Question about Bissell Carpet Cleaner Powerbrush Deep Cleaner Vacuum
Bissell aroma pro upright carpet cleaner wont push foward keeps getting stuck
Brush bar keeps falling out of housing it's attached to two little black arms, one side a drive belt attaches. The brush spins in upright position, but when release pedal to clean carpet it wont push forward
4 Suggested Answers
  • 120 Answers
SOURCE: My Bissell Pro Heat 2X will not release water or
its probably a solenoid that controls the flow to the floor, take it to a bissell repair center, because its not an easy fix.
Posted on Jul 06, 2009
  • 36 Answers
SOURCE: I have a Bissell Pro Heat 2X carpet cleaner and
The reason for the brushes to stop when it is above any surface is there is a switch in the handle that stops the brushes so it dont burn your motor up it may have a faulty switch.
Posted on Jul 31, 2009
Vac Belts
  • 701 Answers
SOURCE: Bissell pro heat steam carpet cleaner, not releasing water.
That means that you need to replace the pump belt. Here is the belt you need and a manual you can view:
Bissell 7901 Belt and Manual
Posted on Mar 02, 2010
Testimonial: "just what I was looking for thank you"
Brushes don't rotate on proheat2X,
How to Replace the Belt & Brushroll on Bissell ProHeat 2X ...
? 2:11
https://www.youtube.com/watch?v=Jj_43IHz9U4
Dec 28, 2012 - Uploaded by eVacuumBags
How to Replace the Belt & Brushroll on Bissell ProHeat 2X Series Carpet ... How to Replace Bissell Deep Cleaner Pump Belt orBrush Belt - Duration: 1:44. ... Won't SPRAY solution Rollers spin Fixing Bissell ProHeat Carpet ...
Brushes Will Not Rotate Deep Clean Essential - YouTube
? 0:53
https://www.youtube.com/watch?v=gbEXY5jkWSc
Apr 9, 2015 - Uploaded by BISSELL
If your machine is turned on and in the upright position yourbrushes will not turn. ... How to Replace the Belt & Brushroll on Bissell ProHeat 2X Series Carpet ... Won't SPRAY solution Rollers spin Fixing Bissell ProHeat Carpet ...
bissell pro heat 2x brushes wont spin Questions & Answers ...
www.fixya.com > Forum > Tags
... bissell pro heat pet 2x and my brushes won't turn or operate... check the belt belts ok brushes won't turn/rotate turn dial on bottom front on the water tank to ...
Feb 03, 2016 | Vacuums
My Bissell Pet Carpet Cleaner brushes will not turn around and heater doesn't work?
Hey you may want to check out our website for assistance in troubleshooting your machine. Here's a quick link to the FAQ page.
http://www.bissell.com/faqs/?cid=ccsocial
Jan 01, 2013 | Bissell 1770 Quicksteamer II Upright...
Whenever I push the Bissell Proheat the brushes catch on carpet
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
yrf45
Mar 09, 2010 | Bissell 7920 ProHeat Pro-Tech Upright...
I have a Bissell Pro Heat Carpet cleaner and the brushes will not turn. The pully is not turning the belt.
if the motor shaft that rotates the belt to turn the brush does`nt turn you have motor problem`s if it does you need to free up what ever is keeping the brush froom turning freely
Nov 06, 2009 | Bissell 7901-1 ProHeat Scotchgard Upright...
Brush not moving in Bissell pro-heat
if the belt is more then 6 months old or more, then the belt will have to be replaced reguardless of the way it lookes. belts can stretch over time and when you put the machine on the carpet the friction causes the brush to stop because the belt has stretched. i would try this first. hope this helps
Jul 30, 2009 | Bissell 7901-1 ProHeat Scotchgard Upright...
Can't figure how to reassemble brush so it won't
there is a clip (sort of "U" shaped) that goes on the side this should take care of your problem.
Apr 16, 2009 | Bissell 7901-1 ProHeat Scotchgard Upright...
My bissell 1699-n is dragging or catching on the carpet
Hi
Please check this user manual which will explain you about the complete information on your vacumm cleaner.
Bissell 1699
Please do accept the solution and revert for any further assistance.
Thanks
Rylee
Mar 25, 2009 | Bissell 1699 ProHeat Clear View Upright...
Help with steam cleaner
DId you push the little button located at the rear of the attachment on the top? It is gray and part of the hose peice. It is what holds it the attachment to the tube
Jan 31, 2009 | Bissell 1699 ProHeat Clear View Upright...
Bissell pro heat advantage 12 amp
You can download the instruction manual at the Bissell.com web site.
Jun 29, 2008 | Bissell 9500 ProHeat 2X CleanShot Upright...
Bissell Carpet Cleaner Powerbrush Deep Cleaner Vacuum Logo
70 people viewed this question
Top Bissell Vacuums Experts
Jim Parker
Jim Parker
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
