I have an LG front load washer model number WM2487HRMA that keeps displaying an FE error code. Can someone please tell me what this means and how to fix it??
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 35 Answers
I HAVE NOT SEEN THIS ONE BUT THERE IS ONE THE CODE LOOKS LIKE THIS tE IF THIS IS THE ONE YOUR GETTING THE TESTAT FOR THE HEATER IS BAD ARE THE WIRE TO IT IS BROKE LG HAD A PROBLOM WITH THIS ON ALL THERE WASHERS THAT HAD THE HEATER ON IT
Posted on Nov 02, 2012
duby1990
  • 370 Answers
SOURCE: Front Loading washer Kenmore Ht3
Here are the steps to unlocking the door manually if clothes are still in the machine.
1.Unplug machine
2.remove bottom panel
3.Reach up along the inside of the front panel and locate the botttom of the door latch assembly
4.Located on the bottom of the door latch assembly is a tear dropped shaped tab
5. Gently pull down on the tab about a 1/4 inch or until a click is heard.
6. You may now open the door.
This code means the door lock mechanism has failed or the central control unit has failed. Replace the door lock mech. first. This should fix the problem. (before replacing anything make sure there is no obstruction around the switch or in the switch.) After the machine has been unplugged it may fix itself. if not replace door lock mech.
Posted on Nov 21, 2008
jyackle5
  • 8197 Answers
SOURCE: error code f24
F24 indicates a water temperature sensor error. If during the wash cycle in the water-heating step, the water temperature sensor (NTC) value is out of range the F24 error code will display.
Possible causes:
  • Too cold of water or hot water is turned off
  • Temperature sensor failure or loose connection
  • Control board failure
Posted on Dec 18, 2008
SOURCE: Kenmore Elite He5t Washer Error F24
If it is not the plug at the bottom is ok and the temp. sensor is ok.Check the plug on the CCU on top mine was not even plugged in. When I plugged it in the washer started working. You have to take the top off to get to it,but it is easy. Three screws on the back top and the top will slide off easily. There is a troubleshooting manual in the front bottom panel on right side of panel. Page 10 troubleshoots the temp. sensor. The book gives you all the troubleshooting codes. The front panel comes off easily by unscrewing three screws on the very bottom of the panel.
Posted on Feb 08, 2009
  • 4 Answers
SOURCE: lg intello washer error code cl
fault code "cl".you have your child lock function on.push the two child lock buttons together on the control panel,hold them for a few seconds till the "cl" icon dissapears
Posted on Feb 18, 2009
  • 53 Answers
SOURCE: OE ERROR CODE APPEARS ON DISPLAY
OE - drain error - 5 minute time out drain time error. check your pump/filter for blockages
Posted on Oct 14, 2009
Front load washer LG wm2140cw with error code up side down FE. Any ideas what this means? Will start to run then error code shows up and it stops.
A tE error code on the display of the washer indicates a heating error, usually caused by a faulty thermistor.
  1. Unplug the washer from the power outlet for 10 seconds.
  2. Plug the washer back in and press the POWER button and then the SPIN SPEED button until No Spin is selected. Press the START/PAUSE button.
  3. Once the washer has drained, restart the wash cycle.
  4. If the tE error code appears again, close the water taps and unplug the washer. The washer will require repair service.
Apr 06, 2015 | LG Washing Machines
Code fe on lg what does this mean
This fe error or fault code indicates that the washer is overfilling due to a defective water inlet valve. The valve is not repairable and will need to be replaced.
Mar 01, 2014 | LG WM-2077C Front Load Washer
My Lg problem is FE?What Ihave to do?
Turn the water taps clockwise to close them and unplug the washer if "FE" or "PE" appears on the display. The "FE" error means the water valve is faulty and the washer is overfilling. "PE" means the water level sensor is faulty.
Hope helps.
Sep 11, 2011 | LG WM-2277HW Front Load Washer
I have a LG washer model WM2487 H*M suddendly water started coming out from underneath and also the front panel shows a light saying FE....I read that means something about is due the faulty water...
FE = Fill Error. Not a faulty water valve in your case. (FE codes if it takes too long to fill the machine, but if the water is leaking out, the valve is not the problem, the leak is) If you take the back cover off, you might be able to see where the water is comming from. Possibly the black rubber hose from the tub to the pump has a leak.
Mar 17, 2011 | LG WM2487HWMA Front Load Stacked Washer /...
My LG washer TROMM displays the code FE what does that mean?
Overflow error.
Water level frequency is over 213
If FE is displayed the drain pump will kick in to prevent flooding.
Might be a bad water valve OR it could be a clogged water pressure tubing (from tub to control)
Your tech service manual and some notes are HERE
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Oct 19, 2010 | LG WM1812C Front Load Washer
Error codes
Here are the common error codes for the LG machines.
LG Washing Machine Error or Fault Codes
If you have a LG Washing Machine you may see an error code come up and wonder what it is. Here are the common error or fault codes that will be displayed on the LG machine.
OE
This means that the washer has tried for ten minutes to drain the water out of your machine and the water did not drain out.
UE
This means that the load in the drum is out of balance causing excessive vibration when spinning.
IE
This means that the washer has not filled with water in 8 minutes.
LE
This means that the motor and the control panel are not talking to each other properly
PF
Power Failure – The power has gone out to the machine and then has come back on
FE
This means that there is too much water in the machine
PE
This means that the water level sensor is not working properly
CE
The washer motor has received and over current condition
TE
This means that your heating sensor is not working properly
SE
This means that you had a temporary sensor error
HE
This means that you had a temporary heater problem
DHE
This means that you had a temporary dry heater problem
This will give you a basic idea of what has caused your error code.
Heatman101
Mar 15, 2010 | LG WM2277H Front Load Washer
Our LG model WM2032HW intermittently show up with th FE code what could be wrong and can it be fixed by us?
FE error code means water is overflowing. The water is over 8 level.When FE is displayed, the drain pump will operate to drain water automatically. Otherwise the pressure switch assembly is malfunctioning. Check and replace if necessary. Part number is 6600FA1704X.
The pressure switch assembly shuts off the water inlet valve when the desired water level is reached. It then activates the drain pump when the water inlet valve is not deactivated.
Oct 18, 2009 | LG 4.0 Cu. Ft. 7-Cycle Front-Load Washer -...
Lg intello washer error code cl
Jan 29, 2009 | LG WM-2277HW Front Load Washer
LG Sense Clean DD error code "FE" front loader washer/dryer combo
my lg senseclean wash mashine shows the sign Cl on the display and the door cannot be open what does it mean?
Jan 03, 2009 | LG 4.0 Cu. Ft. 7-Cycle Front-Load Washer -...
FE code displays
Yes, the water valves are easy to locate and replace.  Just remove the top panel to get access to them.  There are 2 of them.  You need to know which one to replace before ordering the correct part from LG.
Mar 05, 2008 | LG WM2277H Front Load Washer
Washing Machines Logo
143 people viewed this question
Top Washing Machines Experts
