Question about Dryers
White knight tumble dryer door catch wont close
    Top Expert:
  • Dryers Master
  • 9,472 Answers
What is the model number of your unit?
Posted on Nov 02, 2012
SOURCE: tumble dryer drum willnot revolve.
i have a white knight dryer drive belt snapped how do i fit new one model cl382wv thanks
Posted on Dec 16, 2008
dragonsthatk
  • 547 Answers
SOURCE: cannot get into back of tumble dryer to fit new belt
Hi welcome to Fixya
You must pop off the top of the dryer then remove the front after the front is off you can remove drum .
The belt goes around the drum and the motor pully and under the tentioner wheel after you get belt on replace front and top.
PLEASE MAKE SURE TO UNPLUG FROM POWER THIS IS 220volts AND CAN HURT YOU BAD
Thank You For Useing Fixya
PLEASE RATE ME
Posted on May 02, 2009
SOURCE: White knight tumble dryer making
I have this banging problem, it sounds like a plastic ball rolling about inside it
Posted on Dec 02, 2009
apart4u
  • 213 Answers
SOURCE: WHITE KNIGHT TUMBLE DRYER WILL NOT GET WARM
How to Replace A White Knight Tumble Dryer Heating Element Heater and Thermostat
For a full list of appliance Video Repair help see our video section
White knight tumble dryer not heating this video show you how to change and fit a new heating element and thermostats can be used on Ariston, Electrolux, Ignis, Neutral, Tricity Bendix, Whirlpool,
Here is the element in this video
For all you tumble dryer spare parts click here
The easiest way to find you part is put your model number into our search bar at http://www.apart4u.co.uk/ TEL 08455218000
Posted on May 10, 2010
apart4u
  • 213 Answers
SOURCE: white knight tumble dryer CL432WV wiring diagram
This has lots of diagrams on white knight http://www.apart4u.co.uk/news/category/questions-and-answers/diagrams/
My white knight tumble dryer wont start
Nothing works or drum fails to turn (tumble dryers)
Ensure that the power supply to the dryer is switched on, the timer is set to the desired drying time and the door is correctly closed. If you have a condenser model, also check that the bottle is empty and is fully pushed into the machine.
http://www.whiteknightrange.co.uk/whiteknight/faq.html
The first thing to establish when troubleshooting the clothes dryer is whether the dryer will start or not. If it won't, start by checking the outlet and the circuit breaker. Is the dryer plugged in or has it tripped the circuit breaker? If the breaker has been tripped, flip it back on and try the dryer again. The drum should turn without a problem.
If both plug and breaker are fine, you'll need to inspect the door switch as you continue to troubleshoot the tumble dryer. When you close the door on the dryer, a plastic peg should click and operate the switch which allows the dryer to work. The peg might be bent or broken, in which case it won't connect with the switch. You can try to straighten the peg, but if it's broken, you'll need to replace it. If the peg is fine, the switch has probably failed and will need to be replaced.
http://www.doityourself.com/stry/troubleshooting-a-clothes-dryer-drum-doesnt-tumble#b#ixzz3FOOQgtAT
Oct 06, 2014 | White Knight Press Genuine Tumble Dryer...
Hi does anyone know how to replace door gasket on white knight 44aw dryer
Look under the lip near the mounting area. There should be a spring, just gently pull it around till it is 180 degree or more . it will fall off.
Jul 26, 2014 | White Knight Press 44AW White Tumble Dryer
How to replace door handle on a White knight tumble?
quicker and easier to replace the door, cheaper in the long run.
Jul 23, 2014 | White Knight Press Genuine Tumble Dryer...
How to adjust door on white knight tumble dryer
Micro switch may need adjustment as when pressure applied to door the dryer operates. It may be the operating arm (if there is one) needs to be bent out slightly. I switch has a button operator then maybe an adjustment of switch position will fix. If not try gluing a small piece of plastic to the door where the operator pin is and this may work.
May 30, 2014 | Dryers
White knight
The replacement belt could have been installed incorrectly.
Nov 03, 2013 | Washing Machines
White knight tumble dryer wont switch on (44a)model push the switch no click
hello check inside the door to see if the long pin hasn't snaped off this connects to the interlock that activates the motor if this is ok check the capacitor next to the motor this gives the motor a boost at switch on hope it helps
regards
shaun
Mar 12, 2011 | Abbaka White Knight 44AW Electric Dryer
Dryers Logo
Top Dryers Experts
