Question about Motorola Astro Xtl5000 Model M20urs9pw1an 800mhz Uhf Radio Xtl 5000
05/94 error on 05 control head
Control head work as a dash mount but shows 05/94 error when hooked up a a remote head
    Prodigy:
    An expert who has answered 500 questions.
  • 607 Answers
This error message indicates an incorrect connection from main radio and your remote head, Check that you have installed correctly and that all plugs and fittings are snug and not loose.
Otherwise, the remote is cactus, that could be another issue, try without the remote and see if the radio works, the answer lies in either of those.
Hope this helps you.
Cheers,
Peter
Posted on Mar 10, 2013
Indicators, headlight, high beam, Heater showing strange behavior. Can you please suggest what could be the possible reason for it . BCM or Multi Function switch?
Hooking up an OBD2 reader will tell you right away if the BCM is shot or BCM. Take it to advanced auto or O'Riley's they will hook up a an OBD2 reader and tell you. Sounds like a faculty PCM and BCM to me or just faulty PCM since you've replaced the Body Control Module already.
Feb 20, 2015 | 2008 Hyundai Elantra
How to repair dash vents A/C does not come out of dash board vents
no,the problem is the control head.common on these vehicles. or the vacuum diaphram motor behind the control head mounted on the heater box is weak. it could also be a vucuum leak on the hose going to the diaphram from the control head or an internal leak within the control head
May 01, 2014 | 2004 Ford Crown Victoria
Need schematic diagram infinity basslink subwoofer
Design: The BassLink brings together a 10" subwoofer (treated paper cone, foam surround), a 10" passive radiator (to increase efficiency and limit distortion), and an extremely efficient, specially designed 200-watt Class D amplifier that work as an integrated system. Special circuitry monitors voice coil position to maintain linearity at high power levels, so you hear loud, clear bass.
Enclosure Type and Materials: The enclosure is made of an acoustically inert polymer which is rigid enough to resist flexing and dampens any resonance.
Servo-Control: The servo-control system continually monitors the performance of the speaker and ensures that the amplifier delivers exactly the right amount of power.
Class D Amplifier: This unit has a built-in 200 watt Class D amplifier which is highly efficient and designed specifically for use with the subwoofer and passive radiator combination.
Auto Turn-On Feature: When the speaker level inputs are used, the system will automatically turn on and off with the radio. Note: The auto turn-on feature does not operate when the preamp level inputs are used, unless the remote turn-on lead is connected.
Low-Pass Crossover: The low-pass crossover frequency can be varied from 50Hz to 120Hz for a seamless transition between the output of this unit and that of the other speakers in the vehicle. The crossover has a slope of 12dB per octave.
Bass Boost: The amplifier includes a continuously adjustable bass boost from -6 to +3dB centered at 40Hz.
Phase Switch: Allows you to select normal or reverse for best bass.
Mounting: You will be able to put BassLink in a variety of in-vehicle locations, thanks to its compact size and mounting feet that enable the rigid polymer box to be mounted vertically or horizontally.
Vertical Mounting Dimensions:
Width: 14.625"
Height: 13.375" (including feet)
Depth: 8.675" (10.076" including feet)
Horizontal Mounting Dimensions:
Width: 14.625"
Height: 9.5" (including feet)
Depth: 12.75" (15.1875" including feet)
BassLink LC Remote Level Control
Overview: The BassLink LC allows you to adjust the volume of BassLink powered subwoofer.
Installation: The BassLink LC may be mounted under the dash or may be dismantled and mounted inside the dash for a factory appearance.
Under-dash Mounting: Select a mounting location that allows easy, safe access to the control while driving. The BassLink LC has mounting "ears" to use as a template for drilling pilot holes. Attach screws through the "ears" to secure the BassLink LC to the mounting surface.
In-dash Mounting: Disassemble the BassLink LC by removing the Phillips-head screws on the front, rear, and top panels. Remove the bottom and side panels and disengage the RJ11 connector from the back panel. Choose a mounting location that allows easy, safe access to the control, and provides 1-3/4" clearance behind the mounting surface. Drill a 9/32" hole in the mounting surface. Feed the BassLink LC's potentiometer (with the knob removed) through the hold and use the nut provided to hold the control in place.
Connecting to BassLink: Route the cable behind the dash or other interior panels and under the carpet. Do not route the cable outside the vehicle. Connect the cable on both ends.
Inputs and Controls
Inputs:
Universal Interface: Front and rear, left and right Universal interface speaker-level inputs (for use with the supplied speaker-level input wiring harnesses)
Line Level RCA Inputs: Front and rear, left and right female preamp level inputs
+BATT (+12V): Gold-plated screw terminal, 0.350" wide
REM (remote turn-on): Gold-plated screw terminal, 0.350" wide
GND (ground): Gold-plated screw terminal, 0.350" wide
Fuse: There is an installed 20 Amp fuse
Remote Gain Control: Phone type jack for included remote gain control
Controls:
Gain Control: Rotary control that sets gain (variable from 250mV to 4V)
Crossover Control: Rotary control that sets the low-pass crossover point (variable from 50 to 120Hz)
Bass Boost Control: Rotary control that sets bass boost level (variable from -6 to +3dB, centered at 40Hz)
Phase Switch: Selects normal or reverse phase (0 or 180 degrees)
Power LED: The power LED glows red when the BassLink is on
Servo LED: The Servo LED glows green when the servo circuit has determined that the woofer has reached maximum excursion and power to the woofer has been modified to provide maximum performance. The LED should light momentarily during high-level bass transients. Note: Avoid adjustments that cause the LED to remain lit for an extended period of time
Thanks
Apr 01, 2012 | Infinity Bass Link Subwoofer Car Audio...
Hello, I need code for model UC7067RC Hampton Bay ceiling fan. There are numbers 1234 and remote does not work Please help. Thanks
Call Fan Man Lighting in Minnesota at 1-866-600-3267. They have 30 years experience and helped me with my UC7067 problems.
Oct 14, 2009 | Universal Remote Control Hampton Bay...
Tahnks
Yes it does have a starter relay
I believe it is located Front seating area, driver side, behind dash, mounted above gas pedal
Pretty positive. If not there than it would be
Front seating area, driver side, driver side of steering column, behind upper dash panel, mounted above fuse block
Jan 17, 2009 | RCA Universal Remote Control
C D problems
Run a Lens cleaning disc .
Is it an in dash player or a remote(trunk) mounted unit.
You should be able to google the error code to find out where the problem is.
if its a remote unit your cable from the CD to your head unit could be damaged.
Dec 30, 2008 | 2000 Cadillac DeVille
Hi low hiead light switch 82 el camino wher does the rod hook up
should be a switch mounted to the top lower steering column that the rod fits into that operates the high/low beams
Dec 28, 2008 | 1982 Chevrolet El Camino
Hampton bay fan, wall mount remote control
Hello burrow31. There maybe a switch located on the fan stating 'remote/manual'. Check your manual. Remove the battiers in your remote and short out the battery contact terminals. Reinstall the battiers, start the fan and after fan has reached set speed press & hold fan speed button for one second. Still no speed change contact the Mgfr. with model & serial #.
Oct 11, 2008 | Hampton Bay 54 In. 5-Blade Fan, Chestnut,...
Remote
well really u can take the remote wire from the amp to a kill switch mount it on the dash and then the kill swicth to the fuse box. put it on the fuse that says radio hook the remote wire up to that and remember that when u wrap the wire around the fuse make sure that it stays in place . or u could have a bad ground its one of those though and u dont really have to run a swith or a kill swicth u just go srtight from the amp to the fusebox under the dash let me no if any if this info works.
Apr 01, 2008 | AudioBahn A2150HCT Car Audio Amplifier
Motorola Astro Xtl5000 Model M20urs9pw1an 800mhz Uhf Radio Xtl 5000 Logo
446 people viewed this question
Top Motorola Radio Communications Experts
eradiostore
eradiostore
OBHighflyer
Greg Cann
Greg Cann
Are you a Motorola Radio Communication Expert? Answer questions, earn points and help others
