Question about Mitsubishi Televison & Video
Power doesn't turn on
Power light would light but tv didn't now even the power light doesn't turn on. Hooked up to cable box that still works
    Top Expert:
  • Mitsubishi Master
  • 14,553 Answers
If no power light on the set----a fuse in there or a problem with its power supply----Most Mitsubishi sets have a built in error that stores events---what is model number of the Mitsubishi?
Posted on Nov 02, 2012
SOURCE: Samsung HCN4226WX/XAA Rear Projection 42" TV Wont Turn On
take off the back there is a board at the top right with two black stk-392-040 chips on it unplug the red connector at the left side of the board then plug set up and see if it comes on if so the chips on the board are bad or replace the board about $100.00
Posted on Aug 03, 2007
  • 1030 Answers
SOURCE: AKAI 55" Rear Projection TV won't turn on.
the 3d effect tells me that your convergence ic's have blowned. standard for these sets.. not to much of a difficult repair. repair them all the time..
Posted on Dec 13, 2007
  • 2039 Answers
SOURCE: TV won't turn on after power outage
LOT OF TIME WHEN YOU LEAVE IT OFF FOR THE NIGHT DISCONNECT POWER CORD DEFECTIVE SURGE PROTECTOR IS NOT GOOD FORE EVER PLUG TV IN THE WALL WITOUT THE SURGE PROTECTOR IF IT GOOD CHANGE THE SURGE PROTECTOR FOR NEW ONE CHEERS
Posted on Jan 17, 2008
  • 927 Answers
SOURCE: Power button Flashes
Good Day, you all;
The front panel light on Hitachi TV does not really tell you much. To see what the TV is doing or better said NOT doing is remove back from the set.
If you are not a technical type person, it would be better to consult an authorized service center, but if you are perform this; 1. Remove back
2. Observe led and notice which once light, there are as many as 9 LED's.
Now that will tell you what area of the TV's circuits are to be concerned about.
Let me know, Good Luck, big IRISH.
Posted on Aug 06, 2008
Slinteriors
  • 8617 Answers
SOURCE: RCA Proj TV (model D52W14) Power light flashes 3 times
Replace CP150, CP120 and CP114. You can get the repair kit for your RCA at the following link. www.tvrepairworld.com the kit contains the capacitors and the CD with detailed instructions.
Posted on Sep 07, 2009
Atlas ocap
use the camera digital or cell cam and with the remote control viewn see if the LED are ON. see the photo attached.
If do not do it. Open the remote control clean the keypads from corrosion, and resolder any colder joint . clean the contacts batteries and try again.
May 30, 2013 | Televison & Video
Toshiba x205-59349 hdmi doesn't register on the tv
If you hooked up with set and or a box on that may be the issue--HDMI does not like connections being made with units on.
disconnect power from set and or box if used for a while and then with HDMI reconnected power up the set and or box.
Dec 03, 2012 | Toshiba Televison & Video
Have a nx1932w; worked fine until this morning; turn on the monitor (using it as tv) the logo is in black and white and it says no signal - can't even get menu button to work.
the most common problem with LCDs today is failing electrolytic capacitors, especially in the power supply section. Look for bulging, leaking, blown or missing capacitors and replace them.
May 17, 2012 | ViewSonic NX1932W LCD Monitor
My LG 42LV4400 led tv won't turn on. Even the
Someone must open it and check voltages on the power supply board as the first step.
Depending on what is found boards may have to be ordered and installed to KNOW which will fix or not fix the set.
Mar 14, 2012 | LG Televison & Video
My pyle 2200 1400 watt 2 channel amp wont get power..... why!!!!!
did you check the remote turn on wire connection at the back of stereo?
Jan 15, 2012 | Pyle Car Audio & Video
I have a 32" LCD
Tries tv and cable box unplug,replug it back like about an hour later.For the tv to do a resetting itself back to the factory setting.The cable box to reboot and upgraded it software.Than go in to the tv Menu go to Audio Setting go down and do a resetting back to the tv factory setting.By doing these steps u have a great chances to get ur tv audio sound back.Not have the same problems after this than the tv Tuner signal board it is shorted in the audio ICS modjulation sections.Tries websites like Shopjimmy,com,Ebay.com to buy a whole refurbish tv Tuner signal board for the replacement.
Aug 16, 2011 | Televison & Video
I have the amp hooked up and the power light comes on, but there is no power going to my subs.
Check your gains. Make sure they are not turned down all the way. Are you getting audio to the amp. Use an MP3 player with a headphone to RCA cable directly into the amp to make sure your getting sound. Check the speaker wire to the subs. Make sure they didn't get disconnected moving the box around.
Apr 19, 2011 | MA Audio HK797 Car Audio Amplifier
LCD TV is hooked thru cable box. When you use the
Try this (may not work):
1. UNPLUG power from TV at wall outlet.
2. Turn ON the TV (with no power cable plugged in).
3. Plug power cable back in (at wall outlet)
4. Turn ON TV (don't use remote this time).
Hope this works!
Sep 03, 2009 | Televison & Video
Televison & Video Logo
44 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
