Question about Garden
Where are the fuse in polaris trailblazer 330
Have gas and spark
  • 68 Answers
SOURCE: i have a 2001 polaris trailblazer and it wont fire.
Did you change your spark plug? Just because you have good spark does not mean the plug is firing under compression or the porcelain is not cracked.
Posted on Mar 25, 2009
SOURCE: my awd won't work. Is there a fuse?
when i bought my polaris, i asked where the fuses were at and he told me that there are not any fuses. He did say that there are some fuseable links somewhere.
Posted on Apr 29, 2009
kel1guy2002
  • 3740 Answers
SOURCE: my 2002 polaris trailblazer wont start it has fire
If you have oil and gas and it will fire then try a new plug. A bad plug when removed will appear to be fine but under compression can fail.
Also try a splash of good gas in the throat of the carb or intake (if fuel injected) with a new spark plug. My bet is it fires just fine.
If this is a fuel injector type engine you could have a bad injector control unit or a clogged injector.
If it fires with gas in the intake manifold then suspect carb or injector system. (which ever applies)
Thanks for using FixYa!
Kelly
Posted on Feb 19, 2010
  • 18 Answers
SOURCE: 2007 polaris trailblazer not charging how to test
I would start by making sure your battery is fully charged then with the battery connected, use a multi meter to measure the amps going to the battery while you have someone hold the throttle steady at different rpms. then you can check the capacitor charge coil resistance I think its the black/red to brown/white 120 ohms black/red to ground infinity and white to ground zero ohms. Hope this helps.
Posted on Mar 27, 2010
SOURCE: No spark at plug on 99 polaris 250 trailblazer
i bought a 92 polaris trail blazer im very confused cus it has no battery and no battery leads going anywere and it has a back up pull start but its not geting any spark at all what should i do im not very good with quads?
Posted on Jun 11, 2010
Where is the fuse box on a trail boss 330
Here are a couple of posts.
Polaris trail boss fuse box location
This is different year but might help,
http://atvconnection.com/forums/polaris/336771-06-trail-boss-330-a.html
Nov 25, 2015 | Polaris 2009 Trail Boss 330
I have a polaris 2008 trailblazer 330. It turns over but has no spark. What and where should i check 1st and next
start with a new spark plug,if no luck,try looking for an earth wire that maybe loose.if all wires look good,you may have a bad coil lead.that is the lead you put on the spark plug.try those things first
Oct 21, 2015 | ATVs
Kenmore gas range when no clicking when turning the oven on
Get FREE Standard Shipping on orders of $100 or more. Details
Range: Gas burner won't spark or ignite A surface burner igniter switch and a spark module activate the spark electrode when a burner is turned to the "Lite" position on a gas range's cooktop. If the surface burner switch, spark module or wiring in that circuit fails, the spark electrode won't work, and as a result the gas burner won't light. If those components work but the electrode won't spark, the problem could be that the spark electrode is coated with spilled food of is bent or broken. In addition, the electrode won't spark or ignite the burner properly if the ceramic insulation sleeve below the tip of the electrode is cracked or broken. If the gas burner isn't lighting, these repairs may help.
Range 101
See all articles These repairs may help solve your problem:
Replace the spark igniter electrode
1396454293470.jpg The spark igniter electrode-also called the surface burner igniter-is an insulated electrode that provides an ignition spark to light a surface gas burner. It sparks and makes a ticking sound when the burner switch is turned to the Lite position. Replace the spark ignition electrode if it fails to spark or if the ceramic insulation sleeve is cracked or chipped. How to Replace a Spark Igniter Electrode in a Gas Range Find This Part
Replace the surface spark module
1377098014986.jpg The surface spark module is in the ignition circuit for the gas surface burners. When a surface burner control knob is turned to the "Lite" position, it provides voltage to the spark electrodes on the gas surface burners. If the surface spark module fails to provide the electrodes with voltage, then it should be replaced. Find This Part
Replace the spark igniter switch
1396454315355.jpg The igniter switch is an electrical switch on the stem of the gas surface burner control valve. This switch completes a circuit to the surface burner spark module, causing the burner igniters to spark when the burner switch is turned to the Lite position. Replace the burner igniter switch if the burners don't spark when you turn the burner control knob to the Lite position or if igniters spark constantly even when the burner knobs are in the Off position.
May 27, 2014 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
There is a rubber hose that runs up under the steering column on my 2011 polaris 330 trailblazer ATV that spits gas out when it's warmed up, how can I prevent this
I'm pretty sure that means that you over filled the tank, as it heats up it expands.
Or the Float is stuck inside the Carburetor, and it would have to be rebuilt.
May 22, 2014 | Garden
Trailblazer 250 wont start
check/change, Battery, spark plug, remove air filter, use starter fluid, drain all old gas. use premium new gas. usecarb cleaner...should run,.
Mar 28, 2014 | Polaris ATV
No gas to oven and burners, only one burner sparks no matter what knob you turn on
For burners, the sparks should fire vertically upwards. If not they wont light gas. If the other three are not sparking, and this problem started at the same time. replace the spark module. If the sparks failed over time, replace the spark switches which sits on the shafts of each burner.
If no gas to oven or burners, your problem is the gas supply...to the gas valve or leaving the gas valve.
This repair would be for a trained person.
Oct 19, 2013 | Kenmore 78812 / 78814 / 78819 Gas Kitchen...
Ok where is the tempeture sensor on a freaking Polaris 300 trailblazer !
Trailblazers that I'm familiar with (250's, 400's) they had coolant sensor in the head for the overheat light and another coolant sensor on the radiator to tell the cooling fan to cut on/off.
May 12, 2013 | Polaris 2008 Trail Blazer 330
No gas to spark plug on atv
carb float/needle sticking opening the carb drain will provide evidence if fuel is reaching fuel bowl, if fuel is present then i would suspect the carb is gummed up and it will need to be cleaned ( all jets/passages ) another area could be that the gas cap vent/line is plugged not allowing fuel to flow by gravity feed.
Jan 08, 2012 | Polaris ATV
Troy built 675 series will not start and has gas . Ive checked the spark plub connection and all is good .
have you checked the quality of the gas? is it old from last season? open the gas cap and smell the gas,does it smell like varnish? If your gas is bad it wont start because it has lost it"s flamability.also you don"t what to use old gas because it can damage your engine by causing your valves to stick or freeze up...If your gas is bad you need to drain your fuel tank and carb and replace it with fresh gas..You might want to go and get some fuel stabalizer at the auto store or wal mart and add it to you fuel can you use to fill you mower. That way your fuel will be good for up to a year when stabalizer is added to your gas..Have you checked for a spark at the spark plug? remove the spark plug from the motor, plug the spark plug back into the plug socket and lay the spark plug aganst the muffler, pull the pull start cord and look at the end of the spark plug for a bright blue spark. You might want to do this in the shade to be able to see it. If you don"t see a spark , i would try a new plug first and see..if still no spark then your ignition coil has gone bad,that is the whole unit from your spark plug wire to the coil..check these items first,,,
May 26, 2011 | Troy Bilt 5.5hp Self Propelled Mower
Garden Logo
50 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
