Question about Kenmore Dryers
Clothes are getting burned - Kenmore Dryers
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 35 Answers
There is a silver vent inside the dryer it needs to be clean off with sos pad are something like that the dryers have two fuses if it was getting to hot it would blow one of them
Posted on Nov 02, 2012
Kenmore stack dryer burns clothes
HI CAROMIA.unusual but check basics first1-dont overfill 2-no sintetics and nylons.if still burns its obviously overheating.3-check vents.hope this helps.ali
Jun 20, 2012 | Kenmore Dryers
MY FRIGIDAIRE ELECTRIC DRYER IS LEAVING BURN MARKS ON CLOTHES,WHAT IS CAUSING PROBLEM
Assuming that you have the correct temperature selected for your clothes, there are two likely causes:
If the clothes are showing randomly shaped burn marks, the dryer is overheating. This would be accompanied by a burnt smell on the clothes. The high limit thermostat is the culprit.
If the burn marks are dark streaks, the clothes are getting pinched between the drum and the inside of the dryer that does not move. This is caused by worn bearings, slides or rollers. Should you choose to repair this yourself, there is a great deal on a kit with all of the parts you need plus a new belt for only $32 here:
http://www.repairclinic.com/PartDetail/Drum-Bearing-Felt-Seals-Pulley-Belt/5304461262/1261075
Good luck from Detroit, Mi.
Jul 20, 2011 | Frigidaire GLER341A Electric Dryer
My dryer leaves burn marks on the clothes. What
Hi. Thanks for using fixya. I can help you. When clothes get marked or torn in your dryer, check these: Rollers Your dryer may use rollers, or wheels, to support the rear of the clothes drum. When these are worn out, they may cause the clothes drum to drop down slightly, which can pinch the clothes between the top of the clothes drum and the rear of the dryer interior. When the rollers wear out, you need to replace the whole set. Rear seal Your dryer may have a felt-like seal at the rear of the drum. If this seal is worn, torn, or missing, clothes can get caught and torn in the space between the clothes drum and the rear of the dryer interior. When the rear seal wears out, you need to replace it. Front glides Your dryer probably uses nylon or plastic glides at the front of the clothes drum for support. When these are worn out, they may cause the clothes drum to drop down slightly, which can pinch the clothes between the top of the clothes drum and the front of the dryer interior. When the glides wear out, you need to replace them as a set. Front seal Many dryers have a felt-like seal at the front of the drum. If this seal is worn, torn, or missing, the clothes in the dryer may get caught and torn in the space between the clothes drum and the front of the dryer interior. When the seal wears out, you need to replace it. small_8_13.jpg
Nov 09, 2009 | GE DBL333EA Electric Dryer
Burning marks on clothes in dryer
how old is dryer. drive belt may be slipping. Unit may have a faulty control that allows element to superheat. You have a potential fire hazard. What type of clothes are getting the burn marks? Should they be dried in a dryer?
Jul 02, 2009 | Dryers
Dryer makes small holes (cigarette burn size) on clothes
Get a new dryer. Old ones tend to tear-up clothes and burn holes.
Apr 29, 2009 | Dryers
The dryer is leaving what looks like brown burn marks on clothes
you might need to replace the felt on the inside front that the tub rides on
Apr 23, 2009 | Dryers
Dryer is leaving burn marks on clothes on any temperature.
change your cycling thermostat. It is not telling your heat element to shut off at the rated emp
Jan 21, 2009 | Whirlpool GEW9250 Electric Dryer
Parts of clothes get stuck in edge of dryer...seems to burn them.
I have had this same problem with my stack-able dryer. It was leaving small burns on my kids clothes and my good sheets. My dryer has a felt-like seal at the front of the drum. If this seal is worn, torn, or missing, the clothes in the dryer can get caught and scorched or torn in the space between the clothes drum and the front of the dryer interior. My seal was worn out, so I needed to replace it. I had someone come in and do the work the first time but when it wore out again I just order the part and replaced it myself. It is fixable:)
Apr 07, 2008 | Kenmore 98702 Stacked Washer/Dryer
Frigidaire Dryer Model FLGB43RG
those "burn" marks if they have an arking shape to them are smudges from the felt that goes on the drum support above and bellow the door inside the drier. the felts wear out every five to seven years or so. easy repair. send me a model number and i could go into more detail. part numbers ect.
Sep 23, 2007 | Zanussi TC7114W Electric Dryer
Dryers Logo
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
