Question about Fisher and Paykel Washing Machines
How to find filter in Intuitive model
Sandy residue on washing
    Sergeant:
  • 264 Answers
Check your pump down at the bottom of the machine take the bottom plinth off the plastic that runs along the bottom of the machine once off on the right hand side you will see your pump you will need to undo the black screw and get your self a towel and a small and big bowl there will be a lot of water so when you have took the screw out start turning the pump cap very slowly and when you have filled the small bowl close it and keep repeating it till all water is gone then take it right out if its stuck then pull it clean it out and put back together don't for get to turn your machine off be for doing any thing ok hope i have helped if after you have done the pump and the machine still do the same thing then its programmer ok
Posted on Nov 03, 2012
3 Suggested Answers
woodchuck789
  • 4066 Answers
SOURCE: EP calypso SN cm09034 washing badly clothes often
You may have a problem with your pressure switch cutting the water off too soon.
Your pressure switch stops the water and allows it to start the next cycle. It's a switch either in the control panel or at the top of the tub with a small tube connected to it which goes down between the inner and outer tub. As the water level increases the air in the tube is compressed until there is enough pressure to "make the switch" stopping the water from filling. This tube can get clogged and the switch won't work. Remove the tube and clean it out. Blowing on the tube when it's still connected to the switch will make the switch if it's working and clear.
Posted on Mar 12, 2011
  • 64 Answers
SOURCE: Washing Machine Intuitive Eco model number IW811 won't power on?
Possible Cause Solution The power switch is not turned on at the wall. Unplug the machine from the wall. Wait 60 seconds, plug back in and turn the power back on again. The household power supply is at fault. Try plugging another electrical appliance into the power slot.
Posted on Aug 06, 2012
My glasses end up with sandy residue. Is there a filer and where
no filter like you think the sandy residue is from the detergent and that is because your water is not hot enough.
Mar 14, 2015 | Dishwashers
Sandy residue
Are you on public water or a well? If you are on a well, you may need to replace the screen on the well point.
Jan 03, 2014 | Samsung Washing Machines
I have a sandy residue on the glasses in the upper shelf after washing--model is Whirlpool Gold GU980SC
The scum, film and white residue problems have started since the reduction of phosphates in dishwasher detergents.
Here is a tip that will help you to solve the problem of films, residue, and scum in your dishwasher.
Dishwasher Residue and Film on Dishes
heatman101
0-0
Sep 22, 2010 | Whirlpool GU2475XTV Builtin Dishwasher
I have intuitive eco washer and it is turning out washing with sand and grit on it. I have done a bowl clean and removed the agitator to clean it and no change.
Lusia SGrow, this model machine has a "deep cycle" automatic bowl clean that is supposed to remove lint, any residue from using fabric softener etc. So I am sure that is what they mean. NOT removing the actual bowl.
Jun 14, 2010 | Fisher and Paykel Fisher Paykel Intuitive...
We get a gritty / sandy residue. what can I do?
The cause may not be your dishwasher.
Especially hard water may leave the residue. If you don't have that problem when you hand-wash, then check your pipes. Homes more than 40 years old may have galvanized pipes that eventually rust on the inside. The grit could be grains of rust from the pipes. If you do have galvanized pipes (rather than copper) then you may need to replace them. You could put in a filter as a temporary work-around, but that will eventually clog with the gritty material.
Feb 16, 2010 | Bosch Dishwashers
My whirlpool gold doesnt clean properly there is a sandy residue
Sounds like you have a calcium issue with your water. if you have a water softner time to get it serviced. also you can get a cleaner for the dishwasher to clean it out called Dishwasher Magic.
Dec 04, 2008 | Whirlpool Gold 24 in. Built-In Dishwasher...
Sandy glasses
Are you making sure your heater is ok??Water temp should be taken and be 120 or hotter.If its not turn up water heater temperature.If heating coil is not working replace it.It provides the heat to the D/W and aids in the heated Dry cycle.The solution for spotted/foggy glass problems all  start with making sure your water is Hot enough.Rinse aid is the second.
May 03, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
Washing Machines Logo
22 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Owen Barnes
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
