Question about Proscan Televison & Video
My proscan won't stay on until it gets warm,
I have to unplug the cable to the tv and let it get warm because as soon as the picture comes on it shuts off. once it gets warm it's fine
  • Gilbert Riojas Nov 02, 2012
    Thanks for your help
    Genius:
  • Proscan Master
  • 2,432 Answers
It was a common problem with an lcd tv, usually a leak or bulged capacitors in the power supply board will be the caused.
Posted on Nov 02, 2012
  • 4 Answers
SOURCE: proscan tv surround sound hook up
This depends on whether you have digital cable box or not. If you have a Digi Cable Box look for the red/white RCA output and connect this via RCA cable to the Red/White Audio input on your surround.
If just Basic Cable look for a red/white audio output on the back of your televison. connect this to the Red/white in on your surround. Could be called tv in or auxillary.
Posted on Jan 28, 2009
phongnv
  • 56 Answers
SOURCE: Vizio Model#:L37HDTV10A
Is the HDMI port 2 work? Try to turn it off and turn it back on. If it is still not working then the HDMI ports have gone bad. You will need to replace the main board.
Posted on May 12, 2009
SOURCE: no picture or sound, light comes on in the front and have to unplug tv to turn it off.
I had this exact problem on my Vizio 47" HDTV. I removed the speakers and all the screws on the back cover. Took the cover off and located the fuses on the largest circuit board. The are in the upper right hand corner of the board. There are 3 of them in a row labeled LF 1.5, LF 3.0 and LF 3.0. The are white in color with copper ends. I took a volt meter and measured continuity across all fuses individually and found the LF 1.5 to be blown. The guy at the electronics store sold me a barrel 1.5A fuse and told me to soldier it across the top of the blown fuse. It took an extra set of hands but the TV works perfectly.
Posted on Jun 23, 2009
SOURCE: LCD TV picture is green
I just called Vizio and they said to unplug the TV, then physically hold in the power button on the TV for 2 minutes.
Posted on Jan 04, 2010
SOURCE: TV won't turn on.
I say press the input button until you see a picture!.
Posted on Jul 06, 2011
Diagnosing tv auto shut down.
The TCON board is not junk, if anything it is the mainboard that is faulty.
Jul 04, 2016 | Proscan 40LD45Q TV
Proscan LED TV Will power up the red standby light & standby on amber when turned on but does not show picture or sound unless I unplug and replug over
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
http://electro-medical.blogspot.com/
In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Feb 14, 2016 | Proscan Televison & Video
TP50F60/TP50F61 picture won't come on for long stretches
If you need to hit the tv my money is on a bad solder joint. Re-flow solder on any suspicious joints.
Oct 08, 2012 | Toshiba TP50F60/61 TV
Proscan 40in HDTV all the colors are messed up and the pixels are and no matter what I do it won't get any better
If the problem is same with different input devices and you have ensured there are no loose contacts in power outlet, RC jack, cable and sockets, the TV needs servicing.
Aug 24, 2012 | Proscan 40LD45Q TV
Proscan 32LA30Q won't power on
It appears to be a 32 inch.
Some questions:
Does power light come on and if so what color when set is off?
Were you having any problem before where you had to turn set on several times to get it to come on and stay on?
I am here to help you.
Mar 14, 2012 | Proscan 32LA30Q Television
TV picture won't come on, just get white static
Hello
There may have some crack or loose to the circuit board during drop. Just get it serviced. No more component should be repalced. Only service should be done. OK.
Feb 03, 2012 | Toshiba Televison & Video
Power on/off circuitry intermittent. Power does not come on from remote or switch. After unplugging/replugging 20-50 times, power comes on as soon as plug is put in (switch not necessary). At that time...
Hi Chris,
Sorry for the late reply, I'm offline upon purchasing my service.
Email me at jimvincentvillanueva@yahoo.com, I will send you the copy of the Philips 32MF337B Repair Manual.
Repair Manual includes Technical Specifications, Connections, and Chassis Overview, Safety Instructions, Warnings, and Notes, Directions for Use, Mechanical Instructions, Service Modes, Error Codes, and Fault Finding, Block Diagrams, Test Point Overview and Waveforms, Circuit Diagrams and PWB Layouts, Alignments, Circuit Descriptions, Abbreviation List and IC Data Sheets, Spare Parts List.
Jdvillanueva
Oct 16, 2011 | Philips 32MF337B 32 in. LCD Television
I have a proscan model 40LD45Q and it will turn on for about 1 min then turn off, when i turn it back on as soon as the picture comes up the tv will shut down. this is a cheep tv and sending it off to get...
I have two ideas, first there may be only a loosed connection and cold solder the second power supply if your unit tends to work when warm up this indicates the thermal intermittent problem like I said due to loosed connection or cold solder and the second is the bulging up or leaky capacitor if your capacitor is faulty this will cause a low and unfiltered dc output voltage it will not properly transfer dc output to other parts of your tv. But if you are familiar with electronic parts and have proper tools you can fix it by your self but if not i suggest that you should contact a technician to do it for you, it will not cost you a lot of money. Good day and best regards.
Aug 01, 2011 | Proscan 40LD45Q TV
Can't get the DVD player to play on new TV
turn dvd off ,unplug cables, turn dvd on, plug cables back in
Mar 11, 2009 | Proscan 32LA30Q Television
Televison & Video Logo
122 people viewed this question
Top Proscan Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you a Proscan Televison and Video Expert? Answer questions, earn points and help others
