Question about HP Office Equipment & Supplies
My printhead on my designjet 1050c keeps on saying that it needs to reseat i have put a new one in but still the same problem any ideas
2 Suggested Answers
SOURCE: I replace the black ink
This message comes when print head is not fitted or locked properly in the socket, please remove printhead, also check for polythene conver on nozzle that should be also removed.
Posted on Feb 08, 2011
HP DesignJet Z6100 Series - Error "Printhead Replacement Incomplete Restart It"
Time for a new printer. These things are just not worth fixing any more, even many of the large office units are made to break and be scrapped.
Nov 26, 2014 | HP Designjet Z6100 InkJet Printer
On my HP 1050C Designjet I am getting the error 'Check printhead path Type 2. Then it says to switch off.
Hello. The "Check Print Head Path" error is usually a worn out carriage belt on printers more than 5 years old. Open the top cover and examine the area under the belt and look for debris that looks like pencil erasure crumbs. Other possible problems could be the tube system catching on something as the carriage moves, the encoder strip being very dirty or extreme friction between the carriage bushings and the rails they move on. If the belt needs to be replaced, a replacement kit can be purchased at: http://www.lpscomputer.com/c-790-hp-designjet-belt-replacement-kits.aspx
Hope this helps.
Bob
Jan 26, 2011 | HP DesignJet 1050c plus InkJet Printer
I replace the black ink printhead and cleaner for hp designjet 1050c and it keeps telling to reseat the printhead.
Dec 29, 2010 | HP DesignJet 1050c InkJet Printer
HP Designjet 1050C Pluss - Error Code Question
Hi there only can try.
This is a firmware error, meaning your f/w simm is probably bad. You can try reseating the simm. It is behind the small panel in the back of the plotter, that is held on by 4 torq screws. Reseat all the simms that are present and see if that helps. If not, you probably need to purchase a new firmware simm.
Also try looking at
pulling the JetDirect card and then re booting it
Feb 10, 2010 | HP DesignJet 1050c InkJet Printer
HP Designjet 1050c begins to plot, then stops plotting with the error message "Turn of printer, check printhead path". What is the problem?
you need to lubricate the slide bar with some thin oil ( sewing machine oil).put the oil on your finger and then touch the bar this way you wont spil oil into the printer
Nov 03, 2009 | HP DesignJet 1050c InkJet Printer
Hp Deskjet 1050C Plus- Print head error
It is not unheard of to have a bad print head out of the box. I suggest you remove all the print heads and clean the ribbon connectors in the carriage that connect to the print heads. Clean the connectors on the print heads also.
If that does not clear up the problem, you may have a bad trailing cable (carries all the signals to and from the print heads) or a bad carriage.
Parts available at: http://www.lpscomputer.com/c-654-designjet-1050c-1055cm.aspx
Download Service Manual: www.lpscomputer.com/ec/manuals.htm
Jun 09, 2009 | HP DesignJet 1050c plus InkJet Printer
How do you resolve a hp designjet 1050C printhead path (1) - turn power off and check issue
How do you resolve a hp designjet 1050C printhead path (1) - turn power off and check printhead path Type 1
May 20, 2009 | HP DesignJet 1050c InkJet Printer
System Error 060308000008 on HP Designjet 1050C plus
that error show a problem with the pintheads
Remove ALL the Printheads and clean the flex contacts on the
Printheads and in the Carriage Assembly, if that dont solve the problem change printheads, if after that have the same problem call HP, was a hardware error.
Apr 30, 2009 | HP DesignJet 1050c plus InkJet Printer
94 people viewed this question
Seeker5211
Seeker5211
