Question about Whirlpool Dishwashers
Whirlpool dishwasher model # du945pwp02 control panel
5 Suggested Answers
  • 188 Answers
SOURCE: Whirlpool GU2500XTP dishwasher went dead in mid-cycle.
"Wondering if this model has had reliability issues with the circuit card." ...If by circuit card you mean the electronic control board, that part number is used in many other models as well. In my experience with these control boards, I believe they have a low failure rate.
Make these checks if you haven't done so yet...
Check for 120V (breaker). Look for loose/shorted wiring connection at the dishwasher's junction box. Check all wiring connections to the control panel, electronic control and thermal fuse. Test the continuity of the thermal fuse (part # 8193762). If that's ok, you have already replaced the control panel so the problem is likely with the electronic control board (part # 8564546).
Good luck.
Posted on Mar 12, 2009
  • 33 Answers
SOURCE: Whirlpool GU1500 XTLS Dishwasher, need control panel part number
Just go to this site and you will find the part you are looking for.
http://tiny.cc/z5Sy6
Posted on Sep 12, 2009
Testimonial: "Love that he told me what part he thinks it is but why is ther 3 different parts that look exactly the same on this page he sent me to. Very Confusing"
Mackmech11
  • 122 Answers
SOURCE: Whirlpool Gold Silent Partner IV Dishwasher -
I think the problem here is there is water in the control panel. this can happen and short the other buttons out the cancel has its own circuit. I would recommend changing the control panel.
Posted on Apr 24, 2010
oldTech2332
  • 2341 Answers
SOURCE: whirlpool dishwasher model DU945PWP02 will
A lot of times issues with your type dishwasher can be resolved by resetting the control board. This tip i wrote will show ya how to reset the board,but in addation to it not starting do any of the lights blink a certain number of times then pause then blink that same amount of times again?? if yes the number of times the light blinks it telling ya what number error code is being displayed.
Here is that tip to reset the board, http://www1.fixya.com/support/r10357661-get_whirlpool_dishwasher_start_when
GENE
Posted on Sep 23, 2011
I have a Whirlpool Quiet Partner Two dishwasher. The rinse only light & quick wash light constantly blink and I can't run it, none of the buttons will work. Is there a way I can reset my dishwasher?
This generally means the control panel is no longer working and must be replaced. That's the entire plastic assembly at the top of the door, in which the buttons reside. Disconnect power first, remove screws inside the door which hold the panel in place. Unplug power connectors, remove circuit board control board. Find dishwasher model number and search parts for that model. The part is pricey, more than $100 last time I replaced mine. Install control board into new panel, make power connection. Reassemble door. Good to go.
Oct 03, 2015 | Whirlpool Dishwashers
Whirlpoool model du920pfgb3--touch pad is not responding and no lights or nothing are on??
Control panel. Try to push cancel button to see if it resets.if not google it and they will walk you through it.
Mar 28, 2013 | Whirlpool Gold 24 in. Built-In Dishwasher...
My quiet partner 111 whirlpool dishwasher is flashing clean
Hello.
Manufactured by Whirlpool, Kenmore dishwashers have an electronic control panel that must be unlocked in order to set or make changes to your dishwashing cycle. If an error light is blinking on your dishwasher's control panel, the panel must be reset before you can gain access. Blinking lights on your dishwasher control panel may signal a mechanical problem that needs to be repaired. If the lights continue to blink after you've reset the control panel, contact Sears to service your Kenmore dishwasher or consider troubleshooting the appliance yourself.
1Press and hold the "Heated Dry" button on your Kenmore dishwasher for four seconds to unlock the dishwasher control panel.
2 Press the "Heated Dry," "Normal Wash," "Heated Dry" and "Normal Wash" buttons one after the other, in fairly quick succession.
3 Wait for the dishwasher to run a short diagnostic test.
4 Press the "Cancel/Drain" button at the end of the diagnostic test cycle. This should reset the control panel on your Kenmore dishwasher.
Thanks.
Nov 04, 2011 | Whirlpool GU2400XTP Built-in Dishwasher
Whirlpool dishwasher model DU945PWP02 will not start.
GENE
Sep 23, 2011 | Dishwashers
Whirlpool Gold Silent Partner IV Dishwasher - model Anyway, my PROBLEM is that the control panel isn't working!!! At all!!! Only the cancel button works... Do you have any solutions?
Apr 23, 2010 | Whirlpool GU2400XTP Built-in Dishwasher
No power going to front panel on whirlpool dishwasher gu2455xtsso
If the model number you listed this question under is correct, there is a thermal fuse (also known as a bi-metal) located inside the control panel of the dishwasher. The part number for the thermal fuse replacement is W10258275.
If you type in your model number you can utilize the exploded view parts diagrams at pcappliancerepair.com, appliancepartspros.com or searspartdirect.com to assist you in locating the part. The fuse is listed as item 6 under the "Control Panel Parts" section.
To replace the fuse, follow these steps:
1. Make sure the dishwasher is unplugged or the breaker is turned off.
2. Open the door and remove only the top screws directly behind the control panel.
3. Remove the protective cover from back of the control panel to expose the main control board.
The thermal fuse should be mounted to the control board. If you remove it and take a resistance check, it should read close to 0 ohms, if good. If bad, replace as necessary.
If you have any questions about this repair, or require additional assistance, please let me know. I hope this helps you.
Control panel on my whirlpool dishwaher not functioning properly
The console (control panel) is defective. The buttons may be getting stuck and/or are corroded.
Feb 20, 2009 | Whirlpool 24 in. ADG7540 Built-in...
Dishwashers Logo
32 people viewed this question
Top Whirlpool Dishwashers Experts
Mike
Owen Barnes
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
