52 Answers
SOURCE: restore back to factory settings
From Acer direct
If you see this:
I done a factory reset on my acer laptop and for about 30 or 45 mins now its been stuck on the last step installing sysprep factory mode with three dots behind that keeping counting. should i worry ?
Leave it overnight. If it it still doing it, reboot and see what happens. Sometimes it will be fine, sometimes you will have to reformat or reinstall all over again.
Apr 19, 2016 | Acer Computers & Internet
My friend gave me this netbook and said i needed a operating system for it. well when i turn it on it says that it cant finish the installation or a message comes up and saysstarting service and never...
Try booting, and when you see the Acer logo, press "Alt" & "F10" keys simultaneously to bring up the Recovery Menu. Follow the prompts to restore the Aspire One to factory default settings. Post back with how that works out.
Dec 31, 2013 | Acer Aspire One D270-1375 Atom N2600 1
Restore factory default
Switch the laptop on and press the 'Alt' and F10 buttons at the same time while the Acer logo screen is visible. This should take to a menu screen where you can select a recovery to the factory default. This will delete all files and restore the operating system to the state it was when you bought it.
Aug 12, 2013 | Acer Aspire One D270-1865
F10+alt don't work to reset acer aspire one to factory setting. what else can i do
Hi twillis84.
You will need to start your computer in the "Safe Mode", you do this by tapping F8 while the computer is starting up.
Once the computer has started, select "Safe Mode" you have two choices.
I would try "A" first.
A...You can do a System Restore from here.
You will click "Start">All Programs>Accessories>System Tools>System Restore, this will restore your system to an earlier time when it was operating properly.
B...Once you are in the safe mode, then you will double left click on "Start">Control Panel>User Accounts>Change an Account.
Now you can change your password,delete the account,etc.
Driver restore/applications Acer---using eRecovery
Drivers for Acer products may be found on the Acer Product Support. Search for the product and download the drivers.
Alternatively, the factory installed drivers and applications can be re-installed by using Acer eRecovery by following these steps:
1.Click Start, and then All Programs
2.Click Acer, and then Acer eRecovery Management
3.You may be prompted to enter or create a password. This password will be required to use eRecovery in the future.
4.In the next window on the left toolbar, select Restore.
5.Choose Reinstall Drivers or Applications
6.Choose Contents
7.Choose the driver or application you wish to install
8.On the right, click the Install link and follow the prompts.
9.The computer may restart when installation is complete. If it does not restart, manually shutdown and restart the computer.
Note: For older Acer products, the Acer eRecovery Management program may not be available.
If you do not have a set of Acer Recovery Media, they may be purchased from the Acer Recovery Media Order Form.
Acer Website:
http://support.acer.com/us/en/default.aspx
Please take time to rate me
Bud
Sep 24, 2012 | Acer Aspire One AOA150-1949 Laptop
Acer travelmate 5730 factory settings restore
Acer Travelmate laptop by pressing ALT+F10 during the bootup to get to the eRecovery and restored the computer to factory default.
Jul 15, 2012 | Acer TravelMate 5730-6204 Notebook
Hello how do i restore my acer aspire 5332 laptop to factory settings
Unlike other laptops, Acer laptops integrate a computer management utility called 'Acer eRecovery Management' to create backup of hard drive data, create restore point, reinstall applications & drivers, and reset Acer laptop to factory setting.
Step 1: Before starting your Acer laptop, ensure that there is no external storage device attached to it. Now start your laptop.
Step 2: Press 'Alt + F10' when the laptop starts booting, and wait for a moment while Windows loads the reset files.
Step 3: When 'Acer eRecovery Management' window appears, select 'Restore System from factory default' and click 'Next' to continue.
Step 4: Again click 'Next' to reset your Acer laptop. This process will erase all data from your hard disk and reset your Acer laptop to original factory settings.
Step 5: Click 'OK' in the notification window to begin the the resetting operation. Now wait while your Acer laptop is reset to factory settings.
Tips: You can also create a backup copy of your laptop data before factory reset. Simply click 'Backup' in 'Acer eRecovery Management' window.
If you have any other issue with your Acer laptop/desktop/Notebook, fget technical assistance at
http://www.vtechsquad.com/acer-support/
Jun 09, 2011 | Computers & Internet
Turns on but says system not found
Try start up in Safe Mode press F8. Choose Safe Mode, when at the choice window, to select either Safe Mode Desktop, OR System Restore, chooses system restore and choose a time before you had the "Problem" and follow instructions. This should get you back. If that doesn't work try running the factory restore if any... else you will have to reinstall your operating system from the Windows Install DVD.
Feb 21, 2010 | Acer Aspire 5500 5570-2609 Laptop
Aspire 9300
Run 'sysprep -factory'
the above application can be found on a Windows XP installation cd-rom under support and inside deploy.cab which can be extracted using windows.
google 'sysprep -factory' for more information.
Jun 14, 2008 | Acer Aspire 9300 Notebook
Computers & Internet Logo
112 people viewed this question
David Payne
David Payne
