Question about Universal Remote Control 2700A DTV Receiver
Set my box up and there is no channel 5
No Channel 5
    Problem Solver:
  • 18 Answers
Hi is it not showin the channel it self i had this problem i changed the box on the wall cos my lead wont fit in it and mine workd may not be whats up with yours but ut helped me i rescaned it came on
Posted on Jan 04, 2009
Connecting a sansui 13 inch to a converter box
1) Connect the converter box to a good digital TV antenna and position the antenna as high and as close to a window as possible.
2) Set the converter box 'output switch' to an unused channel for your area. (Usually 2, 3 or 4.)
3) Connect the output of the converter box to the 'antenna input' on the TV.
4) Turn on both units and set the TV channel to the same output channel selected above.
5) Now select TV channels using the converter box remote only. The TV should receive all converted channels on the preselected channel.
6) Adjust the TV antenna for the best reception for all channels.
May 04, 2014 | Sansui Televison & Video
Hi, my problem is only the front 2 speakers work i have tried all the speakers in the front 2 connections of the unit & all speakers are working but none when in the rear, center, & sub woofer unit...
Without knowing which receiver etc you have... make sure your "mode" is set to 5 channel, Dolby Pro or similar. And even then, make sure your source is 5 channel. What are you using for an input cable? It needs to be able to provide 5 channel. Standard RCA stereo type cords do not. You need either optical, "coax" or hdmi. Lastly do you actually have a 5 channel program? Many older movies, and standard cable boxes only output stereo, not 5 channel.
May 31, 2011 | Audio Players & Recorders
Don't know how to set channels w/new cable box.
Use channel 3 or 4 or hook up the RCA jacks. If you use 3 or 4 leave it on that channel and use the cable box to change channel. Use RCA jacks (best) turn the channel on the recorder to line in ether LINE1 or LINE2 with one you plug it up to and leave it on that channel.
Jul 23, 2009 | Toshiba RD-XS32 DVD Recorder
Cannot get my goodmans 289ns to accept the virgin digital signal
Will the TV go to channel 3? if not you need to reporogram the TV to sence channel 3 or go into the setup and undelete channel 3. Channel 3 is the channel your digital box is set to boradcast to the tv itself.
Apr 22, 2009 | Goodmans 289NS 14" TV
Recording
With your setup, the VCR gets its input from the cable box output, which will be on either channel 3 or 4. It depends on how you've set the box. The channel you are watching on TV or want to record is picked on the cable box.
The VCR will only ever see a channel 3 or 4 signal, so it must stay on that channel. That means when you record, set the VCR to record on channel 3 or 4, the box OUTPUT channel. The biggest mistake people make when they have a cable box is to set the VCR to record on some channel other than 3 or 4, and the result is snow. There's nothing on any other channel for the VCR to record. You also need to have the cable box turned on and set to the channel you want to record if you set the VCR for timer recording. That's another pitfall people meet.
This should get your recording going.
Mar 30, 2009 | Memorex MVR2031 VHS VCR
I installed the converter box on channel 3 instead of channel 4
No reason to delete converter box from channel 3. Most converter boxes have a selection switch on the back for channel 3 or channel 4. Slide switch to 4 and set tv to 4.
Jan 13, 2009 | Televison & Video
Quasar model VV2008 tv/vcr
in side the mother board(kit)  there should be vertical IC gone.   check the vertical section  for  the IC number  and  replace it  ,     this  will solve ur problem
thanks
Oct 26, 2008 | Quasar VV2009 Combo
Programming Quasar VHQ940 for DTV converter box
I assume you're trying to record from the DTV box. You will have to set the DTV box to play through channel 3 then tell the VCR to record channel 3. So basically the VCR always THINKS it's recording channel 3, but in reality it's recording whatever channel the DTV box is on. You will be unable to used timed recording unless you leave the box on whatever channel it is you're wanting to tape.
Aug 05, 2008 | Quasar VHQ940 VHS VCR
My daughter brought her tv home from college without the remote. I'm now trying to hook it up to digital cable. It needs to be on channel 3. When I try to manually change the channel to 3 using the...
The easiest will be to make sure that the cable box is on and sending out a signal to Channel 3 and auto-programming the set. Channel 3 is skipped because the last time it was auto-programmed, there was no signal on that channel.
Dan
Jul 10, 2008 | Televison & Video
Dmr-es10 dvd recorder - cant get the machine to record digital channels form tv
Channels 1-5 are I believe for Analogue reception. To record from my digital Freeview box, I'm plugged into SCART port 2 (bottom most port on right hand side of machine as you look at it from the front). Use your remote to change the channel to A2 with the <CH> rocker button just above the video+ button on the controller. This will then record whatever channel your freeview box is set to - the only pain is you can't watch a separate channel whilste recording.
Kind Regards
Brad
Apr 01, 2008 | Panasonic DMR-ES10 DVD Recorder
Universal Remote Control 2700A DTV Receiver Logo
52 people viewed this question
Top Universal Remote Control Televison & Video Experts
Computer Repairing
Computer Repairing
Are you an Universal Remote Control Televison and Video Expert? Answer questions, earn points and help others
