Lamp modules on hp highdef tv wont last hardly a year.had to replace two so far&looks like #3now.both times hp has made them good but this is too much trouble
If the power switch LED is flashing, chances are the set experienced a short duration power interuption. There are two ways to recover. One is to unplug the set from the wall. The other is to hold the power button in for at least 5 seconds. The power button LED will flash quickly indicating a reset. After about a minute the set should be able to be turned on. These TV's experience a very short lifespan, typically about 3000 hours. If the above instructions haven't solved the problem then check the lamp.
Posted on Sep 02, 2009
Richard,
Could be a bad spark gap on the ballast board. Should have a tech come in a do some Hv testing to see whether the ballast should be replaced, could make the difference on getting the lamp to last 1000 hrs or 3000 hrs...
Bill
Posted on Jan 04, 2009
Dec 20, 2012 | Toshiba 52HM95 52" HDTV Projection...
i actually own this tv myself... that striking you here will only occur when the lamp does not fire. as far as lamp life i have found that mitsubishi has the longest lasting bulbs from my experience. i would check to make sure the connector on the lamp is seated properly into the other connector in the tv. if you know your lamp is 100% i would look at replacing the lamp ballast. ive had this tv for a few yrs now and love it.
Oct 17, 2007 | Mitsubishi WD-52525 52" Rear Projection...
Jan 21, 2011 | Mitsubishi WD-52525 52" Rear Projection...
Sep 18, 2010 | Sony KDS-R50XBR1 50" HDTV
Aug 27, 2010 | Sony Grand WEGA KDF-55XS955 55" Rear...
Aug 02, 2010 | Panasonic PT-51G44 51" Rear Projection...
Jun 27, 2010 | Panasonic PT-45LC12 45" Rear Projection...
Mar 25, 2010 | Sony KDF-50E2000 50" HDTV
Sep 04, 2009 | Panasonic PT-61LCX65 61" Rear Projection...
317 people viewed this question
My HP ID5220 picture won't come on. The on button just flashes blue.
