Question about Brother HL-2170W Laser Printer
Brother HL-2170W Laser Printer is 'offline" wont turn back online
I have tried the obvious things like right clicking the printer icon and property menu, taking out the paper tray, restarting everything, can anyone suggest anything else short of uninstalling and reinstalling the printer. The wireless installation for this printer took hours.
  • 5 more comments
  • Anonymous Jan 21, 2009
    have the same problem but im using windows vista
  • Anonymous Jan 22, 2009
    Same problem, but in Vista
  • cohollaren Jan 26, 2009
    I have windows vista
  • bfhardies Feb 28, 2009
    Brand new printer, using Windows Vista. Print settings pages print, but cannot print from the computer to the printer, it just stays out there in the printer queue. It says the printer is off line, I don't know how to get it online.
  • rossmahn Mar 02, 2009
    The Printer HP LaserJet 3390's Status is Offline. How do I get it back Online?
  • joldfield495 Mar 09, 2009
    I have the same problem with "offline". I have tried to install several times using all methods. At the very end of installation the printer icon appears green in the toolbar for 1 sec. then goes to off line. I have used cable method, and wireless method. It acts the same way when tring from a cabled desktop through a Belkin Wirless router.
    Thanks
  • honey
    honey Jan 26, 2018
    Give a call to support (877-690-9305)
I have a lap top and was having the "printer offline" problem
1) I did the triple click on the printer as in soluyion two to get the IP address which is clearly labled on the 3rd page.
2) Clicked on "Devices and Printers" in the "Start" menu
3) Right clicked the "Brother..." icon and selected "Remove Device"
4) Selected "Add Printer" on the "Devices and Printers" menu
5) Selected "Add a wireless, network, or bluetooth printer"
Nothing was coming up in the search so...
6) Selected "The printer I want isn't listed"
7) Selected "Add a printer using TCP/IP address or host name"
8) Entered the IP adress from the 3rd page of the printout on to the line "Host name or IP address"
9) Left the "Query..." box selected, clicked "next" and printer installed
Posted on May 22, 2010
Before I tried any of the 'reinstall everything' steps, I held the 'go' button down for 10 seconds to get the Network Configuration Page (as per Brother Web Site) and after it printed out, all my other print jobs printed as well.
Ed Z
Posted on Jul 30, 2010
  • 1 more comment
  • imturok Sep 30, 2010
    Good solution.
  • dsaldana27
    dsaldana27 Feb 06, 2013
    Yeah it seemed to work for me as well
  • John DeGrauw Mar 24, 2013
    The same solution worked for me on my HL-5370DW. Thanks!
    Problem Solver:
  • 5 Answers
On Windows XP the solution is as follows. Do the install per directions using the network cable method. Install BRAdmin light off the setup disk. ( password=access)Then, get into Printers And Faxes via the the Start->Settings method and DELETE the printer then (you will need the IP address of the printer, it will be something like 192.168.2.3) For Windows® 2000/XP and Windows Server® 2003 8
In Printers.& FAXES
Click Add a printer to start the Add Printer Wizard.
For Windows® 2000: Double click the Add Printer icon to start the Add Printer Wizard.
c Click Next when you see the Welcome to the Add Printer Wizard screen.
d Select Local printer and deselect the Automatically detect and install my Plug and Play printer
option, then click Next.
e You must now select the correct Network printing port. Select Create a new port and select
Standard TCP/IP Port from the pull-down window, then click Next.
f The Add Standard TCP/IP Printer Port Wizard will now appear. Click Next.
g Enter the IP address, or the node name you wish to configure. The Wizard will automatically enter the
Port name information for you, then click Next.
h Windows® 2000/XP and Windows Server® 2003 will now contact the printer that you specified. If you did
not specify the correct IP address or name then an error dialog will appear.
i Click Finish to complete the Wizard.
http://www.brother-usa.com/ModelDocuments/Consumer/Network%20Users%20Manual/NUM_HL_2170W_EN_1292.PDF
Posted on Jan 21, 2009
  • Ron5590 Jan 26, 2009
    I later discovered that rather than the install/delete/manual install method that there is a cleaner way. After the cable install the software then launches the driver install part. During this you get a screen which asks you how the computer will identify the printer. The default (recommended) part of the screen says pick from a list. The next option down is to input the IP address. USE THIS OPTION and it will work.
Just to add onto Solution #1. I did the main solution which worked, but I had the wrong IP address at first. The way to find it is to click on the "Go" button on the printer 3 times in quick succession. Then, you'll get a three page printout of settings -- the IP is on page 3.
Posted on Apr 04, 2010
    New Friend:
In the first place, twofold watch that the printer is both on and associated. On the off chance that you haven't as of now, have a go at unplugging the printer from power for a couple of minutes and after that connect it back to.
Fizzling that, erase the printer in Devices and Printers and re-include it. On the off chance that that doesn't work, take a stab at reinstalling the driver.
For help or support, visit at Brother Printer Support
Posted on Feb 21, 2017
My printer is offline. How can I get it back online?0 It will not print anything. Everytime I send something to the printer it goes to pending.
Click Start > Go to Control Panel > Printers and faxes or Printers > Right click on the Printer > Select "Use Printer Online"
Oct 19, 2010 | Brother HL-2170W Laser Printer
Why is HL 2170W printer saying it is offline. It is wireless and I used Netgear
Go to the computer Control Panel, select Printers, right mouse click on the printer and choose Use Printer Online. See what happens.
Mar 16, 2010 | Brother HL-2170W Laser Printer
Brother 2170W "fails to associate"
Have you tried the SecureEasySetup method of connecting your HL-2170W to your wireless network?
Basically, it involves no wires:
1) Press the wireless setup button on the back of your printer (you may need to use a pen or pointed object)
2) Press the SecureEasySetup button on your router
3) Let the two sort it out - Green Go button on printer indicates success.
A complete guide for using the SecureEasySetup for your brother model:
Brother SecureEasySetup Method
I hope this helps!
Jan 26, 2010 | Brother HL-2170W Mono Laser Printer
Brother HL-4040CN successfully installed but shows offline
I assume it's turned on and connected to the router.
Sometimes with DHCP, the IP address on the printer will change. I end up going into the router table to see what IP addresses are assigned where. Invariably I'll find my network printer has changed. Find the printer and write it down.
In Windows, Go into Printers> choose the Brother and right click to check Properties. Look for Ports and change the IP address as needed. It will come back online.
Sep 16, 2009 | Brother HL-4040CN Laser Printer
Offline
change the data cable of ur printer
Sep 12, 2009 | Brother HL-2040 Laser Printer
Printer shows offline after installing correctly
make sure that the printer is turned on.
if you have the printer settings, you can check the configurations.
but if you have windows xp installed on your system, you can check the control panel, printers and faxes, then right click on the printer, you must set it as a default printer, and uncheck the use printer offline.
Hope this will help you solve your problem .
Aug 09, 2009 | Brother HL-2170W Laser Printer
Brother HL-2170W Laser Printer is 'offline" wpm
I had the same issue and searched ALL over the net for a solution and was thinking about returning the printer until I found this. It works, ALL of my computers are up and running with no issues at all. Just follow these instructions and you should be up and running in no time.
http://welcome.solutions.brother.com/bsc/public_s/id/pdf_pub/faq/faq002519/wireless_wcable_hl2170w.pdf
Jan 04, 2009 | Brother HL-2170W Laser Printer
My brother laser printer 2170w is saying it's offline and I have no idea how to get it back online
just right click your printer icon in printer properties.it will pop out some options.in that options it will also pop out the offline option just click that offline option it will turn in to online option.if u find it hard just uninstall the printer drivers and reinstall it again from the printer driver installation cd.it will work properly.
thanks.
Dec 15, 2008 | Brother HL-2170W Laser Printer
Printer offline?
CLICK THE START ICON ON YOUR PC. THEN SETTINGS.THEN PRINTERS AND FAXES. THEN RIGHT CLICK WHICH PRINTER YOU ARE USING THEIR IT WILL SHOW USE PRINTER OF LINE CLICK THAT AND THE TICK MARK ON THAT WILL GO AWAY AND IT WILL BECOME ON LINE.AGAIN RIGHT CLICK ANYWHERE ON THE WHITE SCREEN 3-4 TIMES.IT IS DONE. WISH YOU GOOD LUCK.
Jun 02, 2008 | Brother HL 5170DN Laser Printer
Printer offline
Go to control panel and printers and faxes on your laptop and when you see the printer icon for the printer, right click on it and left click on use printer ONLINE. make sure then that the laptop is communicating with the printer.
Apr 13, 2008 | Brother HL-2070N Laser Printer
Brother HL-2170W Laser Printer Logo
26,527 people viewed this question
James Cagle
James Cagle
ctnozil
Victorman
Victorman
