Question about Mastercool 67471 Evaporative Cooler Air Conditioner
Control panel lights constantly flashing
I have a bonaire vulcan evaporative heating and cooling system. i can get the air con to work, but the control panel is constantly blinking and lights are flashing all ovver the place. Is there some way i can reset this ?
  • barb_walls21 Jan 05, 2009
    Hi Dustin 358
    thanx for your solution, I tried turning the power off but it did not do anything.
  • 30 Answers
You should have a dedicated line that feeds the equipment power look at your main electrical panel or search around your equipment for a pull out disconnect switch or sometimes they will wire it to a light switch. by shutting down the main power and turning it back on it should reset anything.
Posted on Jan 05, 2009
Bonaire vulcan comfort control
No it cant really be fitted as the evap system uses much larger duct and also in some cases people use a different type of duct that when running a gas heater threw it it tends to melt with the heat. Your best option would be to get new ducting that way you can size it correctly so you dont have air alance issues down the track.
May 10, 2014 | Heating & Cooling
Bonaire vulcan summerbreeze evaporative Aircon
seems like your variable fan is faulty. If it is very slow, the coil inside ices up and no air can flow through the coil. It needs to be checked. To many tricky parts to remove with sensors in the way. very easy to break
Jan 30, 2014 | Heating & Cooling
Bonaire vulcan evaporative air conditioner
check your filter for dirts, clean or change it, check your evaporator and condenser coil and clean....
Jan 29, 2014 | Heating & Cooling
I have an evaporative cooler: vulcan bonaire. the only control buttons which appear to be useful are: on/off, cool in the 'appliance' window, and cool in the 'mode' window. i have a feeling that this is...
Hi and welcome to FixYa. The principle of operation of an evaporative cooler is to provide cooler air via evaporation. The evaporation process is achieved by water being pumped over very porous pads with air is drawn through the pads. Most all evaporative coolers unless connected with a centralized heat / cool system only have an on / off & cool function. "On" is fan only (air circulation while using outside air being drawn into the home) and "cool" turns on the pump to pump water over the pads for evaporative cooling. Hopefully I did not confuse you with my answer.
Happy New Year and thanks for choosing FixYa,
Kelly
Jan 01, 2011 | Heating & Cooling
User Manual
You should be able to to the information from this link
http://www.climatehouse.com.au/
Dec 12, 2009 | Mastercool 67471 Evaporative Cooler Air...
Vulcan bonair evaperative cooling unit will not operaate when switched on
If shut down at end of season by air con person may be switched off in roof unit. just remove one side and should have switch in unit usually near pump
Nov 01, 2009 | Mastercool 67471 Evaporative Cooler Air...
We have a Vulcan Bonaire evaporative cooling unit and the control panel is currently flashing on and off and there is a really annoying beeping sound every 30 seconds. We bought this house with the system...
The problem may be with the drainpump not functioning properly. They sometimes clog up with scale. Easy to remove and clean by opening up the unit. Some units also have an alarm function when the cell pads need replacing. Again this one would be able to see visually. They simply slide out, you would have to locate a supplier and just buy four cellpads.
Mar 03, 2009 | Mastercool 67471 Evaporative Cooler Air...
Bonaire Cooling system that stopped working after power failure..
Unplug the unit or turn off the breaker to the unit for at least 30 seconds. If this reset does not work, the electronics may be damaged and need a repair person.
Jan 30, 2009 | Mastercool 67471 Evaporative Cooler Air...
Vulcan-Bonaire : summer breeze
This unit is a cooling unit only. I don't know what switch you are looking at but I don't think it's for the evap. cooler(swamp cooler). I am in the Phoenix, Arizona area and it's very common to have a evap. cooler and a seperate heat/cool system as on the hottest days the evap. cooler doesn't cool enough. I hope this helps. Please give me a positive rating. Thank you.
Jan 27, 2009 | Mastercool 67471 Evaporative Cooler Air...
Mastercool 67471 Evaporative Cooler Air Conditioner Logo
590 people viewed this question
Top Mastercool Heating & Cooling Experts
Bill Long
Dan Webster
Dan Webster
acrman404a
Level 1 Expert
Are you a Mastercool Heating and Cooling Expert? Answer questions, earn points and help others
