Question about Radio Communications
Worldstar MG-6100 Multiband Radio AM/FM ShortWave CB TV
PyroMan6x9x9
  • 150 Answers
SOURCE: cb radio
Not without some serious board modification.
Posted on Sep 15, 2007
wyoed1
  • 211 Answers
SOURCE: 75-822 midland radio
You have a bad detector in the radio. Needs serviced. Change the bad detector diode and it should work. Good Luck
Ed
NC Electronic
Mills, Wyoming
Posted on Jan 07, 2008
tbirdfan1
  • 3051 Answers
SOURCE: With my CB I am getting feedback through the am fm radio speakers
Hello there:
the shielded coax rgu-45 series is probably the best one for this application also if you run the radio to a different fuse or u can also get a surpression filter that goes on the coax line I own a WL9000 KW. i had the same problem untill i got the filter installed at a loves truck stop in texas and no more problems since ok?
drive safe and best regards mike (warner transp.)
Posted on Aug 17, 2009
  • 773 Answers
SOURCE: please explain a 10 meter am/fm radio
Okay.
You do set this up like a regular CB. The meters refers to how long the waves are. CB is 11 meters. So its very close. The antenna woud be tuneds slightly shorter. Use the SWR meter in the radio to calibrate just like you would a normal cb.
Now for the ABCDEF knob. each letter is 40 channels in the band. So A would be 1 - 40 channels, then B would be the next 1 - 40 channel frequencies. You use the frequency counter in the radio(providing that model has one) to tell what channel you are on.
Here is some info one the frequencies in the band.
Now for AM and FM. this is the type of modulation you are using for transmit and receive.
CB transmits on AM or SSB. Amplitude modulation or Single side band. Most CB radios only have AM. But some also have SSB. None will have FM.
FM is frequency modulation.
10 meter radios can have AM FM SSB and DSB depending on the model and options it comes with.
So your radio has 6 ranges for freqency. each is 40 or 50 channesl. Not sure what model you have. If it has 40 then you have 240 channel freqencies.
with AM and FM, you double that, because you can talk on AM or FM on all the channels. If you are on AM and some one transmits on FM unless they are really close, you will not hear them at all, but if you do with will just be garbbled noise.
Also Am and FM both work a little different with range etc.
Now, you may be able to talk on the CB channels as well. Cb starts at 26.965 MHz and ends at 27.405 MHz. The channels are all .010 MHz appart.
Hope this helps
Posted on Dec 09, 2009
  • 1274 Answers
SOURCE: cb transmit noise
Its just RF feed back, that's normal, try to re-route the coax, or just turn the FM down, o try turning your modulation down....hope this was helpful....
Posted on May 29, 2010
Manual for grundig 750 radio
Here is a link to the manual for your radio.
http://www.etoncorp.com/sites/default/files/GS750_Manual.pdf
Dec 11, 2014 | Grundig Eton Satellite 750...
External antenna
what type of radio is it??? that would determine the antenna.
1/4 wave antennas calc... 234 / frequency will give your the length of the antenna...
Nov 29, 2013 | Radio Communications
Finals for Cobra 19DX IV...where can i buy them?
cost of finals plus S&H plus labor. cheaper to buy a new one and have that one for parts. H&Y electronics has them but you have to call them to make sure they do.
Aug 22, 2013 | Cobra 19dx Iv Eu Multiband Am Fm Cb Radio...
Will a cobra power mic cure the low mod on my cobra 19 dx iv eu or will it blow the front of the rig
that is simply bs, Ham radio shops rarely like CB people (I am a long time cber and also a ham.
On that radio there are two things you can do, look for the mod limiter and remove it or another more simple thing:
This radio comes with a 1000 ohm element in the mic--like speakers---Get a older or new 500 ohm microphone and wire it or have it wired for the 19 dx, it will make a big difference in how it sounds.
I not only worked on those radios but sold them in a shop I owned.
You might find a used mic that's 500 ohm, it is usually stamped into the back case of a mic.
Dec 19, 2012 | Cobra 19dx Iv Eu Multiband Am Fm Cb Radio...
Realistic DX300 shortwave do not receive
you may have to change caps and some transistors.
Aug 06, 2012 | Radio Shack Dx-302 Shortwave Am/usb/lsb-cw...
My is newer and dont have d203 so what do i need to do
hello your radio transmits on 27mhz and yes it is shortwave
Jan 15, 2011 | Uniden PRO510XL 40-Channels Base CB Radio
Sony ICF 2010 Shortwave scan does not scan, it beeps.
It will not scan blank memories and it will not scan on search function till you specify a frequency range.
Rod
Jan 30, 2009 | Sony ICF-2010 AM/FM/SW Radio
Users manual for the grundig g5 shortwave radio
I can't find one either but there is a downloadable manual for the Eton E5 at Retrevo.com  Just search for Eton E5
Jan 24, 2008 | Grundig YB 400PE AM/FM/SW Radio
Sony CDX-GT360S NO AM OR SHORTWAVE RECEIVE
am fm receiption not the same most likely antenna make sure the antenna wire fit tightly in radio cheers
Jan 08, 2008 | Sony XPLOD CDX-GT200 CD Player
Radio Communications Logo
135 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Are you a Radio Communication Expert? Answer questions, earn points and help others
