Question about Refrigerators
Fridge/freezer not cooling
My ge profile model #ps123sgmd will not cool. Temp have been warming. I took back panel off and cleaned dust out compressor is cool and fan is running now that I cleaned the dust.
    Top Expert:
  • Refrigerators Master
  • 9,472 Answers
What is the model number of your unit?
Posted on Nov 02, 2012
dididsaythat
  • 291 Answers
SOURCE: ge side by side not cooling enough
check freezer for frost build up and if fan blowing, check condenser make sure clean, and fan blowing, check vents in refrig. make sure no blockage, controls should be in the middle setting,
Posted on Sep 08, 2007
BNewberry
  • 93 Answers
SOURCE: fridge/freezer not cooling
I will be more than happy to help you out with this.  I am a factory authorized servicer for Frigidaire.
Read this Article first on Frigidaire Refrigerators not Cooling.  Then if you have any more questions about this ask me on Frigidaire Tech Support.
Thanks, Bill
Posted on Nov 08, 2008
  • 833 Answers
SOURCE: Fridge running but not cooling
Sounds like you're low on gas...assuming that the condenser coils are clean.
Posted on Nov 20, 2008
SOURCE: ge model gsh25jfrfww not cooling just clicking
Replace the main board on the back i got the part for $130 at a wholesale parts store
Posted on Mar 06, 2009
  • 2468 Answers
SOURCE: Fridge running warmer than it should, Cooling fan
first check the condenser fan for operation if its not running,may be shorted,stuck,etc.,replace as necessary,then if it still doesn't turn,then the mainboard in the rear in behind a cover is bad due to the fan being bad(caution:do not replace this board before making sure the fans all work,or you will immediately ruin the new mainboard,then test run for proper cooling,if still no cooling then replace the ptc overload on the compressor by unplugging it off the compressor and plugging a new replacement
Posted on Apr 11, 2011
Hi, our ge profile refrigerator is having temp
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Sep 03, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Freezer is frozen fridge is warm
Your model is most likely the Profile Artica style. Most times the defrost heater is burned out behind the rear of the freezer wall. Manually defrost and look at the defrost heater to see if burned out. That model possibly has the glass covered defrost heater and will be easy to spot if burned out because the element is inside a glass tube, If you replace the defrost heater also replace the defrost thermostat, Please send me your model number located near floor of the fresh food compartment door seal and kick plate, Thanks Sea Breeze
Oct 01, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
PTS25 Top Freezer Model- Fridge & Freezer won't cool
If the compressor is still good your hard start relay might be bad.
Aug 05, 2009 | GE Profile Arctica Stainless Steel Top...
Freezer temp is wear fridge shoud be.fridge temp 55 degress.
Check the fan in back which cools the compressor . Also check the coils to make sure they are clean of dust , lint , etc...
Aug 02, 2009 | Magic Chef CTB1821AR Top Freezer...
GE Profile Side by Side is getting too cold on the fridge side.
I have a GE refrigerator with the same problem of my food freezing in the refrigerator. I spoke to an appliance part person and they sold me a temperature sensor for 20 bucks. They said it would be located in the control panel, but I took the control panel off and can't find the sensor. I'm now looking on yahoo answers to find out where the sensor is located.
Mar 01, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
GE Profile PFSF5 NJWA BB
There is a timer that determines the defrost of the cooling coil inside the back wall of the freezer. defrost timer may be located in the area of the controls for temperature. Look for a hole in that area and recessed in that hole you may find a clutch head screw. Turn this screw clockwise very SLOWLY until you hear one click. The freezer coil will be in the defrost mode for 18-22 minutes and then the refrigerator should return to the cooling mode. Make sure the condenser is clean and free of dust and dirt. Condenser is where the heat is removed from the refrigeration system and on most models it is located in back behind a removable panel. Reinstall the panel after cleaning the condenser.
Jun 01, 2008 | GE Profile PSW26P Stainless Steel Side by...
Does not stop cooling down
Door edges being warm is caused by what is called mullion heaters that operate to prevent humidity from condensing at these points.
Some refrigerators have an energy saver switch. Turn this switch if you have one to the energy saving position when the humidity is low. Is anything freezing in the refrigerator? If so setting the controls to a little higher setting may solve your problem.
May 03, 2008 | GE Profile¿ Arctica® Energy...
Ge profile Refridge...
check if the outside walls and back are hot to warm,. if not warm posible low level gas, or commpressor not pumping gas around.
Oct 18, 2007 | GE Profile 26.6 cu. ft. Side-by-Side...
Refrigerators Logo
113 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
