I have a 65 inch Toshiba tv model 65h84 That the sound works but the picture does not show that good
Check cable from TV to wall socket for antena - check for continuance with a multimeter.
Posted on Nov 02, 2012
4 Suggested Answers
SOURCE: Toshiba 42 inch plasma TV: small pop and then no
U R F*cked
Posted on Aug 06, 2010
salt56
  • 373 Answers
SOURCE: The picture on my Toshiba
This model 65H84 is a rear projection type with three picture tubes. And if I am not mistaken is around 10 years old. So, if it is at least 10 years old then the picture tubes are getting weak and burned out, therefore not producing a bright enough picture. Typical with rear projection with age on them.
Posted on Jun 28, 2011
spr1949
  • 1182 Answers
SOURCE: tv sound plays but no picture
Some components have failed inside the board. Kindly do not use the TV until serviced by a qualified technician.
Posted on Jul 23, 2012
The unit will not turn on. A red light blinds and that it. No picture and no sound
I have the same problem on the same tv. If you have fixed it by now please inform me how, I would really appreciate it. And vice versa if I get mine fixed.
Aug 08, 2011 | Toshiba 65H84 65" Rear Projection HDTV
The picture on my Toshiba 65H84 - 65 Inch Theaterwide HD Projection Television is going dark. Is there a bulb that I can replace? If so, how?
Jun 28, 2011 | Televison & Video
Hi, My friend has a Toshiba 65h84 Rear projection tv that has bad picture. when turned on it shows some snow effect but pink instead of white. when we connect the cable you can see distorted video on the...
Chances are you have a defective hyper module. The symptom with this problem is called piecrusting and appears as a squiggly and distorted picture, usually worse at the top. It may dissipate after 20 to 30 minutes as well. This module has been out of production for a few years but some regional companies will rebuild it for around $125.
Bill W
integrityhomeworx.com
Mar 14, 2011 | Toshiba 65H84 65" Rear Projection HDTV
I have a 65H84 model TV and plan on moving it to a different room. This TV was in place when we bought the house from previous owners. Does the unit come a part in two sections for easier moving? Thank...
No,this thing come in as a whole tv unit,dosen't come aparts.U check the tv,see if it work,before going all the troubles moving it to another room.These DLP tvs design are notorious for it tv convergence problems and DM power supply board intermittently shutdowns alots.It bulky design and not work for free DTV over the air.
Feb 08, 2011 | Toshiba 65H84 65" Rear Projection HDTV
No picture--help
I'm assuming you are trying to view an input, like a DVD recorder or Cable/Satellite box?
If so then you need to check the connections. This problem usually occurs when there's a loose scart.
Feb 19, 2009 | Toshiba 65H84 65" Rear Projection HDTV
My hd tv doesn;t have a picture. the sound is on and the on/off
we have not solved the problem and we paid for your premium assistance program and our talk was terminated early., i wasn;t able to get back in..
we get in touch with me. it is impossible to speak with you...
Problem with toshiba 65H84
Good Day, mowattearl;
The most common with this TOS TV is the failure of the convergence IC's, but rebooting, resetting first, unplug TV from wall for 3-5 minutes then plug back into wall. The "conv" IC's are STK's, large black devices mounted to a large heat sink on the verticle.
Good luck, big IRISH.
Jul 24, 2008 | Toshiba 65H84 65" Rear Projection HDTV
Dim picture from one broken lamp??
The red CRT is most likely not the culprit. If water got on to any of the boards such as the red CRT driver board it could damage it wich also at the same time can load down voltages (200 volts etc) that can have a global affect on the other CRT's. Changing any on the CRT's by the average consumer is NOT recommended because you are dealing with a device that requires 30 KV (thats thirty thousand) volts to make it light up. Take these as warnings and consult with a technician.
Dec 08, 2007 | Toshiba 65H84 65" Rear Projection HDTV
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
