Question about Fisher and Paykel Washing Machines
Fisher@paykel washing machine where to find a filter
Leaves sandy residue on clothing
    Sergeant:
  • 264 Answers
Check your pump down at the bottom of the machine take the bottom plinth off the plastic that runs along the bottom of the machine once off on the right hand side you will see your pump you will need to undo the black screw and get your self a towel and a small and big bowl there will be a lot of water so when you have took the screw out start turning the pump cap very slowly and when you have filled the small bowl close it and keep repeating it till all water is gone then take it right out if its stuck then pull it clean it out and put back together don't for get to turn your machine off be for doing any thing ok hope i have helped if after you have done the pump and the machine still do the same thing then its programmer ok
Posted on Nov 03, 2012
TechBrian
  • 15 Answers
SOURCE: Blocked filter in Fisher & Paykel washing machine top loader
Fisher & Paykel washers do not have lint filters inside the tubs as they are designed to drain away any debris from the wash during the drain cycle.
Posted on Mar 10, 2009
RescueTech
  • 145 Answers
SOURCE: Fisher Paykel washing machine model # GWL15 drips
Hi Dale..
It sounds like you have a leaky inlet valve assembly. The part number is 421029P and is easy to replace. You can get one here:
http://www.fisherpaykelparts.net/ecart/item.php?item_id=266&category_id=56
Posted on Apr 20, 2009
  • 245 Answers
SOURCE: My Maytag washing machine leaves residue (lint? soap?) on clothes
us liqwid soap us les chang filter.to meny close can trap the dry stuf.
Posted on Jan 25, 2010
  • 3 Answers
SOURCE: fisher & paykel washing machine fault codes
I have a Fisher & Paykel GW609AU Smartdrive Excellence 6.5 Washing Machine that would start then stop then start then stop a few more times before eventually beeping.
I fixed it by bypassing(joined the white and yellow wire) the trip out switch which is located under the control module(one screw to remove).Now it Works.
Posted on Feb 20, 2010
SOURCE: GW52F Fisher and Paykel Washing Machine
You are better off swapping the valves over in the machine until you can buy a replacement valve. I've done this for a month or so until I replaced the valve. Works as long as you only use a cold wash and your cold water is not too cold as to make the machine want to add some hot. If it does this then simply press start to clear the fault.
Posted on Jul 14, 2012
I am getting a lot of lint on clothing is there a cleaning process with my smart drive pride 5.5 fisher & paykel washing machine
clean the lint filter in the machine
put any clothes that are likely to shed lint or are susceptible to collecting lint in a wash bag before putting in the machine
Oct 17, 2017 | Fisher Washing Machines
Soap residue fisher & paykel top loader
Agitator can be removed easy,Take out the fabric dispenser cup,
Reach down inside the agitator & undo the wing nut, left to undo.
Take out agitator & clean & the bottom of the bowl,
For a more better clean fill machine with hot to high water level & leave soak over night,Do heavy duty wash in the morning to remove scrud.
Feb 10, 2013 | Fisher and Paykel Washing Machines
**** buildup in top load washer. what to do
Unscrew the agitator and wipe out all accumulated muck. Screw agitator back on, and put through a rinse cycle with white vinegar and bicarbonate soda. This will flush any residual scum. You may have to repeat procedure every 6 months.
Dec 03, 2012 | Fisher and Paykel Fisher & Paykel Washer
Dirt after washing
WASH PERFORMANCE INFORMATION
12.1 Creasing
Creasing can be caused by over loading SmartDrive or the dryer. Permanent Press or Delicate
cycles have been designed to minimise creasing as they use a lower spin speed. Do not leave wet
clothes to sit in the washer or laundry basket.
12.2 Soiling
Soiling is the result of insufficient detergent for the load. White clothes are better washed
separately. Separate lightly and heavily soiled items, as clothes can pick up soil from dirty wash
water. Cold water below 20oC does not wash effectively. Select the wash temperature according
to soil type. For example, blood and mud are better washed in cold water, while sweat and oil
based soil wash better in warmer water. Loads made up of articles of varying sizes will wash
better (e.g. full loads of sheets may not wash that well). Hard water requires more detergent than
soft water.
12.3 Linting
Wash lint givers (eg. towels, flannelette sheets) separately from lint collectors (eg. synthetic
fabrics). Over loading SmartDrive can increase the likelihood of linting. Insufficient detergent for
the load can increase linting as there will not be enough detergent to hold the lint in suspension.
Over drying synthetic fabrics in a dryer can cause a build-up of static electricity and result in the
fabrics attracting lint.
12.4 Detergent Residue
Over loading SmartDrive can result in detergent residue being caught in the creases of the
fabrics. If this occurs, decrease the load size. Some detergents need to be pre-dissolved. Check
the instructions for the detergent. Cold ambient temperatures, cold washes or short agitation times
may not let the detergent dissolve properly. In these cases pre-dissolve the detergent.
Overdosing of detergent can also cause residue when foam breaks down and will show as white
specs on the clothing. Poor quality detergents can result in residue.
12.5 Black Marks on Clothes
A build up caused by the interaction of fabric softener and detergent (scrud) can flake off and mark
clothes. Do not use too much fabric softener, maximum 75cc. If this is a problem, it is
recommended that SmartDrive is periodically filled with hot water, plus 1-2 cups of dishwasher
powder and left to soak.
12.6 Grey Marks on Clothes
Not enough detergent for the amount of soil on the clothes can result in grey marks on clothes. If
this is a problem it is recommended that SmartDrive is periodically filled with hot water, plus
detergent and left to soak.
12.7 Dye Transfer
Wash and dry non-colourfast clothes separately. Non colourfast clothes left sitting in a washer or
laundry basket can transfer dye to other clothes.
12.8 Tangling
Washing with too much water (i.e. under loading) can cause the clothes to tangle around each
other. Do not load SmartDrive by wrapping clothes around the agitator.
Aug 11, 2012 | Fisher and Paykel Washing Machines
Fisher and paykel washing machine GW703-U leave black spot on clothes during final spin
12 WASH PERFORMANCE INFORMATION
12.1 Creasing
12.2 Soiling
soft water.
12.3 Linting
12.7 Dye Transfer
12.8 Tangling
Jan 30, 2012 | Fisher and Paykel Washing Machines
Cloths come out of machine dirty the machine is a fisher@paykel aquasmart .machine leaves wash powder marks on cloths.this problem accures on all settings is very noticable on dark cloths. tryed topload...
Hi just read your posting.Now from the information in your posting it tells me you have tried all the settings and cycles and still the soap is present on the clothes at the end of the cycle,Is this correct?Have you tried a cycle with the EFFICIENCY button switched off and in the Regular setting?Have you tried a liquid detergent?Please reply with additional information on the questions and I am sure I can help you rectify this fault.Looking forward to your reply.
Aug 03, 2010 | Fisher and Paykel Washing Machines
Machine leaves lots of lint on clothing
Check lint filter and clean. Make sure you don't leave any Kleenex's in the dryer.
Oct 06, 2009 | Fisher and Paykel WA37TG1 Top Load Stacked...
Mar 10, 2009 | Fisher and Paykel IWL12 Top Load Washer
Washing Machines Logo
35 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Owen Barnes
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
