How can I reformat the hard drive on my old thinkpad laptop so I can load another version of winxp ?
    Scholar:
  • 97 Answers
Assuming you have a copy of XP and the License key, you simply start the computer with the CD inserted. be sure to press the key to start the CD install process when prompted.
after the CD starts, it will ask you if you want to install. Do this accept the agreement and it should prompt you to the fact that you already have an installation. Choose to install over the existing version not as an additional instance.
Here is the key...in the next step it will ask you where to install windows. choose your C:\ drive and delete that partition. you'll have to confirm a couple times. This removes the old data. Then choose the same un-formated partition, allow windows to use all the space and choose NTFS Quick format. let it run and you will have a brand new installation of XP.
Good Luck!
FW
Posted on Jan 04, 2009
    President:
  • 948 Answers
All you need to do is boot your laptop from the XP install cd instead of the hard drive. The install cd asks if you would like to format the partition(s) and prompts you that you are about to erase all data on the drive. To enable booting from the cd drive, press f2 or Del as the computer is booting, go into the BIOS and change the boot sequence so that cd is first instead of hd(some number).
5508859r windows7
You do not have the best version of Win7... you have the cheap one. If you had the fancy Win7 version of even any version of WinXP you could see your files, if the HDD is good. Ask a friend for assistance and plug the USB adapter into another PC. (I have my diagnostics PC with WinXP to avoid the issue.)
Jun 27, 2014 | Gateway 5508859r - Hd 160gb Ata Ide
150gb sata formated hdd not recongized by lenovo 3000 n200
ok..let's do one thing at a time...can you boot to F2, and see what your bios states is the case?
May 25, 2008 | Lenovo 160GB FDE 5400rpm SATA for ThinkPad...
Have an older T23 IBM Thinkpad. Was running Malwarebyts which I just loaded on the system due to a problem at work and wonted to make sure i was ok at home. System ran for aprox 32 min and apeard to lock...
This is a possibility, the T23 is a very old laptop.
Normal 0 Check the BIOS to see if the hard disk is detected, if not open then re-seat the hard drive.
If the BIOS does not detect this hard drive, then the hard drive is probably faulty.
If it was me, I would not waste my time and money trying to get a new hard drive for this ThinkPad.
Disk drive manufacturers do not make small capacity hard drive anymore and the current range of hard drives won't work in your ThinkPad because the BIOS cannot support these hard drives.
Oct 02, 2010 | IBM ThinkPad T40 2373 Notebook
My laptop had been working fine, then the last
Hi yes try this, if no joy come back to me.
Normal 0 MicrosoftInternetExplorer4 st1\:*{behavior:url(#ieooui) } /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} To install new version of XP. Insert XP CD into drive, reboot pc pressing ESC button, or delete in some machines. This takes you into BIOS, change your primary boot device to CDrom, save changes and reboot. Select boot from CD once this appears and wait for files to be installed. Select the part of the hard drive you wish to use for your operating system (usually the largest) and select partition this drive. Delete any previous os, and reformat hard drive. (Be aware this removes everything saved on your hard drive, so always back up first) Re boot afterwards and reinstall operating system.
Jul 10, 2010 | IBM ThinkPad A30 Notebook
Which operating system supports IBM thinkpad 600x
All versions of windows except Vista and Windows 7.
You may find it difficult to purchase Windows version up and including XP.
You may need to install more RAM and a a 6 to 10 Gb hard drive.
The smallest hard drive available is approx 100Gb but the BIOS in the Thinkpad won't support a hard drive this large.
Nov 19, 2009 | IBM ThinkPad 600X Notebook
T30 wont reformat
Sounds like you have a faulty hard drive. Can you see or detect the hard drive in the BIOS? To test the hard drive, remove it from the laptop and connect it to a USB hard drive adapter and plug it into a working computer's USB port. If this computer sees it as an external hard drive and you can open the various folders and files, then it os OK and the fault is in the laptop. If the hard drive is faulty, then you need to replace the hard drive in the laptop and install Windows to get the laptop working again.
Jun 03, 2009 | IBM ThinkPad T30 2366 Notebook
How to reformat R52 ibm thinkpad
Your laptop should have come with a recovery disk, you will need to boot to that disk following the onscreen steps for formatting and restoring the operating system files. Furthermore, if your system did not come with a recovery disk, or you have a Windows XP/Vista disk you can boot to that instead.
Windows XP Install:
After the installation system boots, the setup prompt will prompt you for searching the system for previously installed versions of Windows; bypass the recovery option after the search is complete. The setup will then display a list of Hard Drives to install Windows; follow the key for deleting the partition (press "D" to delete). Once the partition has been deleted highlight the "free hard drive space" and press "Enter" then you will be prompted to format the drive and install Windows. Moreover, you should right down the Windows Product Key off the sticker on the bottom of your laptop; you'll be asked for that key after the setup restarts your computer assuming you are using that license for that version of Windows.
Windows Vista Install:
When you boot to the Vista DVD you will be prompted to enter the product key as soon as the setup loads. Select the Hard Drive with the mouse, then left-click the format button on the right pane. Continue with the installation.
Nov 29, 2008 | IBM ThinkPad R52 Notebook
My ibm wont start up??????
The problem is going to be with either the operating system or the hard drive, and you will need an operating system disc in order to solve this problem. After acquiring an operating system disc you can try an operating system repair. If the repair doesn't take, then try to reformat the drive (NTFS) and install a fresh version of the operating system. If you have any problems during or after the format and fresh install, then the hard drive has failed and needs replaced. A hard drive failure is the most common with this type of problem, but occasionally the operating system will glitch and cause it. Either way you will need an operating system disc if you plan on fixing this yourself.
Jul 23, 2008 | IBM ThinkPad T21 Notebook
Ibm 600x .... cannot detect hard drive larger than 2.1gb .. it can detect 2.1gb below ... i installed winxp on 2.1gb .working fine
ibm is providing their computer with a relevant bios updtes . bios updte will solve most of this type of problems
Dec 02, 2007 | IBM ThinkPad 600X Notebook
Computers & Internet Logo
David Payne
David Payne
