Question about Sharp Microwave Ovens
Error code 8888 Sharp Microwave
Error Code 8888
4 Suggested Answers
futureloginn
  • 734 Answers
SOURCE: I have an error code
Electronic range control failure, Replace electronic range control (ERC)
Posted on Nov 12, 2008
tbreeze47
  • 3083 Answers
SOURCE: Hi. our Sharp R242 Microwave
I saw an answer for this problem on a justanswer.com blog, and although it's for a slightly different model than yours, it's the exact same problem and they mention what to try to fix it:
http://www.justanswer.com/questions/2v2ff-my-microwave-flashes-8888-none-of-the-buttons-work-what
This was my initial thought...that the display isn't receiving information and going into the error code, which would be because of a loose ribbon connector, which carries the signals needed for operation. When you take it apart, be careful not to touch the high voltage capacitors- you can discharge them with a screwdriver blade by shorting them out, or cover them with electrical tape, temporarily.
Here's a web page that talks about how to check various microwave parts, and may be of help to identify the capacitor:
http://www.applianceaid.com/image/component1.JPG
Good luck, and hope this helps you get it fixed.
Posted on Nov 08, 2010
  • 1196 Answers
SOURCE: Sharp Microwave R246. Power Failure
Press the "Off/Clear' button to cancel anything on the display, and reset the microwave. This is a soft reset and will simply get you out of any program you have started. Press it when the cooking complete reminder appears on the display.
Perform a hard reset. Pull the plug out of the wall power supply, and wait a moment. Plug the microwave back into the wall power supply to reset any anomalies with the microwave's memory. You will need to reset the time of day if you perform a hard reset. This should help fix the problem.
Posted on Sep 09, 2011
My Sharp R-240D microwave is flashing 88:88 on the clock. None of the buttons work. How do I get the touch panel to work?
I'm not finding that as a valid US model.
I would suggest checking the label again.
Feel free to contact me directly for more help.
- William E. Miller, AS-EET
pupista@gmail.com
http://www.microwavecontrol.com
Microwave Oven Control Panel Repair Nationwide
"Recycling by repairing since 1982"
May 02, 2017 | Sharp Microwave Ovens
Mod.KHMS155LSS-1 Getting F-6 Fault code ????
Search Results
    Combination Microwave Wall Oven - Error Code/Message ...
    www.kitchenaid.com/...microwave...error-code...f6-error-cod...
    KitchenAidQuestion: Combination Microwave Wall Oven - Error Code/Message - F6 Error Code -F6 E8. Answer. Product Symptom: Combination Microwave Wall Oven ...
    Over-the-Range Microwave - Error Code - Starts with F ...
    www.kitchenaid.com/...microwave-error-code...f...f6...code/P...
    KitchenAidKitchenAid's product help articles give answers to your frequently asked questions (FAQs). ... Microwave - Error Code - Starts with F - Starts with F6 - F6E0 Code.
    Kitchen Aid Oven Model # KEMS308SSS02 error msg - Lost ...
    www.shopyourway.com > Manage My Life > Questions
    I have a Kitchen Aid Model # KEMS308SSS02 and I getting the follow error message... is working and was always working but the top microwave/oven does not work. ...Kitchen Aid Oven Model # KEMS308SSS02 error msg - Lost Err/ F6 E0/ ... Most "F6/E0" fault codes is usually because of a loose wire connections, loss of ...
Feb 05, 2016 | KitchenAid Microwave Ovens
Turned off power will not reset
Unplug wait 3 min plug back in
Jan 14, 2016 | Sharp Microwave Ovens
Sharp microwave 8888 is flashing and I cannot remove
see this steps and fix it. God bless you
Reset the clock. Press "Clock" and the correct time, using the number pads. Press "AM/PM" if applicable, and press "Start" or "Clock" to confirm.
  • 2 Press "Timer On/Off" to reset the timer if nothing on the touch pad will operate. Use the number pads to select a new timed amount, if desired, and press "Timer On/Off" to start. Press again to cancel.
  • 3 Press and hold "Clear/Off" for three seconds if the timer will not function or is blinking when you touch the pads. This will release the "Child Lock" feature. Make a new touch pad selection.
  • 4 Disconnect power to the microwave if following Steps 1 through 3 does not resolve the blinking timer. Wait a few minutes, and then restore power to reset the microwave.
  • However if the problem persist the display board
    main control board is faulty
    Oct 02, 2012 | Sharp Microwave Ovens
    Sharp RCD2200M error code ee2
    this mean shortes thermistor you must replace, but before you must test with VOM.
    see the video .God bless you
    Jul 10, 2012 | Sharp RCD2200M Microwave Oven
    Error 002
    I would contact Sharp directly. I'm not finding any results for a 002 error code.
    May 26, 2012 | Sharp Microwave Ovens
    MODEL E23GT-F 240 VOLT SHARP M/W
    Hello there
    this is tbirdfan1 here is a pict of the megatron for you
    Apr 29, 2010 | Sharp R-22GT Microwave Oven
    I have an error code f-1on my Sharp Microwave Mod R-312A. What is this and how do I correct.
    Nov 12, 2008 | Sharp Microwave Ovens
    Microwave Sharp carousel Model R3A36 keypad not working. We had a brown out due to a recent storm and the microwave keypad didn't work anymore after that. We unplugged and replugged and the light inside is...
    Your keypad has failed.
    It would need a new control panel frame, which comes with the keypad.
    You simply remove the circuit board and plug it into the new frame.
    It is part # FPNLCB070WRK0 and the best place to order Sharp parts is Tritronics.
    Sep 03, 2008 | Sharp Microwave Ovens
    Error code on touchpad....
    EE4 means that the unit is not set to the proper level for the line voltage at the place where it's installed, or that may have a faulty outlet or power line.
    Assuming yours is a Sharp R23-series, we have uploaded the full service here.
    But I've attached an excerpt to show you how to check / set your proper voltage level.
    We're happy to help and we appreciate your thoughtful rating of our answer.
    May 19, 2008 | Sharp R-23GT Microwave Oven
    Microwave Ovens Logo
    180 people viewed this question
    Top Sharp Microwave Ovens Experts
    William Miller
    William Miller
    Devabhakthuni...
    Devabhakthuni...
    Ed Mac
    Are you a Sharp Microwave Oven Expert? Answer questions, earn points and help others
