I have a sylvania SMPK3604 4GB and the battery died and now I can not get it to charge
The battery ran down to nothing and now I can not get it to charge, I charged it before I used it now it won't turn on to charge.
  • 123 Answers
SOURCE: My laptop won't turn on,
Good day. You can try to do these steps which is usually a normal solution to this kind of issue:
1. Take out the battery of your laptop
2. Remove main supply, or power cord
3. Hold power button down for 30 secs,
4. Put only power supply in or power cord
Note: do not put battery in yet
5. Turn laptop on
6. Put the battery in.
If this will not work you might consider contacting toshiba tech support for laptop for other resolution. Hope this information will be helpful in resolving your issue. Thanks for using fixya and have a great day.
Posted on Jun 25, 2011
caroldon
  • 17130 Answers
SOURCE: My battery on my ASUS
Check the voltage at the pins of the adapter. If present accordingg to the specifications then connect to the laptop and remove the battery from behind. Now check the voltage at the battery terminal of the laptop. if there is low or no voltage to the desired level then there are problems within the main board as this insufficient voltage will not charge the battery makeing it go down below level.
Posted on Jul 09, 2011
jryc32
  • 408 Answers
SOURCE: My daughter's Acer Aspire 5732Z laptop will not
It sounds like the battery charging ac cable might be faulty.. You might want to go to a local shop and see if they could try another cable before you go out and spend money on a new one. They usually will try a cable to see if that's the problem.. Please let me know if this washelpful and if it solved the problem and good luck..
Posted on Sep 10, 2011
SOURCE: Netbook charging indicator light won't light
If the battery won't charge and the laptop won't turn on but the ac adapter works with other laptops, then the problem is the port where you plugin the ac adapter. Some of the laptops has it built in to the motherboard. So you might need to have it repaired by a technician. Or if the laptop is still in warranty, you might need to send it to the manufacturer to have it repaired or replaced. But if the laptop works without the battery, or it will turn on but the battery indicator is not lighting up, you're facing one of these problems.
1. The battery itself is dead. 2. the battery bay is loose 3. the battery itself is loose
Hope this helps...
Posted on Sep 15, 2011
luis_david
  • 407 Answers
SOURCE: ACER ASPIRE ONE D255E POWER CORD WON'T CHARGE
Hi: Acer chargers have a very short life time, in the past 2 years I had bought 2. Just buy a new one from amazon they're very inexpensive. Here's the link: http://www.amazon.com/Laptop-Adapter-Aspire-AOA110-AOA150/dp/B0028LK6IU/ref=pd_bxgy_e_text_b
Regards,
Posted on Sep 25, 2011
I have a sylvania portable swivel screen ..sdvd7027 and i need to know how this will charge battery i have a plug in cord but i dont have remote or cigg plug but as soon as i unplug cord it dies ...?
sales brochure says it has a battery
best guess a lithium type
but can see any for sale ..as a single battery replacement
for one
if you didnt have to fit a battery it will be inbuilt
if new will take some time to charge it up
if not charging will be the wall plug adapter or battery failure or an internal failure of the charging section of the devices circuit board
Amazon com Sylvania Portable DVD Player SDVD7027 7 Inch Swivel Screen...
Oct 13, 2016 | Sylvania Computers & Internet
No power no lights no nothing
Check state of charge of the battery, check battery connections are clean and tight, if the alternator has packed in or the drive belt broken, no charge, the vehicle ran till it drained the battery. See if the car will jump start. If yes, connect a volt meter to battery and check charge rate.
Jan 28, 2014 | Fiat 124 Cars & Trucks
2001 kia sportage while driving on the highway all power died and will not start back up
Your alternator has probably failed so you were running off your battery. when it ran out everything shuts down. Charge the battery, then start the car after you start it disconnect your battery if it dies your alternator is bad.
Nov 08, 2013 | 2001 Pontiac Sunfire
Replaced the alternator and battery on 98 civic ex, car ran cherry and all of a suddent doesnt want to start, just died on me while driving.
ran cheery, the exhaust ran red hot? LOL.
the engine runs off the alternator not the battery.
so , if the alt is bad,the battery will discharge.
the alt charge lamp glows, did it?
old post,
bad alt, or battery is no good.
try a known good battery , and make sure the
voltage across the battery is 13.3v to 15vdc running.
if not the ALT System is bad, notice I said system.
btw , replaced means nothing to me.
new , used, rebuilt, recycled, , what?
Sep 20, 2013 | 1998 Honda Civic
Battery will stay charged
Have the battery charged and tested and then test the charging system. You should never run a car with a very dead battery. that will burn out the alternator.
Sep 14, 2013 | 1996 Buick Century
My iphone 2g wont turn on, i replaced the lcd, it worked ok, my batter was low. so it died and i was trying to turn it on, but it wont turn on. when i plug in the wall charger nothing happens,but when i...
I have a feeling that when you ran the battery down it is now struggling to get and hold a charge.
If you have a friend with a similar battery perhaps try that, or go to a mobile store and ask them to try a new battery for you.
Nov 09, 2009 | Apple iPhone 3G
My Mp3/Mp4 player dies too quickly! I really dont know why! When it gets done charging it dies in literally 5 min!!!! Help!
just a guess but have u had it quit awhile? or put it to use a lot? [charged it and ran it down a LOT of times] the batterys deteriorate after awhile and depending on the make u may be able to have shop replace the battery.
May 17, 2009 | Samsung YP-K3 MP3 Player
2006 Tuscon Battery Dies while Parked--randomly
It is the Alternator. The Battery will Charge But drains while Driving. The Alternator is not Recharging the Battery while the Motor is Running.
Jan 21, 2009 | 2006 Hyundai Tucson
Computers & Internet Logo
David Payne
David Payne
