Question about Casio Cell Phones
It won't charge
I cleaned it but still dos not work.
  • 580 Answers
First Option:
mostly nokia chargers doesn't make problems...
just try the following..
connect ur mobile with a system (usb cable)...
found out whether it is charging or not...
if the same prblm appears then there is a prblm in ur cell phone or power jack(socket)...
if it charged with usb cable buy a new charger
Please change Phone Bettery and check the charging
IF Charging Problem not Solved So
Second Option:
Your Phone charging IC Fault So Please change charging IC
And charging Problem will Solved Quickly
Posted on Nov 02, 2012
Keyboard will not work in dos lights will light up then goes off?
1st Check the PINS when u plug it in - I guess you are using a PC
2nd If its a USB Keyboard - try using a PS/2 - the one which has a purple end and some pins
3rd The light flashing on and off is ok - its a test - however you have the option like F8 / DEL by pressing repeatedly it will show you a BIOS Setup where you can change keep NUMLOCK light on. - this will help you know if the keyboard is detected correctly or not.
Nov 16, 2017 | Computers & Internet
Iphone won't start up
Un plug the battery check the connections on the battery and the iphone clean with some stochbrite and wipe off with 90% alcohol let dry and should work fine as long as the battery is fully charged.
Dec 26, 2012 | Apple iPhone 3G
Irobot roomba 500
If you're sure the battery contacts are clean and the battery really is charged, then there is faulty circuitry within the Roomba that would have to be repaired or replaced.
Confirm that the battery is inserted with the metal contacts down so they make contact with the spring terminals in the battery compartment.
Visually confirm that the metal contact plates on the battery pack, and the spring terminals in the battery compartment are clean and shiny. If not, wipe with a clean cloth or paper towel, its OK to use a little water or rubbing alcohol on the cloth, if needed, and then dry it.
Visually confirm that the metal contact plates on the Roomba, and the spring terminals on the docking station's home plate are clean and shiny. If not, wipe with a clean cloth or paper towel, its OK to use a little water or rubbing alcohol on the cloth, if needed, and then dry it.
If you have a volmeter, measure the voltage between the contacts on the battery pack If it isn't something in the neighborhood of 14 volts and is 11 volts or less, the battery isn't fully charged.
Reinstall the battery.
For the moment, please connect the power adapter directly to the Roomba rather than the docking station to eliminate one possible faultly connection.
If the battery wasn't fully charged, or you weren't able to test it, try to charge the Roomba and then retest the battery voltage if you can. If the battery voltage was higher immediately after charging, but didn't get to 14 volts, the charger is good, but battery needs to be replaced. If the battery voltage was unchanged after attempting to charge the Roomba, the charging circuitry may be faulty. If there was no light patterns when you tried to charge it, and it was plugged in to a good outlet, then the power adapter or charging circuitry is definitely bad.
If you have no voltmeter and you cleaned the contacts and tried to charge the Roomba and it works, use the Roomba and then recharge using the docking station and see if it was just dirty contacts or it won't charge through the docking station. If it didn't work, you'll need to figure out if its the battery, the charging circuitry in the Roomba, or the power adapter. If there are no lights when you try to charge the Roomba, then Either the power adapter or the Roomba power circuitry is defective, but without a voltmeter you can't find out which one, and there's no way to know if the battery is good or bad, but you know Roomba wasn't trying to charge it. If there are lights when you try to charge the Roomba, then at least you know the power adapter is good. Unfortunately, without being able to test something there's no way to distinguish between a charger that won't deliver a charge to the battery and a battery that won't accept a charge. If you want to take a guess then a bad battery is more common and less expensive to fix.
Jul 07, 2012 | iRobot Roomba 560 Robotic Vacuum
I bought gigaware docking speaker for iPod and it always charged my iPhone, but now all of a sudden it won't charge anymore It said something like accessory not compatible will not charge
sir you first clean your docking speaker and then charge it.. it will work fine. or other wise change your speaker there time is over.
Mar 29, 2012 | Apple Cell Phones
9595 Charger won't charge while in stand
Your charging and cleaning stand is faulty. They are not repairable because parts are not available. You can purchase a new clean and charge stand at shaveroutlet.com
Braun Series 7 and Pulsonic Clean Charge Base
May 21, 2017 | Braun Shavers Male Pulsonic System 9595CC...
I reinstalled XP on IBM T41, now battery won't charge. Could this be Driver Problem
Sounds like you need a new battery.
It's not just a battery in a case, it also has a small circuit board inside to control the charging etc, if that's faulty it won't charge, or if it has dead cells in it won't charge.
Feb 08, 2012 | IBM ThinkPad T41 Notebook
Htc evo 4g shift won't charge or turn on and I
Have you attempted taking the battery out and while the battery is out holding down the power button for a few seconds? If this doesn't work,
First test your charger to ensure proper charging. Clean charging ports. Remove battery and clean brass contacts with alcohol and q-tip
Jan 12, 2012 | Lands Phones
My SCH-a930 won't charge. I still have battery life, and the phone works fine, but the phone won't charge. I have tried multiple wall outlets. Does anyone know how to fix this? Thanks!
Please, try using another charger with the phone.
If the problem continues, get a screw driver, unscrew the phone and bring the charging port out. The charging port is at the tail end of the phone.
Clean the surface of the panel where the charging port contact the panel with a spirit and allow it to dry for 30 minute. Couple back the phone and i am sure the charging phone will work fine.
Regards
Jun 28, 2011 | Samsung SCH-a930 Cellular Phone
Cell Phones Logo
121 people viewed this question
Top Casio Cell Phones Experts
Oloyede Monsuru
ray gallant
Are you a Casio Cell Phone Expert? Answer questions, earn points and help others
